ET48.3 BashBash Build >
Old 08-30-2016 | 12:05 PM
R/C Tech Elite Member
Default ET48.3 BashBash Build
So I started my ET48.3 basher build after consulting this forum a lot.
I've gotten the following parts ready to go:
  • Tekno ET-48.3 Kit
  • Sanwa/AT MT4s
  • Black Tekno Wing
  • 44T Hardened Steel Spur
  • Aluminum 25T Servo Horn
  • Tekno Aluminum Read Hubs
  • Aluminum Split Center Diff Mount
  • Tekno Mud Guards
  • Tekno 2mm Hubs
  • Savox SV-1270TG
  • Tekno Capped Wheel Nuts
  • T-Bone Front&Rear Bumper
  • T-Bone Wheelie Bar
  • Tekno Pink Springs (F) and Orange Springs (B)
  • Proline 3.8 Badlands & Proline 3.8 RockRage
  • Tekno 15T and 16T Pinions
Will post some pictures of the build process soon
mlax is offline
Old 08-30-2016 | 01:01 PM
werner sline's Avatar
•Aluminum Split Center Diff Mount : isn't that already supplied ?
werner sline is offline
Old 08-30-2016 | 01:40 PM
0verkill's Avatar
Sweet, look forward to your initial thoughts.
0verkill is offline
Old 08-30-2016 | 01:48 PM
Mopar2Ya's Avatar
You may already have this stuff:
Heavier fluids, shoegoo & drywall tape, 4mm reamer, doable sided VHB tape, something like clear bra or skate board tape to protect the bottom of the chassis.
No, part of the kit mount is composite/plastic. TKR5262 completes the mount in aluminum. http://www.teknorc.com/shop/tkr5262-...l-ano-ebetsct/
Mopar2Ya is offline
Old 08-30-2016 | 04:51 PM
Decided on the motor/esc combo today and ordered a Castle MMX and C1515 2200KV for now.
For fluids, I went 40k/80k/40k to start with.
mlax is offline
Old 08-30-2016 | 06:18 PM
I bashed my eb48.3 and quickly bent the main transmission shaft. If you crash hard, it may happen to you to. I added a brace between the 2 first chassis brace...
Old 08-31-2016 | 09:02 AM
Can't wait to see pics, I love these truggies....
RC Juice is offline
Old 09-01-2016 | 03:19 PM
0verkill's Avatar
Were you running all 3 chassis braces? I've never seen anyone bend that shaft. Mines still perfectly straight after tons of hard hits.
0verkill is offline
Old 09-01-2016 | 11:51 PM
Here are some pics from the build so far...man this is a lot of work for someone that has only had RTR cars. But the sense of quality and accomplishment is fantastic. Just the sheer thickness of the suspension arms is incredible.
And so the build starts...
A good bit later...first time doing Diffs. Proved to be fiddly and jesus is diff oil messy...
We are getting there...by now I probably have about 10-12 hours in this build. Just the motor missing! Building the shocks was simpler than I thought it would be. The Tekno kit is so well put together and with very few exceptions, the manual is terrific.
to be continued soon!
mlax is offline
Old 09-02-2016 | 05:03 AM
Maximo's Avatar
Lookls great..... but dam you don't need that fugly bumper on a Truggy !!!!!
Maximo is offline
Old 09-02-2016 | 05:38 AM
0verkill's Avatar
True, the ET48 doesn't need a TBR front bumper unless you plan on plowing other cars out of your way. They're mostly made for weak cars.
0verkill is offline
Old 09-02-2016 | 12:36 PM
I actually like it, i think it makes it look a little more rugged
mlax is offline
Old 09-02-2016 | 01:25 PM
Maximo's Avatar
My worry is that its going to cause the car to dig in when it nose dives rather then just roll thru like it normally would, definitely will impede the machines ability to safely land a jump, it will not be able to land with nearly as an aggressive angle of attack as it would stock... Truggies have the wheels very forward and it allows the machine to land nearly vertical and still drive out with some throttle ....If I was doing demolition derby type stuff I could see that bumper helping, or If I was continually 90 degree pogo sticking the landings I would consider it.... Maybe if you were doing Kamikaze backflips it could cushion a really bad pogo sticking landing, but it will come at a price and the machine will want to dig in when it normally would not have...
Maximo is offline
Old 09-02-2016 | 01:35 PM
Mopar2Ya's Avatar
I've never had any digging issues w/mt TB bumper, but I never run regular truggy tires. I have had the TB ET bumper catch on upside down/bad landings. The TB EB48 bumper should also fit the ET, & it's smaller.
Mopar2Ya is offline
Old 09-02-2016 | 01:40 PM
0verkill: can you post a picture of your battery tray perhaps? You mentioned that you modified it to take larger batteries. Any recommendations?
thanks
mlax is offline
