Thunder Tiger MT4 G3 Video
#346
http://forums.wondertiger.com/viewtopic.php?f=5&t=529
#347
Gens Ace 5s 5300mah 30C
Has anyone tried the Gens Ace 5s 5300mah 30C in their MT4 as I am wondering how well it fits? I have compared the dimensions of the Gens Ace against that of the battery tray and it is very borderline. The other potential issue with the Gens Ace is the positioning of the balance and charge cables on opposite sides of the battery. Option B would be the Turnigy 5s 3000mah 30C packs but I have had good experiences with the Gens Ace batteries and would prefer to stick with them if possible.
#348
Going to be picking one of these up in the next month to have as a second basher with my flm emaxx. Are there any spare parts that I should buy to keep on hand. Nothing worse then a day of bashing ruined by some stupid two dollar part.
#349
- all hinge pins (get digidem's replacements)
- body post mounts
- body posts (get digidem's replacements)
- rear arms
- front knuckles
- rear axle carriers
- body shells
#350
The most easily breakable hinge pins are the rear 3mm ones with the flat spot.
Arms , knuckles, and axle carriers do not break that easily, but if your going to bash really hard it wouldn't hurt to pick up some spares.
My body posts eventually broke but not as quickly as others...all depends how often you land upside down off of jumps
#351
Alright thanks fellows. I cant wait to pick this up for another basher.
#352
Hi guys i`m from Germany sorry for my english.
I have a question about running 5s lipo with Mamba Monster ESC and 2200KV Castle Motor i hope you can help me.
Can i run the system with 2 lipos in series one 2s and one 3s lipo?
Both are 4000mah 30c from same factory.
I mailed to Castle but they don`t answer.
Thanks!
Thanks!
#354
Thanks,i have series adapter cable.
But i don`t won`t to burn my Mamba ESC.
#355
I would use a heavier gauge cable than the traxxas series connector. Is that what you have? They are meant for 1/16 toys with mini lipos.
This is what I use
http://www3.towerhobbies.com/cgi-bin...&I=LXYHX5&P=SM
This is what I use
#357
Itīs an Robitronic Hurricane the wires are already on the esc (series) 10 and 12 gauge.
Iīn my MT4 G3 i use one 5s pack but in the Hurricane i have 2 battery slots so i need 2 batteries my problem is 4s is a little bit to slow and 6s too much.
5s well be perfect i think,also in the MT4.
Iīm only scared tu burn my castle esc with two different packs.
#359
Ok thanks for you answer then i will try it too.
#360
Wires
I Bought one TT MT4-G3 but didnīt receive yet...
I would like to know if we really need that large wires from the motor to esc. COuld I shorten thatīs wires. I has a RC8Te that was powered by Tekin T8 and RX8, and since I make the conection, the wires was realy short...that would be fine if I cut the motor/ ESC wires?
Thank you
Thank you
