Kyosho Mini-Z Series
#4937
with that said, if you want to give it a shot, go for it! Wire the servo up the same as the one you pull the controller, if it doesn't center and pulls away from center, then flip polarity on the motor.
#4938
Mini-ZRacer.com Forums - View Single Post - McLaren MP4-12C body - 3D printed reinforcements
#4939
I've uploaded the .STL files for the 3D printed parts in this post here:
#4941
#4942
I still have about 40 of them.
#4943
Has anyone used these with easy laps system? Our group is switching to EasyLaps. With the Jomurema using a regular receiver, this would plug in.
#4944
my recommendation would be to stick with the original one. It has a connector PCB side so you can use one transponder and swap it between cars. It comes with the correct JST plug for micro receivers as well. This one looks hard wired, so not easy to swap unless you add connectors.
#4945
I get why, sort of, they decided to make the switch. Been mixed on reaction. For those like me that know chances of running outside group are slim to none, it’s just money. But for the others that will run 2-3x it makes sense.
#4946
Really?! I'd be curious to see how you did it. Were you a bitPimp back in the day? I did dual cells, FET upgrades, gear mods, chassis extensions, but by the time I got around to proportional steering, I was getting into x-mods and mini-z, and then that proportional Zip Zap came out and was kind of meh.
A Real Life Tinker Gnome: Bit Char-G - Doing research long after it matters. And making a 1/64 scale proportional car.
A Real Life Tinker Gnome: Bit Char-G - Do you like my body?
#4947
slow steering and traction roll
Does anyone have problem with mr03ve's(not pro) steering? My problem is the steering feels so slow that I have to start a turn a tile earlier than I used to. Is there any settings in iCS that I can adjust to solve the issue.
I'm also in the middle of deciding on purchasing a ma020 or 030. I've heard a lot of story of ma020 flipping over on RCP or high traction surface but still want one as 030 seems to have limited wheel base setting.Has anyone had experience with setup a ma020 without heavily modifying suspension? Thanks
#4948
#4949
#4950
Thanks for the feedback. 030 seems to have some teething problems but I hope Kyosho will fix them during the production. For me, the 030's biggest advantage is the brand new electronics and the fact that it came with Kyosho's DWS.
I've missed out on several good deals of 020 , one of which was an open box brushed 020 dws with audi r8 body for $130, instead, I went for the 03ve and found it not so suitable for my living room track. Building one seems to be kinda expensive at the time as there are not many good candidates that meet my requirement (asf board and have most of the frontend chassis parts). In the end, maybe it is a better idea to go for 030....
