Losi 8ight building and setup
#7081
4 shoe clutch??
Hi everyone,
Quick question, I am running the 8 RTR that came stock with the 2 shoe clutch flywheel setup, I ordered 4 new shoes and springs. Can I run the RTR flywheel with the 4 shoes without any problems? I was looking at another guys flywheel that runs the race roller and the flywheel looks a little more beefer that the RTR one..Any thoughs?
Thx
Dan
Thx
Dan
#7082
I had issues with the srings on the caliper's...when they would get dirty it would cause them to stick even more if the springs weren't there....i even went as far as to polish the rods they ride on..and it still bound up every once and a while.....i have since Ditched the springs....and if u take the time to set-up the linkage properly u should'nt have any brake drag anyways.
The springs on the caliper screws allow one to adjust the brake WAY close to the rotor. Without them, it kicks the rotor off to an angle when on the brakes thus giving you very little contact area and alas; fade. Not to mention wearing out the rotor very quickly.
It appears a slightly longer pivot arm would fix the problem, but the springs work perfectly if you get it just right.
#7083
Hi everyone,
Thx
Dan
Thx
Dan
I've only seen one RTR, but the flywheel looked exactly the same - just minus two shoes. You should be able to add another two shoes and have the same setup as the kit/roller. It should also really help the clutch 'feel' too!
#7085
The length of the spring is a key. I ran into the same problem and have since 'designed' a fail safe for the dragging problem. Uses two springs per caliper and springs in the linkage as well.
Also, does anyone run springs instead of fuel tube on the linkage? I thought that was contributing to some of my fade and I put some springs that were slightly more beefy then a ball point pen spring on my linkage. It seemed to help. My reasononing was that once all that brake linkage starts to get hot the tube just is not consistent and contributes to fading.
#7086
Thats correct, seems like just the part of the flywheel that contacts the starter wheel is thinner on the RTR than the roller/kit. I personally thought that the stock RTR setup (2 alum shoe 2 silver springs) didnt have much feel but felt like it had some snap to it though. I am going to run 2 comp shoes with gold springs and two max life's with silver springs on a sweepy outdoor track with some med to large jumps...Here is another silly question, I tried running 1000 in the rear diff, but i found the rear end would oversteer, not alot but just too much for my liking. I like to run 2000 in the rear diff but that I am fresh out of. I have a race this weekend, and all I (and my LHS) have for diff fluid is 1000 and 3000. What would it feel like if I filled the diff half and half of 1000 and 3000 has anyone tried this? Or should I just run the 3000?
Thanx for the reply guys.
Dan.
Dan.
#7087
if you mixed 3k and 1k it would feel very similar to 2k.
#7089
So Losi quit making the skinny flywheel? I recently bought a new flywheel and thought "WTF" when I saw it was twice as wide as the previous flywheels I've purchased. I didn't think much about it till I ran a race and noticed the difference. I'm still undecided weather I like it or not.
#7091
#7092
#7093
#7094
Like someone else mentioned, it probably was the type of springs used. I am using the same OFNA springs that I use on my Jammin CRT.5 and have never had any brake problems what so ever on that rig. This springs are allmost hair thin with the coils pretty far appart and made specifically for this application. I personally would never use a pen spring because its not desinged to be used as a break spring.
i tried the Ofna's....same result...notchy brakes and they made the cams stick....u would think the 100% opposite...but once u got a little gritty dirt on em they would start to lock up at idle position..the Trinity springs were WAY too stiff and too long to effectively work....the spring is working the servo more then the actual brakes.....so those didnt even get used....i went back to running nothing on the shafts and have had no issues since.....also the ofna's are SOO thin that they can actually get pinched inbetween the cam and the shaft...that caused some Super bad brakes....basically unless ur having brake drag issues then dont bother messing with the cam springs...Its a waste of time.
