Team Associated SC18....
#91
Suspended
Funny!
But if we're talking comparative scales and the corresponding differences in speed between them, since 1/18th out of the box aren't as fast as 1/10th, it seems as if you're trying to blur the lines of reality.
Did your light blow out?
#92
#93
Its more of a speed/power to weight ratio...If you run a mini-t at the same scale speeds as a xxx-t it should handle close to the same - setup ability of a 1/10 (shocks and fluids) Try a mini-t on a prepped track with holeshot style tires and it will run good...
#97
Just got my January 2010 issue of RC Driver in the mail and Tony P. has a preview article on the SC18 and some better pictures. About the only real specs he included were that the chasis is 15mm longer.
When can I get one of these! Just like the first 18T, I can't wait!
#104
SC18 WB = 166mm (per RCCA)
Detta SC WB = 185mm
1/16 Slash WB = 206mm
SC18 Width = 143mm (per RCCA)
Detta SC W = 168mm
1/16 Slash = 185mm
Looks like we'll have 3 quite differently sized trucks.
