Tekno MT410
#1336
I really like those old-style Ford pick up bodies. I'm glad you have 'before' pics of them.
#1338
I use Louise RC (Duratrax) tyres/wheels on both my Losis, they just balloon a little, but not so much as Pro-line tyres. However i want to try Pro-line Mashers in the future.
#1339
80lb Gorilla sting. It's in the fishing section at walmart. It's lil over $20 but I haven't broke any yet and theses tires get used weekly. I use 2 constant loops and use witch ever decent knot u can tie. I do have a certain way I tie mine but don't know the technical name for it. Well worth the money.
#1340
Yes but I don't know the technical name for it. I wrap the tire to get the size the cut sting and tie it off the tire then put it on. Much easier than trying to tie it on tire. We run on really rocky gravel and I don't have any sign of wear on the string.
#1341
This is my rear gearbox big bearing modification (8x16x4).
Machined front side, uses 8x16x4 bearing.
Machined rear side, uses 8x16x4 bearing.
The stock pinion bearings are 5x13x4, that's too small for me
Steel bushing, 5x8x8mm
She's ready to run! I ended up pressing in the steel bushing with a vice on each side of the bearing, it's not moving and is rock solid. Everything spins smooth, ready to rock & roll 👍
#1342
Tekno rubicon, your his/hers basher MT410's look awesome and ready for a bashing!! I'm diggin the retro ford body choice and trimming on them! Really like those paddle tires too i've never tried a set.
Impressive machining Overkill, those larger output bearings definitely look BEEFY! You have a shop yourself? Were you blowing through those bearings or just a part you wanted to try and improve?
#1343
#1344
These things are easily the most sturdy RC I've ever owned, but nothing is foolproof. Here's the aftermath of a head on collision with an immovable object at full speed
I hit a 1ft tall ring of bricks around the base of a tree at the edge of a dirt road I was hauling down. Worst possible timing too, it happened right before the weekend's perfect weather.
I had a ton of spare parts stockpiled, just none of the ones I needed It does look like all the parts will be here today, slim chance I'll be able to get it fixed up and get a run in by the time it gets dark though.
#1345
#1347
Quick few question that I know have a few answers....
Intended use will be bashing.. from street, high bite, to grass fields, tracks of course and everything in between. Mainly on 4s. Wheels racer to 3.8s.
Thinking 2000kv? or CC 2200kv?
Diff setup? 70/70/50
Thanks.
Thanks.
#1348
T8 2000kv and CC 2200kv .
Great builds everyone!
I'm hooked.
#1349
