Thunder Tiger MT4 G3 Video
#331
If you guys are looking for tires and wheels that fit the MT4 here's some info
http://forums.wondertiger.com/viewfo...97d18ce1827668
http://forums.wondertiger.com/viewtopic.php?f=5&t=146
#332
Loving this truck, have bust a couple of hinge pins, but is holding up pretty well part from that
#333
Anyone else been cranking down servo saver spring to get more out of stock servo?
#334
Just about to put a 7955TG in mine now. As far as I know I should not need a bec to run it, just will be a little under power ratings with the built in bec in the ace esc. I think thats 5.75v and 3a... I would think you only need an external bec if you want to run a hv savox or something like that right?
#335
Took it for a spin again last night, and lost a hex pin. No biggy, just a pain to end a day!
What does anyone else here use as a retainer for it? Does anyone use a ziptie, or maybe even Rc8be uni c clips?
#336
Thanks Latufu. Got it in last night and only tried it in the house but seems plenty strong.
I am using o-rings also to keep the pins in! Works great.
#338
Stock servo just doesn't cut it, my buddy and I put in a Sanwa SDX-901 Servo instead, now it goes in the direction we steer. Here are the specs:
Torque -
4.8V: 319.4 oz-in (23.00 kg-cm)
6.0V: 402.7 oz-in (29.00 kg-cm)
Speed -
4.8V: 0.19 sec/60°
6.0V: 0.19 sec/60°
Weight: 2.33 oz (66.0 g)
The slightly heavier servo also helps keep the front end down more I feel. Here's a short clip of it on 4S Lipos:
Torque -
Speed -
4.8V: 0.19 sec/60°
6.0V: 0.19 sec/60°
+ YouTube Video | |
#341
There's more:
#343
^Those two bodies look great on this truck ,nice paint job.
#344
I don't care that much, because electric is not really my thing, but some of you MT4 people might be interested.. New TT truggy:
http://www.thundertiger-europe-shop....au_ifhss+.html
Looks like an ST-1 update more or less..
TT also is using the MTA4 platform to make a 2-speed nitro SC truck, and is also coming out with a 1/8 brushless rally car...
#345
I see using parts from that to convert mine into the ST4 g3! I like the truggy look. I am interested in the rally car too, can't wait to see that.
