TQ Racing SX8
#196
My SX8 prepared for the Weekend...
Here is my SX8 Ready For the Werks Nitro Madness Race this weekend at Prairie City RC Park In Sacramento California...
#197
Wow Joel! The car looks hott! Good luck with your new SX8.
#198
Thanks Joe, I had raced it in Paradise California with great results, the car worked really well. Now it's off to a much bigger and faster track, really excited to learn how its going to handle the terrain...
#199
All the guys on here are very helpful if you ever need anything, just ask.
#200
could someone help me please. i may be over looking this problem..i was also doing the build at 2 a.m. but i assembled the steering assembly and when i put it on the chassis it has a hard time turning. i noticed it was rubbing on the hing pin bolt and screw.Should i switch the hing pin around so the screw head is facing the back of the casing? i can switch the one hing pin back to the E-clip one and it clears it no problem. i am not sure if one of the hing pins where slightly shorter then the rest or i possibly assembled it wrong.
Thanks Ethan
Thanks Ethan
#202
Ethan put small spacers in the front side of the pin and it will stop the binding,we have shorter threaded pins coming out now.
Luther
Luther
#203
LOOKING GOOD JOEL good luck this weekend
You can also dremel the bottom of the steering bellcrank if you want....... thats what I've done on my cars......
I'll also be at our ROAR regionals this weekend with alot of fast guys.... I should be able to report throughout the weekend
#204
Just finished building mine. I ran a couple minutes real quick in my driveway. Still have to set camber/toe, but all in all, things are looking pretty good. I also used the captured pins, and had the same binding problem. What I did was to put the nut on the front, but I had to cut a little bit of the bumper so it would fit over the nut. Hope this helps.
Shootin for the BMain @ The Barn this Sunday
#205
Thanks Ethan
Thanks Ethan
Thanks Tony, good luck at the Regionals this weekend, hopefully we can put on a good show for the SX8...
#206
empirerc ygpm
#207
Car looks good Joel I like those colors
#209
Thanks for the fast replys! i will def try switching it around today! good luck Tony! Hopefully i will get it fiinished up today!
