Axial Scorpion AX-10 Thread!!!
ive so far had problems with shock caps coming off , shocks leaking , and front driveshaft popping off at front of the tranmission case. im running a novak rooster crawler speed control and a 55t integy.
as far as shock caps go , put the red o-ring up inside of cap, do not slide it down over shock body, the instructions arent real clear on this.i did this to mine yesterday and 3 or 4 battery packs later i havent popped a cap yet , they still seem a lil damp with shock oil but not nearly as bad as before, not sure how to keep these 100% leak free. definetly made an improvement.
as far as he driveshaft i tried a zip tie around where the 2 pieces connected, help a little but still popped, so i took the smaller shock spacer that fits the shock body and it fits the shaft perfect!!!! i put it in place and used a little medium ca glue to keep it in place . ive ran 5 or 6 packs on this mod and havent popped a shaft since .
http://www.youtube.com/watch?v=rCCelrjeEns
This was the ax-10's first run, since this run, I have swaped to a e-flite 1500mah 2/3 pack on the front axle, gone to a mamba max esc, added weight to the wheels,starcut the foams, and changed radios. It is now a completley different driving machine!!
oops, double post
Got the SLAMMED BETTY mounted up now instead of the crt5 bod
Slammed Betty action shots!
hit the rocks for the first time with mine yesterday, i was the only 2.2 crawler there but i had a blast and it did fairly well , other than some added weight it was basically box stock.
after watching what it was doing on the rocks i came up with a few ideas of what it needed so i did some research when i got home , i ended up removing the spacers from the outside of the shock and puting them inside under the piston lowereing the chassis and making it more stable. i also notched the skid plate and moved the lower links in towards the center more, im basically doing the stage 2 kit , by the end of the week i should have all my parts to complete it other than the upper link extensions and the 30 degree lower links (both on backorder), ill also have my 4 link setup and my battery plates for the front axle from the crawler store by mid week. ill be looking forward to see the improvments, next will be a set of losi rock crawler tires.
Registered User
I took mine out to Mount Rainier this week, ran it through some great rocks, some snow and had a good first real run on it. This is pretty good.
Mine is setup 60/40, stock suspension, brood 35x1 motor, dual steering, stock tires/foam cut into a star..works really well, I want to make some minor suspension adjustments but I'm pretty happy with it out of the box. I am amazed at some of the stuff it can get through.
Pics attached..
Pics attached..
