Losi 8ight building and setup
#7231
No, Losi originally put black orings in the cars but due to leakage problems they changed to white orings. Just get the Losi shock service kit it will come with the new white orings.
http://www.tiltedrc.com/product_info...oducts_id=3485
#7232
sounds good. thanks for the help. talk with you later.
#7233
hey, i've got a revo 3.3 as well. do you think the 30 weight shock oil is appropriate for that truck? if not which weight should i go with for the 3.3?
#7234
Well that's really a question for another forum, but I 'll help you out. I run 50 wt in my revo. 40wt in the 8ight.
#7235
Took my 8ight to Revelation raceway tonite, its maiden voyage on the track, and all I can say is .....WOW!! This thing is bad ass! I had allready put 5 tanks through the Hyper21 in a parking lot with road tyres and managed to put another 8 tanks through it at the track with out a glitch. The motor started to wake up but is still really tight.
I have been to the track numerous times with my race prepped LST2 and CRT.5 and have never had this much fun!! Ran out of fuel twice since I was having so much fun....I'm in love and I'm even thinking of attending the club races at Revo. too.
#7236
I know that I have seen this before, but I can't find it on here. I was running my 8 this afternoon. The coupler from the front driveshaft to the diff decided it had better places to be than my buggy. No biggy. What is everyone using to keep that thing together?
#7239
what is everyone using for clutch bells. I have been using the stock Losi ones or the Robinson ones. I have been having a lot of problems with the stock Losi ones. The bearings fit very loose in the bell... and causes a lot of slop side to side.. this is not good as it takes the bearings and the bells out... (this is with new bells) also I tried the super glue trick.. seems to work for awhile but you have to redo it alot.... with the Robinson bells, I have 3 of them and all 3 have teeth missing.....
so I ask... is there a better clutch bell that fits on the stock flywheel/clutch setup ?
#7243
R/C Tech Elite Member
Allright, but I would recommend that he ask another losi guy around him to look at it... I dont seem to have much slop in my clutch bells but they aren't that old either... If I have a problem I allways ask for a second set of eyes on it. ALLWAYS works! A second opinion touching the item allways helps out for me....
#7245
I'd look, or have someone else look at your gear mesh as well. Too tight will grenade clutch bearings, and too loose will grenade bells and bearings. The "jam a slice of paper between the gears, then set" trick works well.
There needs to be a little play in the clutch bearings, it sometimes does feel excessive, but it needs to have that. I replace the bearings often, usually every 1-2 weekends, depending on the dust-e-ness of the track. I use the metal-shielded ProTek bearings from A-Main, and at $1 a pop they're easily worth it. I know guys that use rubber shields from there also and have no issues, but clutch bearings will wear out faster than most other parts of the car due to the heat generated in their immediate vicinity, and the aluminum/composite dust that they gnaw on constantly. And once those things go, your bell can start moving too much, so bearings would be another item to check. Spray them out with electric motor spray, and make sure there is no crunch or stopping when they spin (very free) under minimal effort. If you re-oil them, don't go crazy.
