T/E Maxx Thread
#557
After 25+ years of RC racing I must confess to having turned up my nose at monster trucks. THEN I drove an E-maxx on our test track out back and was absolutely amazed at how well the stock E-maxx drove with no "dialing-in" at all. In fact it wasn't even really aligned all that well.
So...I picked up a E-Maxx as my first to be my first MT (followed quickly by a Tekno-converted Revo Platinum...my racing buddies think I've lost my mind) and have a couple questions.
First: the two-speed transmission. Is this intended to be used "select speed or select torque and go" or is it actually intended to be shifted "on-the-fly"? Believe it or not, the manual does not address the use of the transmission at all. Period. Points it out in the "familiarization panel" early on, but no mention of it at all in the operating instructions.
Second: the stock steering servo seems pretty hopeless. The manual describes the fact that the zero scrub radius suspension doesn't allow the steering servo to operate the wheels when standing still, but it doesn't seem to want to center up very well even when driving. What seems to be a minimum torque rating that works acceptably. The stock servo does not strike me as acceptable.
Thanks all,
Scottrik
Thanks all,
Scottrik
#558
Thanks all,
Scottrik
Thanks all,
Scottrik
#560
Just got my first rc vehicle a new emax 5 days ago.
Pretty cool for ready to go out of the box.
Had a couple of days in the back yard just getting used to things then on Fri tried opening up the throttle on beginner mode and bam, hit a tree head on.
Broke the bumper, lower control arm and pin.
Picked up some RPM replacement parts and aluminum bulkheads and spent the afternoon installing them.
Took the truck out to a park with lots of wide open space and let her go on training mode.
Whoa lots of fun.
Then put it on regular mode, scary fast, powered turns on 2 wheels, just crazy.
This is one fun truck. Just glad I did not get something from Wallmart!!!!
Whoa lots of fun.
#561
#562
i have a tmaxx i got two days ago it ran fine but went to take it out to day started up fine gave it gas and it we about 5 feet and the motor reved real high i shut it off now i have nothing even the ez start doesnt work its a 3.3
#563
Will newer bulkheads fit older trucks. I have an emaxx with black chassis and broken rear bulheads. I have stock bulkheads from a new mamba emaxx when i upgraded it i saved the factory ones. Will they work on the older emaxx?
#564
Thanks all,
Scottrik
Thanks all,
Scottrik
#2: I use a Savox 1256TG (277oz/in) servo for steering, and my E-Maxx wears Trencher-X tires on Desperado rims. It won't turn them on pavement, but it steers great while it's moving, even very slowly. The tires are just too sticky.
#565
And I don't recall them changing anything about the bulkheads other than the color with the 3.3 trucks. I've swapped them between older and newer trucks without any issues.
#566
Wow, I just realized I never posted my truck in here.
Full photo album here http://s443.photobucket.com/albums/q...0Maxx%20build/
Build thread here http://www.rctech.net/forum/monster-...-e-maxxes.html
#568
Hi, I'm remotoring my 3905. Current setup is CC Mamba Max with a Feigao 10l@ 13.2 volts. Runs OK. I have on hand a Novak HV Pro(with fan) and a 4.5 HV motor. What pinion should I run with a 68T spur @ 13.2 volts. Novak recommends a 12T, but I believe that's @14.8-16.8 volts. I'm well aware of potential heat issues. Thanks, Don
#569
I bought one back in may and loved it. Espicially how big it is and how it goes over anything with some punch. It was a 3903. I upgraded it a lot then sold it. WHAT A TERRIBLE MISTAKE. I missed it a lot. So from august until hopefully by spring or sooner, I should have my 3908 build done. So far I have trencher x's mounted on 1/2 offset desperado's, ACNCM aluminum bulk heads, RPM true track. RPM front a arms, RC Screws stainless steal kit, and i bought a stock screw kit also.
#570
Has anyone had a problem breaking shock towers??? I just took my emaxx to the local BMX track and the shock tower broke on a hard landing. Should I get the hardcore aluminum ones? I really wanted to get the proline suspension kit...but those towers are plasitic and i wont get it if the shock towers break all the time...
