Kyosho Mini-Z Series
#377
#378
Have anybody seen the swedish open car Pro-27 ?
here´s mine with mr02 electronics:
(sorry for the bad picture)
#379
When is the new 2.4 coming out?? does anyone know??
#381
#382
#383
Checking kyoshousa.com it says the new 2.4ghz car and system is shipping.
anyone seen one of these on a track yet?
#384
We raced them and the control and the glitch free operation is superb....
The controller is pretty kool too.....you willhear stories about reverse being hard to findbut if you read the instructions and set up your throttle trim you will have no problems....
The lemans bodies are weak....i reinforced mine wsome gussets and glue...
Now we are all running autoscale 94 and 98 mm bodies...
All I can say is if you get one you will be very happy.....
#385
Can you post some photos?
It sounds great!!
How's the speed, say compared to an Xray M18?
It sounds great!!
#386
Hello today I ran my MR02 and it was good but we run a pretty small track that is RCP and has lots of 180s. I was wondering if somebody could post a really good set up that has lots of steering. If you could please tell me
-mid or rear motor
-front rims?
-front tires?
-rear rims?
-rear tires?
-Dampner disc?
-rear side shocks?
-rear shock?
-body?
-front springs?
-rear shock spring?
-Medal front end?
-caster?
-what motor?
-and so on
Bryan AKA Hollywood
-mid or rear motor
-front rims?
-front tires?
-rear rims?
-rear tires?
-Dampner disc?
-rear side shocks?
-rear shock?
-body?
-front springs?
-rear shock spring?
-Medal front end?
-caster?
-what motor?
-and so on
Bryan AKA Hollywood
#387
This was the set-up I won the Atomic West Coast Championships with:
http://www.reflexracing.net/images/S...ace%20Cali.pdf
Check out our shop for the replica package. Might save you some serious $$$ Our addy is www.reflexracing.net
#388
hi bryan...
first thing i would do is to dump the stock tires and get good soft tires... this is usually the most overlooked thing... and is the cheapest to replace too...
good tires will definitely give you good traction....
if you don't have good tires, it won't make any sense if you hopped up your car with all the parts you can find... you won't be able to put all that power down... so go with tire selection first...
experiment with different makes... atomic, pn, kyosho... usually this will do the trick, and solve your spinouts...
if you want some steering, i would suggest getting steering knuckles with some camber in them... either 1degree or 2degree...
from there you can decide whether you want to spend some more on other parts...
you can have real fun with just the bare basic hop ups... in one car, i've changed the tires, got bearings, and changed the h-plate to carbon fiber...
and that's it...
it all depends on what you want to do... (oh yeah don't and don't forget to have while you're doing it)
hope this helps...
for tons of tips, visit
http://www.mini-zracer.com/forums/
#389
Hey Tim, do you know if the Dnano's are going to make it to the US? Also, any more information about the lap counting system they use (new version of CORE?).
#390
some of my pics
ill start with my awd MA-010
0deg offset atomic front dish rims
20deg atomic slick r tyres f
3deg offset atomic rear dish rims pn racing 8deg rcp tyres
pn racing 1.5deg knuckles with re-lubed atomic bearings
pn racing green springs,gpm .6mm ride hight limiters and atomic .3mm spring tensioners
pn racing shock mount
atomic ball diffs(plastic)with tungsten balls,thrust bearing setup and delrin gears
atomic ceramic diff bearings
atomic precision servo gear set
atomic 98mm ti shaft running on ceramic centre bearings
pn racing shaft holders
atomic 98mm 31t spur
pn laydown xtal adapter
pn 98mm rear end yellow kyosho springs,2deg knuckles,2deg toe
kyosho rear driveshaft bearings(wider)stripped and re-lubed
atomic alloy driveshafts
3racing alloy motor cage and holders
atomic 15t alloy pinion
atomic ariel kit
atomic ti screwset
hfay MR-02
spanking new chassis,topdeck kit and board
atm ariel kit
atm corvette c5r alu clip
tagu tower bar 1.5deg camber .5 castor
atm -2 deg tierod(giving +1 with tower bar)
atm precision servo gears
atm blue springs
atm 0deg knuckles
atm stainles kingpins
atm limiter kit
atm ti screwset
atm ssg s soft h plate
atm 94mm dd
atm red dd springs
pn racing dd discs
atm 2.5mm dps mount
atm mono shock
atm ver5 94mm mount
atm ball diff
atm ceramic balls
atm noise cap
atm hfay season 5 motor
open class MR-02
ad band
ver5 98mm
stock r motor = rapido!!!
1deg atm knuckles
tagu .5 castor 1.5 camber top bar
orange atm springs
atm stainless pins
atm -1deg tierod
3deg rear 0deg front rims
atm ti screws
atm dd with green tuning springs
atomic ariel kit
atomic ti screwset
hfay MR-02
atm ariel kit
atm blue springs
atm 0deg knuckles
atm limiter kit
atm ti screwset
atm 94mm dd
atm red dd springs
pn racing dd discs
atm 2.5mm dps mount
atm mono shock
atm ver5 94mm mount
atm ball diff
atm ceramic balls
atm noise cap
open class MR-02
ad band
ver5 98mm
1deg atm knuckles
orange atm springs
atm stainless pins
atm -1deg tierod
atm ti screws
