Mugen MBX6
#5446
Thanks for all the help guys
#5447
A lot of people don't seem to use enough brakes and try to get the car around corners at impossible speeds then they complain that the car doesn't have enough steering...
when coming into a corner just tap the brakes in order to get some weight on the front unless your suspension set up is totaly messed up your car will have a nose down position and tons of steering.
I learned this when i started following the faster guys around the track and I realized they weren't trying to get around the corners at break neck speeds.
#5449
Can anyone shed any light on this Over drive or under drive Diff gearing I'm hearing about ?
What parts are needed ?
Rod
Rod
#5450
Set up?
can someone please help i am all over the place trying to find a good set up
i read couple of pages ago that allen42 has good set up but cant find it
if possible can someone post a set up sheet please.
thanks
j
thanks
j
#5451
#5453
555
10/11 springs, 450/400, 6 hole pistons
#1 kickup block
0 2.75 toe block
3 deg of antisquat(use the upper pos.)
rear a arm forward
hubs in lower hole and middle on a arm
rear camber link middle on tower and outer on hub
front upper/lower arms middle
front upper pin pos high
2.3/2.7 bar
106/126 droop,measured from center of shock bolts
lower shock outer hole/upper middle(on tight low speed tracks i move the front shocks out one hole on the tower for more steering)
do not use s3 orings in diff
14 tcb,.9 springs,stock alum shoes
mount wing with upper holes to lower wing and forward
standard wing-no high downforce
avid disk brake rotors/xray laser cut shoes
keep all hinge pins free with play, most overtighten and bind their susp.
with full tank of fuel,car ready to run, drop on bench and set front arms level and the rear just above level. the rear ride hight is VERY important to the steering of this lighter car. just a 1/2 turn on the rear collar's will make a BIG change!
set swaybar preload at, front 1/8" and rear at 1/4"
2-3 deg of camber
#5454
for the lower speeds of indoor we used jammin springs
white fronts and rears, when its really slick yellow rears
375/300, 6 hole pistons
last winter 7 4 2 was really good but im going to start with 5 5 5 for this winter.
the shock oils were for some pretty cold temps, for 40 and up i would raise the oil.
#5455
hey allan, I would like to try your setup. But I dont have the shock springs, the 6 hole pistons or the rear 2.7 swar bar. I have the updated mbx6 shock springs and the 2.8mm rear bar. Should I try your setup since I dont have the same parts or would you change a few things since I dont have the parts
#5456
if the track is low speed and low bite your car just wont have the side bite or weight transfer of the softer springs/and rear bar. hope thats what your looking for?
#5458
Hey guys
I am drooling over the M2C rear toe system again as I broke another 2.75x1 block yesterday (was 6degC... plastics were suffering)... is this the one, and are hinge pin included as I can't see them on the pic?
http://www.amainhobbies.com/product_...e-Block-System
to those of you using it, how tough are the hinge pins? Can spares also be bought separately? And last but not least, I think I remember we talked about the RC8 inserts being 100% compatible, were we talking about these as they look eerily similar?
http://www.amainhobbies.com/product_...n-Bushings-RC8
thanks for the help,
Paul
Paul
#5459
Hey guys
Paul
Paul
#5460
Thanks allen42 allthe info i am going to try this set up and stick to it until i can drive better
thanks again
j
thanks again
j
