MST-1 Owners Post Here!
#767
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
Moving the body posts higher sounds like a good idea, did it look good to?
#768
Wouldn't it work to carefully heat the body with a heatgun and then press it on to the MST-1? Or would that hurt the Lexan?
#770
More wise words Since my buddy never races or something like that, he doesn't work much with the set-up, tires and springs seems to be enough
#771
Yes heating the body and changing the shape will work, just be careful not to change the shape of the wrong areas. I have done this in the past when bodies we not as dialed as they are today.
#772
Thanks I'll forward it to him
#774
Yes, defentately. Maybe could he even practise on one of my old touring bodies that's ugly and worn
#775
re axles
well I got my new axles and they are totally different material also got the hexes ordered. I had a chance to call out and talk to Kris at mugen I'm totally impressed with these guys and there products I've been looking at 1/8th scales and I can guaratee it will be a new prospec that I buy . all I can say is great job guys Thanks .
#776
re setup
looing for a set up for a tight indoor high bite track does anybody have one? plmk Thanks
#777
indoor track setup
This is the closest setup I found on indoor high bite:
front
camber= -1
toe= 0 or .5 out
ride height= level
piston= 1.5mm
oil= AE 25wt
spring= mugen grey
in spacer= none
out spacer= unthread shock 2 turns
shocks mid on tower mid on arm
camber link short with .06mm spacer on bulkhead none on hub
rear
camber= -.5 or -1 deg
wheel base= 1mm front, 3mm rear
toe= inside 3deg, outside 2deg
mugen drivers say 4in and 1 out works even better
ride height= bones just above level
piston=1.6mm
oil=AE 25wt
spring= mugen grey
shocks out on tower in on arm
camber linkupper inside on tower outside on hub
use tire of choice at track I used red tapers in back with silver in front. m3 evil twins worked well for me as well.
front
camber= -1
toe= 0 or .5 out
ride height= level
piston= 1.5mm
oil= AE 25wt
spring= mugen grey
in spacer= none
rear
piston=1.6mm
oil=AE 25wt
spring= mugen grey
#778
os carb
Gary, I ran my mst-1 with my drake pipe and o.s carb yesterday. It was so smooth. I don't know how I ever got around the track with the stock setup. I have a race in Feb. so I will know more about it then but summer is looking up. I'm tempted to keep running the mt12 as long as I can, unless someone can convince me otherwise. Are the peak motors awesome or are the mt12 just as good.
#779
Does anyone have any ideas on the spring rates on the silver ,grey and white springs for the front and rear of the truck?
#780
Stu: I am glad that the pipe and carb worked well for you. I have been running the Peak Diablo .12 Rear exhaust with some modifications and it has been awesome. In stock form the engine lacks power and top speed. Peak is currently working on possibly having a new veresion of the engine come out, with the same specs as what I have been running. Phillip Atondo also ran one of these engines and liked it. So it should be good considering the street price is around 119.00 and it can be rebuild for 25.00 or so.
