Axial Scorpion AX-10 Thread!!!
#91
heres a second pic of "edge 1"
#92
and here's a pic of my ax10 "basher"....
#94
My comp crawler was performing pretty good, but after this weekend's GTG I saw some thing that might be able it help it get over the rocks easier.
I got home, began taking it apart, and cleaned it up.
The 1st thing I changed was the shock setup. I used Losi White springs in the front with 25wt shock oil and Losi Yellow springs in the rear with 45wt shock oil.
Next to go was the Hitec HS-645MG steering servo. It got the job done but demanding crawlers like myself need the best. I swapped it out with a Hitec HS-5955TG servo.
I shrunk a Spektrum receiver and called it a night.
There is still a lot of things to do. Stay tuned.
#95
hey guys quick question. Are the only differences with the RTR and the ARTR the linkage and the slipper? Is the slipper better for competition? thanks
#97
UPDATE!
Axial Racing AX10 Scorpion screw kits are now in stock!
Axial Racing AX10 Scorpion 237-piece high grade 12.9 alloy steel socket head screw kit. Kit includes all applicable cap, flat and button head screws, as well as nuts, washers, and set screws.
Thanks and best regards,
#99
FLM SPV2 - Axial Chassis
Here is a little something I designed and licensed to FLM - it's a direct bolt up for the AX10. FLM is making them now.
Since I figured I should have a final production SPV2-81 version showing up after all the initial orders are filled, I pulled off the test chassis and dropped on a the last SPv2-81 prototype and snapped a couple more picks. Then gave it a good thrashing. Enjoy the poser pics.
I omitted side body panel for this build. For comps you don't need all the extra top body panels, just a hood, roof, and side panels, but I though it would look cool.
The paint by the way, I did just by laying door screen down, misting with black then following with red then backed in white - not a bad carbon fiber fake.
