Brushless Emaxx FLM Build/ Advice Thread
#121
i did see a guy dye a white set with rit dye and they look pretty good. it doesnt give you the real glossy black but still probably better than painting
#122
The ruluxs are only available in white and yellow. I've seen the white ones dyed black and they look sick.
Follow this link there are dyed rulux's and also black maximizers. Both are good choices.
http://traxxas.com/forums/showthread...ons-For-E-revo
#123
i saw those maximizers in the tower hobbies book tonight, i like those a lot as well
#124
I couldnt find the white ones or off-set ruluxs anywhere and didnt think I would like the yellow ones untill I put them on my truck with the black embe body.
#125
I ALWAYS seem to learn the hard way, make sure you lock-tite the screws holding the bulks together. Mine backed out a little bit and allowed the bulk to pull apart a little but under hard acceleration so it looks like I blew up my rear diff. Hopefully its just a bearing.
#126
Mustang your truck looks great On the yellow wheels and I have been loctiting every bolt I have installed.
#127
loctite is definitely us metal guys friends
#128
you got that right, i can just see this thing zipping across the yard with parts flying off lol
#129
still no parts, actually ordered my diff shims again from another company that is closer thinking they would come in before the original set i ordered but no such luck as of yet. Hopefully they come in tomorrow so i can get the diffs done and then the other parts should be here monday
#130
may i ask where you purchased your shims?
#131
One set from waldorf Rc on eBay and the other from rcplanet
#132
thanks was just curious.
#133
Yep, I blue loctite everything and usually wait about 2-3 days before running it so the loctite cures 100%. Also, dremel some slots on your wheel nuts so they bite your rims better and don't back off. If they come loose under power you'll strip the wheel hexes in no time. And never pee into the wind.
#134
#135
Finally santa the mailman delivered a decent amount of parts so i can get some work done. Got most of my parts in still waiting on shock towers and shocks but that should be it, Here are some pics of the progress
parts shipment tekno carriers, skids, gens ace batteris,shims,arms, etc
i had already ordered a side mmotor mount but wasnt sure if i wanted to use it for bashing but i went ahead and threw it on. If i dont like the way it jumps i will swap it out.
and a pic of the total progress for tonight. It was a pain getting the bulks to set flush had to file down the chassis and the bulkheads a little to get a nice tight fit.
