ET48.3 BashBash Build
#31
Seems like there is something wrong with my ESC or Motor according to Castle so I'm probably going to exchange it.
Do you guys have a suggestion for an alternative? There's obviously the MAX8/4274 but anything else?
#32
I've run Tekin RX8 Gen2, Castle MMX(&others), & HW RTR ESC's, & I prefer the RX8.
RX8 Gen2
Pros: better feel, 220amp, size, fan always on(or auto on), Hotwire
Cons: price, not waterproof, no cell auto detect(you have to change cell count, I only run 6s so no issue), must solder
I'm running the RX8 Gen2 w/the T8 Gen2 1350 kv truggy motor in my EB48.3, & it is very smooth, much smoother from the start.
RX8 Gen2
#34
Having a newb moment. I’m trying install some Badland 3.8s on my ET48.3. When I crank down on the wheel hexes, none of wheels spin freely. When I back off the hexes slightly, the wheels roll more freely as they should. However, I don’t want to run loose wheel hexes on my truck. What am I missing?
#35
#37
You can get some wider hubs like these. They’re 1mm wider than stock
https://www.teknorc.com/shop/tkr5071...et-wpins-2pcs/
Or many others I know that HB D8t and team associated rc8t hubs also fit
https://www.amainhobbies.com/hb-raci...bs67804/p54590
https://www.amainhobbies.com/team-as...c81319/p493893
#38
Thanks for the tip chainsaw. I just realized that I have new leftover wheel hexes from my Pro MT 4x4 because I bought the Associated extended hubs per your recommendation in that forum. Works perfect on the ET48.3.
I have to say I like the DBoots Backflips mounted on my MT410 better than these Badlands on the ET48.3. I didn’t realize how much smaller the Badlands were compared to the Backflips. I haven’t tested traction yet between the 2 sets but I suspect the Backflips will do just fine.
#40
Sorry to hear of your issues. I have been running a MMX/2200kv in my basher buggy for over a year now. Dozens of bash sessions. A hundred plus 4s packs through it with a few 6s for speed runs... never an issue. Fan still works. Granted I'm running a waterproof servo at 6.0v so IDK if that is why my fan hasn't failed.
