CHECK THIS OUT 1/36 Micro-T
#151
Micro-T hits 64 MPH!!! ......while on the passenger seat of my Corsica on the way home from the hobby shop.
#153
I bought three of these for christmas gifts.The first one was for my nephew who in less than 2 hours managed to break the rear control arm mount(which is on back order everywhere).The second one went to my son.When we put the batteries in the transmitter it was already on and the switch was kind of "funny" but my son got it to shut off we left it alone while the car charged but we noticed that the batterries were leaking out of the transmitter.It was all hot and the battery tray was warped.We tried the transmitter crystal in another radio but it still didn't seem to work.Micro-t number three went to my father in law.His seemed like the gearbox was binding,like the gear mesh was to tight.He also sent my wife an email today that it wasn't charging.Other than that I think the micro -ts are awesome.
#154
My Brushless Micro-T lives!
I've been working on a Brushless Micro-T and today I drove it for the first time.
I have everything but my LiPo packs so I had to try it on the 4 cell nimh pack.
The Castle Creations PHX-10 controller can drive the truck slower then the stock speed control. It doesn't cog at all, it does have a very slight ramp up to full power though(I believe its the 4 volt LVC in the controller), keeps it from doing a wheelie - with the nimh pack anyway, based on the speed and torque it will be wheelie city with the LiPo pack. I am using the medium pinion gear, its obvious I can goto the largest pinion. The body fits with no rubbing, no sign of the motor warming up. The ESC is forward only and brakes when in the neutral setting so I disabled the brake, the slight drag of the gearbox and motor seems to be fine, I may add a slightly delayed light brake when I can fine tune it with the LiPo's.
Once again peace has been restored in the RC world, all of my cars are brushless powered!!! Now where are my LiPo's !!!
Equipment used:
Micro-T with ball bearing upgrade
Spektrum SR3500 receiver
Castle Creations PHX-10 brushless ESC
Feigao LPS 5250 brushless motor - 12x22mm 5250kv
Deans micro connectors
4 cell Nimh pack at the moment, soon to be a 2 cell 250ma 20C LiPo
I'll be doing a scale dragrace between a stock Micro-T and the brushless version once the LiPo's arrive. I have access to a full drag system including a 6 inch tree.
I will also post the weight differences between stock and brushless/LiPo, as well as the runtime differences.
Equipment used:
#155
With the body:
#156
good job TheSteve.. I was doing the same thing, I just didn't know where to buy the LiPo's.
Equipment used:
Equipment used:
#157
so i flipped the wheels around, not only does it look much cooler but it steers and handels 100% better with the wider track!!!!!!
#160
Originally Posted by t9dragon
Do you have any pics?
#161
Foam Tires
Originally Posted by geeunit1014
a few upgrades i have seen people do at my local track:
1. taking springs for radioschak xmods trucks, and cutting them down to fit the micro t. works very well, lowers and stiffens the truck.
2. if you race on carpet, the m18 foam tires fit right over the stock wheels
#162
Equipment used:
drift,
#163
will the hitec hs50 servo fit better than the 55 since the 55 has to be trimmed?
