Atomic RC AMZ MiniZ Brushless 4wd Competitor
#76
I broke the stock digital servo. So I replaced it with this one from Hobbyking- http://www.hobbyking.com/hobbyking/s...5kg_0_06s.html
It's a little bit bigger than the stock servo. You have to cut off the mounting arms on the servo and then it fits perfectly into the car. However, you have to use double sided tape and can't use the stock servo mount with this servo.
As far as performance, it seems just as fast and centers better than the stock servo! I've had it for a couple months and it's holding up very well. It's still slop free like new and centers well. Best of all, it's $5!
#77
Hi
How is the car holding up?..........are anymore upgrades needed do you think?
#78
The stock servo isn't a digital version is it?
#80
#81
Actually the stock servo in the "export" or "international" version is indeed a digital servo. This is the version of the kit that I have and it also comes with the aluminum esc instead of the all-in-one esc receiver unit.
http://shop.tinyrc.com/product.php?p...1&cat=0&page=4
The car is holding up very well.
#82
Mine wasn't, didn't know there was multiple versions. So, it depends on what version you have. I didn't get the fancy esc either. lol
MrU, your link doesn't work but, if your rx uses that little plug you're golden with the Atomic servos.
The car is doing great for us. We have 60-70 hours of run time with no complaints. Next race day we add an AMR into the mix of AMZ cars.
#83
I bought a RTR so the servo is not a digital I suppose. I bought myself the alu esc and receiver to uae with my EX1.
#84
There are three versions of the AMZ 4wd. You can get the RTR which comes with the regular servo, plastic esc/receiver, and transmitter. The kit which comes with the regular servo, plastic esc/receiver, and no transmitter. Or the export version kit (the one I have) which comes with the digital plastic gear servo, metal esc only (no receiver function), and no transmitter.
#85
Thanks............yes I have the export version also,with metal esc.......will be building it this week.....just need to buy the metal motor mount etc
#86
does anyone know if other esc program cards work with the alum esc or does it have to be the atomic model that they sell?
#87
just letting you all know we are running the amz at the track here in Rhode Island link to site http://www.b-rsuperspeedway.mynetworksolutions.com/ take a look still run the mini-z and the mini-z f1
#88
A user has posted a picture of the AMZ settings here:
http://mini-zracer.com/forums/showth...t=39350&page=8
Need to register to see the attachment. Using the picture as a reference, you can program with the standard Hobbywing LED program box.
I know you asked specifically about the aluminum ESC. This is just my experience on the RTR version ESC, but I expect it should be the same.
edit: I should also add, the behaviour is all the same as a 1:10 EZRun ESC, so you can set throttle endpoints, and fully program the ESC using the onboard button with the beeps and blinks, again using the picture of the program card as a reference.
#89
AMZ
I have a fully built nevr ran AMZ awd. I have all titanium screws, aluminum motor mount, aluminum shock towers, floating servo mount with digital airtronics servo with 2 new lexan bodies 1 painted one NIB with spares. Just add RX and speedo. PM if interested and I can send pics.
#90
gctkaz..........do you know the settings on the alloy atomic esc..?..ie 1= forward brake 2= lipo cutoff 3= drag brake etc.....as I have the LED hobbywing programme card..it works but it has more settings than the esc,and they seem to be out of order as the settings on the esc...
Thanks simon
Thanks simon
