Kyosho Mini-Z Series
#1127
They quicken the steering reaction of the car quite a bit on parts of the track that has S turns and 180's it very noticeable. Still working on a good basic setup but it's fun to drive. 50t motor is so fast could never imagine how people can drive the hotter 32t motors.
#1129
Looking for some track advice, I am planning on a semi permanent rc track in my basement. I plan to use 9 sheets of 4x8x3/4 of OSB T&G (smooth side up), screwed together with 1x4 under, and spaced around to raise the OSB up a little from the concrete floor, and then using spray glue and asphalt tar paper as a racing surface, and old garden hose to line the track layout. Has anyone tried this? I don't mind TOO much grip, id rather that than too little, as id like to use the rwd cars.
http://www.homedepot.ca/product/vapo...eathing/917439
#1131
Yep something like this -
http://www.homedepot.com/p/Warrior-R...14-0/100086691
After the quick test I did on the track, the grip is great. Should make for some good racing. I decided not to glue down the surface, instead using some 2x2 with t nuts and bolts, I will clamp down the surface at each end of the track. Now that the garage is almost complete (new house etc) Ill be back to completing the basement track soon.
#1132
On my MR03VE, I have to use brakes often as the LM (TS020 body) just keeps coasting freely and not much steering without braking. It's quite fun though.
#1133
#1135
I hope to get a 4WD one later this winter to try (right now got too many m-chassis projects I want to complete).
#1136
I see. GL on finishing the MiniZ track. There cars are so fun to drive, and the body detail is exactly where I want them to be for all my RC cars. I too have a MicroRS4, but thing is in the back of the shelf right now just taking a nap as the MiniZ's were so much better than I imagined, even the MR03-Sport trim.
#1137
#1138
#1139
Rubber. the one car I tested on it had some good understeer, rear was stuck, and they seem to be atomic rubber tires. unsure of what shore. But considering the grip level, I don't think you will be unhappy with any rubber tire on this surface. But as others have said, you have to keep it relatively clean.
#1140
R/C Tech Elite Member
It took me a couple months to get mine. I found the first one, a wide oval, in a forum classified for $75 shipped, then found another oval on ebay about a month and a half later for the same price. During that time I checked ebay, craigslist, and all the major forum for sale listings several times a day. They do pop up, but if it's a good deal they disappear just as quickly.
This is a pretty good deal for getting started. I'll be adding one of these to my collection soon.
http://www.minizrcstore.com/Wide-L-c...-Kit_p_15.html
With that wide L and my current RCP I'll be able to make some pretty big layouts.
so i ordered the wide L set from the minizrcstore, cant wait for it to get here! this is by far the best deal ive seen for them it was on sale $189 no tax and free shipping on my order! just the savings in shipping is awsome! if it comes thru as ordered ill let you know.
