Like Tree521Likes
TLR 8ightX
    Hide Wikipost
Old 03-15-2019, 09:43 PM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 8ightX
Last edit by: 1/8 IC Fan
TLR Eight X
Print Wikipost
Old 01-30-2022, 05:29 AM
  #1546
What kind of tool you guys using to cut the 4mm off the front of the rear arms?
xlrsd is offline
Old 01-30-2022, 09:55 AM
  #1547
Blakesrc's Avatar
Trader Rating: 26 (100%+)
A table top bench grinder makes it extremely easy and quick if you have access to one. You can use a dremel with a cut off wheel and sanding drums etc but its a bit tedious.
Blakesrc is offline
Old 01-30-2022, 07:19 PM
  #1548
token's Avatar
Dremel, takes 5 mins
token is offline
Old 02-01-2022, 01:53 PM
  #1549
Any Losi guys planning on going to PNB? I’ll be there. Would love to meet some of you and pick your brains. Lol
xlrsd is offline
Old 02-03-2022, 11:34 AM
  #1550
Hey guys, I am building the 8x-elite and the front differential once it's in the box and trying to spin to see if it's smooth sometimes has a little friction. I guess is the diff box is not completely well finished, I think that it has some kind of contact...
Logante is offline
Old 02-03-2022, 12:33 PM
  #1551
New kit, tight tolerances. Should be fine after break in.
Run a few tanks through her, then check diff play, shim as necessary. This should be done often.
token and Logante like this.
Evoking1230 is offline
Old 02-03-2022, 12:51 PM
  #1552
I was imaging that, but double check asking doesn't hurt. Thanks for the answer.
Logante is offline
Old 02-03-2022, 01:05 PM
  #1553
Default V2 parts
Anyone have information on the soon to be released V2 parts?
D1Rk likes this.
jlett21 is offline
Old 02-03-2022, 04:36 PM
  #1554
token's Avatar
I wouldn't say soon.
token is offline
Old 02-04-2022, 06:04 AM
  #1555
Trader Rating: 27 (100%+)
Bet more than parts are gonna pop up!
RandyJones is offline
Old 02-04-2022, 07:23 AM
  #1556
elex300's Avatar
Trader Rating: 110 (100%+)
Lets hope🤞
token likes this.
elex300 is offline
Old 02-04-2022, 03:42 PM
  #1557
token's Avatar
I think its safe to start saying, "2 weeks"
D1Rk and Evoking1230 like this.
token is offline
Old 02-06-2022, 04:32 PM
  #1558
The more I peep at pics of both Dakota and Ryan's cars I feel like alot of the rear end setup is now based on the XT platform. Even Ryan's ebuggy radio tray seem to be that of the XT.
D1Rk and token like this.
Clifton is offline
Old 02-06-2022, 04:41 PM
  #1559
I haven't seen pics of the radio tray but the rear tower gives it away. Sometimes front too.
Old 02-07-2022, 05:21 AM
  #1560
how so, rear based off XT?
xlrsd is offline
