What are you using for grease >
Like Tree10Likes
Old 03-04-2023 | 06:22 AM
Default What are you using for grease
A lot of people use their car brand. I understand that. Getting back into the hobby. What off the shelf stuff do you use? There was an old thread years ago about this, couldn’t dig it up. Copper grease, blue/pink/green/gold. Use to be just red and tacky.
derricklong38 is offline
Old 03-04-2023 | 02:22 PM
Vrp gear honey grease, its very thick, I use it for diffs mostly.
losi black grease is also good.
bratan is offline
Old 03-05-2023 | 01:42 AM
Roelof's Avatar
From a machinist I got some high grade white bearing grease.
Roelof is offline
Old 03-05-2023 | 04:49 PM
petersen114's Avatar
Grease for what purpose?
token likes this.
petersen114 is offline
Old 03-05-2023 | 06:50 PM
token's Avatar
This is the question.....
token is offline
Old 03-05-2023 | 09:27 PM
stanleyw808's Avatar
Hello Roelof,
Can You share the Brand?
For me, the best Grease for Ring and Pinion is Kyosho Ring Gear Grease (Part No. 96126). Have You try this Roelof?
Cheers..
stanleyw808 is offline
Old 03-05-2023 | 11:18 PM
Roelof's Avatar
I do not know a brand but with some search there are some several brands to find like this one:
Griffon | Product
Multi purpose grease.
stanleyw808 likes this.
Roelof is offline
Old 03-06-2023 | 12:28 AM
UrabusDenis's Avatar
Really any grease for machines and gears will do, lots to choose from - I think people are overthinking this but hey, you spend your own money. Maintenance is key, no magic grease will keep an unmaintained car healthy.
With that out of the way, I use a red Total Moly grease in a tube (super cheap!) for closed gearboxes, and some grease in a spray-can for open type gears (for easy access).
UrabusDenis is offline
Old 03-06-2023 | 03:40 AM
Roelof's Avatar
Basically thats it: "any grease is better than no grease".
Rick Vessell and hunterdawg like this.
Roelof is offline
Old 03-06-2023 | 06:35 AM
for any purpose. What do you use on gears, or rings. A lot of companies are now selling copper grease.
Old 03-06-2023 | 03:13 PM
token's Avatar
Gold grease has been known for better metal to metal wear. Diffs last longer. TLR or J&T sells it.
token is offline
Old 03-07-2023 | 09:05 AM
jpz_67's Avatar
Originally Posted by stanleyw808
Hello Roelof,
Cheers..
That Kyosho stuff is good. I remember it from my K car days.
In the past I always used AE green slime for O rings, then the black stealth grease for gears.
As of now I use the XTR stuff. They have 3 different grease, a copper base, a lithium, and not sure on the o ring grease but they all work well.
This is basic preventive maintenance that ensures good and reliable performance. When I do a full big event prep I pull all my out drives and re grease all of them. I am already changing the diff fluids so its just a little more time and worth it. When it comes to the ring and pinion don't over do it.
jpz_67 is offline
Old 03-09-2023 | 11:46 AM
been looking at bringing some in house for sale. just need to find stuff I like enough.
Old 03-09-2023 | 09:04 PM
cansoykal's Avatar
SKF LGWA 2/1 if you could find it. Possibly the best all round grease out there. I also tend to use Mobil Polyrex EM for bearings.
Molykote has some great graphite grease as well.
Nitro5270 likes this.
cansoykal is offline
Old 03-11-2023 | 08:35 PM
wolf16731's Avatar
Protek Premier White Grease for ring and pinion gears for the diff and Protek Premier Blue Oring Grease for shock orings. As for CVD's and universals on the driveshafts I use graphite spray because I don't want a wet lubricant attracting dust and dirt to those areas. The graphite spray dries very quickly and being a dry lubricant it doesn't attract dirt at all. Hasn't failed me yet.
wolf16731 is offline
