Kyosho Mini-Z Series
#1171
It does to an extent. When I put tires on I usually spin the tire slowly to find any imbalance. I make sure it's even left to right. If the tire is bulky I usually pinch the tire and spin the wheel about four or five time. It helps even out the tire.
#1176
just got a mr03ve pro. is there a reverse delay?? trying to go reverse is a little unresponsive unless i nudge the forward a little and immediately punch back to reverse. is this a known thing?
#1178
Hi guys, looking for a mini-z module for my Ko propo EX-1
Let me know where I can fine one?
Martin
Martin
#1179
Yes. You can program it out using ics. I have some bluetooth ics boards for sale, pm me for details. The bluetooth programers require an Android device with bluetooth and an app from the play store.
#1180
Hi guys, what a good siz for a mini-z buggy track?
Martin
Martin
#1181
What's the difference between all the Mini-Z chassis out today?
And the best place for Canadians to buy them? I might have to buy a radio too, I don't think my 4pks would work with one.. but I might be wrong..? (Just started reading about them).
#1182
PLEASE HELP my mini-z MR-03VE Pro + EX-6 transmitter brought new 2days old wont go straight, the wheel sway more to the right side, it just wont go straight unless i set the steering trim to L5, if i change the steering trim to 0 which is suppose to be going straight but instead it just lean to right.. if i set steering trim to L5, then the car go perfectly straight. what is the problem behind? does the wheel misalign? should buy new set of wheel to solve? or is it the servo motor problem? please help!! thanks for your time.
#1183
#1184
#1185
i got a set of MR-03VE PRO and 82030 EX-6 MHS / ASF transmitter for sale. $248 each (not include shipment cost). NEW UNIT.
