Mugen MBX5R
#571
the 1.0 mm sevo shims can also be used to space the servo out t let the arm clear the tray.
#572
Has anyone found that you cant get the full steering throw by using the tie rod end on the inside of the servo horn? If i use the inside of the servo horn the rod end hits the carbon fibre plate for the radio tray when its not quite at full throw, i tried using the top hole on my servo horn and same happens and if i use a lower hole the rod end actually hits the servo casing and still not gettin full throw, the only way i could get full steering throw was by using the outer side of the servo horn.
#573
#574
Hey Race Fans
I'm kinda like Rezenclowd. I'm also looking for a new 8th scale buggy to race
next season. I've been racing 2wd 1/10th nitro stadium truck for many years,
but for some reason this class is starting to fade away. I was looking at the
new AE rc8, but Associated tends to cater to the rtr and basher crowd lately.
I know that Mugen Seiki has been an "dyed in the wool" racers only company
for years, on-road and off,with many championships to prove it. Their 1/8 scale buggies have been a big part of their success and been around for more than
a decade. So naturally I have to give the mbx5r a very close look. I know that
as far as quality is concerned the mbx5r has the competition beat. My only
question is handling being that I'm hearing that some of the newer buggies
maybe lighter and more agile?
Best of luck!
#575
Thx for the info guys, i totally forgot about the spacers Im using futaba 9451 servo, i cant remember what spacer i used, ill have a play around with it, im sure i can fix this with the ideas you guys have come up with.
#576
Look at the attached page from the manual & off to the left side note area. It states on the Futaba servo S9451 & S9350 (mine is a S9351) to use 2.5mm spacers and you have to stack the locking blocks offset, one with a thin edge and the other with a thick edge. Mine sets in perfectly and I know a lot of people who are missing this step.
#577
Hey guys had my first race with the MBX5R on friday night. All i can say is i had a ball. Im so happy with my mugen.
Here is a pic and link to results.
http://www.ocrraceway.com/2007%20Results/TDDFC2.html
Cheers
Tim
Cheers
Tim
#579
Nice looking dirt though
#580
Yes the Dirt at OCR is very nice. No rocks just plenty of clay. We had a massive down poor the day of the race so it was a bit boggy. By the A main there was a nice dry hard packed line so it was all good. I have some footage to put up so when i host it ill give you guys the link. Just dont look to close to my driving style. Buggy needs some setup adjustments.
Anyone run the Option Springs and found them Bouncey with 400 Oil?
Cheers
Tim
Cheers
Tim
#581
What is your settings on your shocks at now?
I may throw my progressive hard springs from my MBX5 shocks back on if these springs don't work out.
#582
standard set up except long grey springs, spacers to level arms (2mm). Im going to try no spacers if that doesnt work I'm back to standard springs.
Tim
Tim
#583
hey guys, this is my 1st post on this thread. i recently got a mbx5r loaded with all king stuff except from and rear shock towers.
i did not get a clutch for the guy. can some of you suggest what clutch to use for this car. not sure to buy the mugen setup, or an aftermarket version
#585
hey guys just wondering what the differences are between the "R" spec car and the old MBX5.
i have an MBX5 which i am thinking about up grading to an "R" spec but yeh not sure on which parts i need.
i think that if i get all the things in the following links it should be enough.
http://cgi.ebay.com/MUGEN-MBX5R-PROS...QQcmdZViewItem
