CHECK THIS OUT 1/36 Micro-T
#182
Originally Posted by t9dragon
He stripped the paint off the stock body that came with the Micro-T.
oookaay, so how is that done without damaging the lexan??
#183
Trader Rating: 31 (100%+)
hard scrubbing with paint thinner, and i think brake fluid??? If someone can confirm that.
#185
paint thinner will haze the lexan. use denatured acohol or brake fluid. it takes time to get all the paint off and alot of patients.
also here is a link to a video of the track i have in my garage. http://www.youtube.com/watch?v=IM9QXLPiBYY
#186
when using the m18 wheels what pinion should be used?
#187
i would start with the smallest one, since the tires being larger increases rollout.
#189
Originally Posted by micrors4guy
here is my micro t body that i just finished painting this morning.
#190
Has anyone had gleching issues, I sold one to someone on ebay and they said they are having all kinds of problems with it but it worked fine when I had it.
#192
If I remember right when I was chatting with him he used rubbing alcohol.
#193
brake fluid and a toothbrush.....let the brake fluid soak for about 15 min and then start scrubbing with the toothbrush
#194
#195
thanks, I'll try to explain this to him.
