Thunder Tiger MT4 G3 Video
#361
Yea cut em, they can be real short on this setup
#362
I Bought one TT MT4-G3 but didnīt receive yet...
I would like to know if we really need that large wires from the motor to esc. COuld I shorten thatīs wires. I has a RC8Te that was powered by Tekin T8 and RX8, and since I make the conection, the wires was realy short...that would be fine if I cut the motor/ ESC wires?
Thank you
Thank you
#363
i was referring to the esc wires as well, if there was any confusion
#364
I would not recommend cutting the motor wires. I don't remember offhand, I will try to find the definitive answer, but I want to say the motor wires are part of the windings and you'll affect the kv/timing if you cut them short. I don't see any problem with cutting the ESC wires, if that is what you want to do.
Regards...
#365
I got mine...one more!
Hi...I test my MT4 today. It is amazing car...I always had truggys and this car really looks like a truggy with esteroids...
I try the original setup with 50 x 12t rate and try too a 15t pinion with the 50t spur. The car is só fast with 50x15t and still with a great punch. Is safe to use this rate 50x15t with the original combo? I am using 2 x 2s nanotech 5300mah 60C hard case...means 4s and it is enought for sure!!!
Best regards
Ivan
Best regards
Ivan
#366
well, crazy to say...im really interested in one now..after seeing some reviews and the durability on it..
#367
is this truck worth it?
#368
This is my favorite truck, and i just got done building a flm emaxx. the mt4 is lighter, handles great with a better servo and just rips. Stock servo will get you by but that would definitely be one of my first upgrades, and luckily the only real upgrade you would even need.
#370
#371
#372
Hey guys! I'm about to pull the trigger on one of these babies! Can someone tell me the maximum battery dimensions that will fit so I can purchase ahead of time? I wanna be ready when this beast hits the doorstep!
Cheers!
Cheers!
#374
47mm from top of chassis to bottom of top chassis cage. 53mm wide. 141mm length . There is a little built in molded plastic spacer that if was grounded away would make the length 150mm. You would be fight the angled corner though.
#375
Anyways, I just picked up my new baby today and.... what a fricken BEAST!!! This thing looks like it wants to stomp some!! I can already see others fleeing before my glorious onset when I alight upon the field with this monster mwahahahahaa!!!
Ok, phew! Anyways before I actually run this thing here's my planned changes.
- Change that awful body! Pro-Line F-650 PRO319600 to add some mean truck looks.
- Futaba R203GF 3 Channel receiver so I can use my 4PL. Will flog off the kit RX/TX set.
- Get rid of the token servo and fit a Hitec HS-7954SH running off a CCBEC at 7.4V for 403oz/in and 0.12 sec.
Can't wait!
