Traxxas E-Maxx Thread! >
Like Tree4Likes
Old 08-01-2007 | 09:33 PM
  #46
milenko_76's Avatar
The motor esc combo is the Novak brushless. It does alright on the 3300's. I going to try to run 2 lipos on it in the next few weeks. I picked up a pair of 7.4 5350 lipos. The truck should scream then.
milenko_76 is offline
Old 08-01-2007 | 09:34 PM
  #47
streetracer745's Avatar
is it the 4.5 or 6.5? and what is the speed thoughts on the 3300s? im looking at getting that system for one of my nitro mts and converting with a e-maxx tranny
streetracer745 is offline
Old 08-01-2007 | 09:45 PM
  #48
milenko_76's Avatar
A complete run down of whats on my truck;
Aluminum chassis
Aluminum bulk heads front and back
Aluminum diff cases front and back
Aluminum diff cups with robinson racing diff gears
Aluminum chassis braces
Aluminum steering rack
Aluminum servo protector
Aluminum shock towers
Aluminum wheelie bar
Aluminum hexes
Power Stoke shocks
Titanium turnbuckles
Spring Steel bumpers front and back
RPM arms all around and carriers
Steel idler and tranny is locked in second gear
Kimbrough servo saver
Screw Kit all S.S.
MIP CVDs all around and center CVDs
Novak Brushless 6.5
Hitec 5645 steering servo
I think thats it.
Old 08-01-2007 | 09:51 PM
  #49
milenko_76's Avatar
a little bit faster than stock. But it has a longer running time. I'd get the 4.5 if I were you.
Old 08-02-2007 | 08:02 AM
  #50
how much is a little faster than stock? about 30-35mph or so? does it have more torque?
Old 08-02-2007 | 10:07 AM
  #51
milenko_76's Avatar
By a little faster I mean around 30- 32 mph. A stock emaxx on 6 cells is lucky to hit 30 they are more around 26-30 stock. Yes it has more tourqe. You can flip it at half thottle if your not carefull. On lipos the truck should just fly.
Old 08-02-2007 | 11:35 AM
  #52
well i plan on using either lipo or a123 batteries soon. at first it will be regular 6 cell nimh batts, but it will be on the 4.5 most likely. and if it has that much torque, you could very easily gear it down some and make it a lot faster
Old 08-02-2007 | 05:53 PM
  #53
has anyone ever heard of using a mamba max system i na e-maxx? i saw a video of an e-maxx with a 5700 mamba max system. anyone tried this?
Old 08-02-2007 | 10:12 PM
  #54
milenko_76's Avatar
I haven't used a mamba maxx yet. I have used a MGM compro 8012 and a 9L motor. I wasn't that impressed with the 9L. C.C. is coming out with a monster truck brushless though.
Old 08-03-2007 | 08:20 PM
  #55
curious mind's Avatar
a 4.5 BL? very interesting... any advise on the spur pinion combo? will run it on a small-medium technical track.
tnx
curious mind is offline
Old 08-04-2007 | 01:45 AM
  #56
rs550's Avatar
Default emaxx gearing on 4.5 novak brushless
@sir curious mind
...The search for the ULTIMATE is an ongoing venture...Castle Creations and Novak are at the forefront ofthe advances...It was only a matter of time until motors 'overtook' the chassii (thats plural for chassis kids ) they were put into...Believe it or not, Novak has achieved this already...
...Below are the warnings / advice that Novak now gives users of their HV-Maxx system with the E-Maxx (SOOO many X's)...
Updated Gearing Info For the HV-Maxx System:
IMPORTANT: Do Not Use the Stock Traxxas Emaxx Gearing or the gearing listed in the HV-Maxx's HV Motor Wiring Sheet with the HV-Maxx ESC & HV4400 Motor. Using the Traxxas Emaxx's stock gearing or the gearing listed in the HV-Maxx's HV Motor Wiring Sheet will overload the HV4400 Motor and will cause damage.
Please read the following instruction update addendum for the newest official information concerning HV-Maxx gearing. This addendum updates and supercedes the gearing information in the instruction sheet that is included with the HV-Maxx system:
DO NOT USE STOCK E-MAXX GEARING!
This WILL overheat the motor with constant thermal overloading that will result in motor system thermal shutdowns that will eventually damage the motor’s magnet & rotor.
This type of damage will NOT be covered under warranty!
Use the following gear ratios instead of the ones listed in the instruction manual on the HV MOTOR/WIRING SHEET. If you do not gear the E-Maxx correctly, motor damage will occur!
Batteries Final Gear Ratio*
Spur Gear Pinion Gear (no lower than) two 6-cell packs
24.5 : 1 (2nd gear)
70 14
74 15
two 7-cell packs 28.6 : 1 (2nd gear)
70 12
76 13
*These gear ratios are based on using the stock size tires. If you are using larger than stock tires, the gear ratio MUST BE INCREASED accordingly (bigger spur gear or smaller pinion gear).
This gearing will give the E-Maxx better acceleration, better lap times at the track, and the motor will run cooler. The main concern is to avoid overloading the motor to the point the system goes into thermal shut-down. If thermal shut-down occurs, go down 1 or 2 teeth on the pinion, or go up 2 or 3 teeth on the spur. Airflow over the motor also makes a huge difference for overheating problems.
If gearing the truck up for speed runs, just don’t run it to the point of thermal shut-down.
E-Maxx Hop-Up Update: Metal transmission idler gears are part#13407 from UnlimitedEngineering.com
...You can read from this that Novak is quite concerned about upgrading the trucks to handle the beast they have created...Mamba has also told us that the E-Maxx being used to test the Monster Maxx is essentially 'full-metal-jacket), weighs a ton and has full metal drivetrain...
...You can also read above that Novak recommends the metal idler gear from Unlimited Engineering...
...Elsewhere on Novak they also advice the use of the following parts...
Recommended Emaxx Upgrades:
"After extensive testing, we've found that the high power output of the HV-Maxx can be too much for some of the stock Emaxx components depending on how the truck is driven. We used the following performance upgrades for more aggressive driving or racing conditions, and recommend them to anyone who is running an HV-Maxx in an Emaxx. (Note: Not all of the upgrades are 'required', but in the long run, we've found that it makes for a more enjoyable truck)."
Company Part # Part Description
Unlimited Engineering 13407 Super-Maxx Steel Idler Gear
Robinson Racing 8172 Heavy Duty Slipper - Comes with 72spur
Robinson Racing 8590 Heavy Duty Diff Gears
MIP (choose one) 1485 Front/Rear CVD Kit - original size arms
(you need two)
1525 Front/Rear CVD Kit -wider 2.5 suspension arms (you need two)
...I figure that instead of trying to reinvent the wheel, that we take a leaf from the E-Maxx notebook and look towards fitting a similar drivetrain...
...Step into the limelight please Kershaw Designs Thanks to Kershaw's recent releases and their ongoing R&D into what makes the E-Sav tick, we ALREADY have the right components coming to us...Kershaw ALREADY knows what is going to happen and has taken steps to keep us all running on these UBER-systems that will soon be arriving on our work benches...
hope this help u:
PS; comes from bithead post on esavage thread (china syndrome)
http://www.teamnovak.com/products/info_updates/index.html
rs550 is offline
Old 08-04-2007 | 05:19 AM
  #57
Originally Posted by rs550
@sir curious mind
24.5 : 1 (2nd gear)
70 14
74 15
70 12
76 13
(you need two)
hope this help u:
ive done some of the upgrades like MiP's CVD's, metal idler gear, RMP suspension arms.Now i have to find me some of those Robinson Racing 8172 Heavy Duty Slipper and Robinson Racing 8590 Heavy Duty Diff Gears.
Thanks for the information, now i know whats next to be done with my maxx.
Old 08-04-2007 | 07:08 AM
  #58
milenko_76's Avatar
I have all those upgrades also. I took off the robinson slipper because I didn't care fot it. Maybe I'll give it another go with the lipos
Old 08-04-2007 | 10:52 PM
  #59
roadkill's Avatar
Default steering ?'s
hi, I would like to know if you plp are runing a spring loaded servo saver on your maxx's? I just got a jr 9000t servo installed,and the servo saver spring is to week to turn the tires,sitting still, so i was wondering what you guys use, and where to get it from. thanx
roadkill is offline
Old 08-04-2007 | 11:04 PM
  #60
milenko_76's Avatar
this is the one I'm using.
http://www2.towerhobbies.com/cgi-bin...&I=LXS361&P=ML
It can turn the wheels standing still but not full throw.
