thin oils for lubrication
is there a difference in using either bearing oil, cv joint oil or 3in1? can they be interchangeably used for the same things like for bearing lube, after run engine lube, axle/joint lube, etc.
they are all very thin oils. are they of similar makeup?
Of course everyone has their own idea. I have the motto that everything that lubes will work.
Because most oils and greases do not mix with methanol and will create a mess inside the engine.
or should they always be removed before cleaning an engine, carb or diff?
following
Marvel mystery oil is well used and save to use but a simple test shows it does not mix that well with methanol.
I'm sure that all those will work more or less the same. Maybe if you were an absolute professional then there might be a few subtle differences between those types of oils and their uses.
Cylinder oils are more critical. They need to be just soluble enough to blend with fuel and insoluble enough to remain behind on the cylinder when the fuel is vaporized.
