Like Tree9Likes
Micro RS4 Thread
Old 08-29-2012 | 08:17 PM
  #391
Rapid Roy's Avatar
Originally Posted by cs3087
My rubber tires just slide I need to buy a roller for parts or a parts lot
I used to use those for front and rear. They gripped so much better then any other rubber tire and I tried all of them.
Rapid Roy is offline
Old 08-29-2012 | 08:22 PM
  #392
1967Typhoon's Avatar
Not sure what you mean here....
He is saying he buys whole cars for the tires, what are you referencing?
1967Typhoon is offline
Old 08-29-2012 | 09:05 PM
  #393
Rapid Roy's Avatar
I'm talking about the grip of the soft wide HPI rubber tires.
Old 08-29-2012 | 09:19 PM
  #394
Oops. Now I see.
Old 08-29-2012 | 10:22 PM
  #395
bigb11's Avatar
ebay or rc mart for tires.
bigb11 is offline
Old 08-30-2012 | 04:04 AM
  #396
cs3087's Avatar
No I'm saying I need to buy a car for parts my bad if I worded that wrong!LOL
cs3087 is offline
Old 08-30-2012 | 05:36 AM
  #397
No tires at either currently. At least no rubber tires.
Old 08-30-2012 | 07:55 AM
  #398
adanmtxt1's Avatar
Tires is one reason I stopped running my MRS4; you literally cannot find consumable parts for this car unless you get lucky on e-bay or buy a roller. Oddly enough you can find wheels! One consideration is M18 rubber tires; they might work but I never tired.
adanmtxt1 is offline
Old 08-30-2012 | 04:32 PM
  #399
Guys, any tips to free up the drivetrain? I have checked bearings, made sure nothing is cranked down too tight, adjusted mesh, and I still have a car that won't roll freely. Do the RS4s have a "tight" drivetrain?
Old 08-30-2012 | 04:48 PM
  #400
Move the motor away from the spur and roll the car across a smooth floor. It should roll freely. If not check bearings,belt-everything. On another note-the xray rubber tires look like they will fit. Part #389640. Don
DLS II is offline
Old 08-30-2012 | 06:19 PM
  #401
cs3087's Avatar
That's weird. I never had that problem it could be
Gear Mesh
New Belt
140mm belt on a 150mm chassis
I'm out of possibilities
cs3087 is offline
Old 08-30-2012 | 06:26 PM
  #402
adanmtxt1's Avatar
Make sure you're running the right belt.
Otherwise, remove the belt and spin the front and rear differentials. If they spin freely before a belt is added but are bound afterward, the belt may have become stiff over the years. You might be able to soak it to make it more flexible.
Old 08-30-2012 | 06:38 PM
  #403
Went over the car. It's the front diff. Trying to loosen it up now. It's the stock front diff and it is currently very notchy.
It also looks like the front pulley is clogged up with gunk. Going to clean that all out. Can't wait to give this car a whirl! Pieced one together with a 2S lipo, HPI mod brushed motor, Hitec MG mini servo, LRP speedo, and a receiver for my FSGT3B for $85 total. Just waiting on the speedo!
EDIT - This damn front diff is too tight because the diff collar (diff frame) crushes it closed! Trying to figure out how to make this not happen. Seems to me I am out of luck. Not sure why they would have designed the front diff to be so tight on the RTR. Maybe mine is just out of tolerance. Who knows.
EDIT 2 - Cleaned it up, got it rolling nicely, and proceeded to plug everything up again with dust/hair in under 15 minutes. Not fun so far. Wasn't impressed with performance either.
EDIT 3 - Picked up a used Losi 1:24 Rally, couldn't be happier.
Old 09-11-2012 | 01:23 PM
  #404
I loved my Micro RS4. It worked well for drifting.
I then got a m18. That is also an amazing micro as well.
Wyumez is offline
Old 09-19-2012 | 01:28 PM
  #405
I'm building a MRS Micro. I know the biggest kit supplied pinion is a 13T. How big a pinion will the stock 180 motor take? I have on hand motor heatsinks if needed. Don
DLS II is offline
