Motor replacement help
My son has a Traxxas Stampede 2x4. I put the Traxxas Velineon brushless system in it a couple years ago. After some upgraded driveshafts everything has worked pretty well. I guess he has taken the waterproof thing a little too far and ruined the motor. My question is, what size is that Velineon 3500 motor? The replacement from Traxxas is $99. I’m pretty sure I can get something from Tower or Horizon for much less. I just don’t know what to look for.
Thanks, Micah
Thanks, Micah
The only "size" that fits in a 1/10 scale rc car is a 540 motor. Thats just the length of the can in cm.
Any 1/10 brushless motor will work as long as the turn limit matches the esc. So what were talking about here is turn or kv? Is that what you mean?
The Traxxas Stampede 2x4 most likely came with a Traxxas Titan 12t 550 brushed motor. That motor can be found on numerous Traxxas vehicles with brushed motors including the 2wd Slash and the 4wd 1/10 scale 4-Tec 2.0 on-road vehicle.
The number you see most often on brushless motors is the KV rating of the motor or how much power the motor has. Please refer to page #10 of this .pdf from Traxxas that list the specs for the Velineon 3500 motor.
https://traxxas.com/sites/default/fi...X_manual_0.pdf
Here are some basic specs if you don't have the ability to view the pdf file...
Velineon 3500 motor
- Sensorless
- RPM/Volt: 3500 (10-turn)
- Max RPM: 50,000
- Diameter: 36mm (540 size)
- Length: 55mm
Hope this info helps.
Velineon 3500 motor
- Sensorless
- Max RPM: 50,000
- Length: 55mm
2Likes
