Mini-96 World Challenge
#1261
Class-Pro Stock GT
Date-7/30/21
Location-Winston-Salem, NC
Race Time-319.623
Fastest Lap-4.061
Chassis-MR-03 EVO
Body-Ferrari 458 Italia GT2
Wheelbase-98mm
Tires-K30 radial fronts, Marka V1R10 rears
Motor-Kyosho X-Speed (50T)
Batteries-Kyosho SpeedHouse 800
Front Springs-PN Purple
T-Plate-Kyosho CF Medium
Motor Mount-R246-1355 One Piece Motor Mount
Dampener (If applicable)-Kyosho DDS
Gearing-Kyosho Ball Diff II with 6t pinion
Notes-No changes from last month. Only got a few runs in late in the month, so less than 2 seconds faster than my by best stock car time, but not enough to go sub 5 min this month.
Date-7/30/21
Race Time-319.623
Fastest Lap-4.061
Chassis-MR-03 EVO
Wheelbase-98mm
#1263
Class-Pro Stock
Date-7/31/2021
Location- Elkton MD
Race Time- 334.61
Fastest Lap- 4.02
Chassis-PNR 2.5, EVO board
Body- Jomurema with lexan roof
Wheelbase-98mm
Tires- MZW2-30 , Marka V1R10 rears
Motor- kyosho speed 5600kv BL
Batteries- Orion 900HV
Front Springs- PN Green (PN front end)
T-Plate- wolfram CF #3 (side springs = kyosho yellow, 1 spacer preload)
Motor Mount- MZW309
Dampener MZW310
Dampener Fluid N/A - though there is oil in the shock.
Gearing- 7/44 (stock gear diff and gearing)
Notes: I couldn’t get this car to drive right - then I realized my rear shock was rubbing against the lexan window. I fixed that and it got worlds better but still not great. The diff was gritty… I dropped in the old trusty stock gear diff and the car was ready for a timed run. While this time is a lot slower than my stock time, I’m thrilled that I have the car drivable now. I suspect in the coming months, I will have more to show for this setup.
Date-7/31/2021
Location- Elkton MD
Race Time- 334.61
Fastest Lap- 4.02
Wheelbase-98mm
Motor Mount- MZW309
Dampener MZW310
#1264
Class- Box Stock
Date- 30-Jul-2021
Location- Redondo Beach, CA USA
Race Time- 345.481
Fastest Lap- 4.429
Chassis- Kyosho MR03 RWD
Body- Audi R8 LMS
Wheelbase- 98mm
Tires- (F) Kyosho 30 Deg Slick, (R) PN KS Super Soft Radial
Motor- Kyosho Stock
Batteries- PN 750 mah
Front Springs- PN Orange
T-Plate- PN Carbon 3
Motor Mount- Stock MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- N/A
Gearing- 7T/Stock Diff
Notes: Changed front springs and rear tires from last month.
Date- 30-Jul-2021
Race Time- 345.481
Fastest Lap- 4.429
Body- Audi R8 LMS
Wheelbase- 98mm
Motor- Kyosho Stock
#1265
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hello All,
We had a couple of new/return racers this month, for a total of 6 with some close racing.
Box Stock
1st - ChemNut - 343.9/4.29s
2nd - LuckyLou - 345.5/4.43s
3rd - Traveler - 347.2/4.42s
4th - FastJew - 352.5/4.52s
5th - TomtheGeek - 383.5/4.66s
Porsche Cup
1st - Traveler 344.6/4.22s
2nd - ChemNut - 358.3/4.43s
Stock Class
1st - ChemNut - 317.0/4.00s
2nd - Traveler - 321.4/4.09s
3rd - FastJew - 339.0/4.18s
4th - Cdog4w - 457.4/5.38s
Pro Stock Class
1st - Traveler 319.6/4.06s
2nd - ChemNut - 334.6/4.02s
Open AWD Class
Some really close racing in Box Stock class, with 1st, 2nd and 3rd separated by 2 seconds each and 4th only 5 seconds back. And new guy ChemNut continues to dominate in most of the classes.
FTM goes to ChemNut and his Stock car with a smoking 4.00 fast lap.
Please check my tabulations and let me know if I made any mistakes.
Same layout for August, but running Counter Clockwise. Drive fast!
Cheers,
Traveler2
Hello All,
Box Stock
Porsche Cup
Stock Class
Pro Stock Class
Open AWD Class
Cheers,
Traveler2
#1266
Class-Box Stock
Date-8/31/21
Race Time-350.494
Fastest Lap-4.505
Chassis-MR-03 ASF
Body-McLaren F1 LM
Wheelbase-98mm
Tires-K30LH fronts, Marka V1R10 rears
Motor-Stock
Batteries-TRP 747s
Front Springs-Kyosho Orange
T-Plate-Kyosho Carbon Med
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-Car was 3 seconds slower this month. I swapped out the motor, but it didn't help. Must be me.
Date-8/31/21
Race Time-350.494
Fastest Lap-4.505
Chassis-MR-03 ASF
Body-McLaren F1 LM
Wheelbase-98mm
Motor-Stock
Batteries-TRP 747s
#1268
Class-Stock GT 70T
Date-8/25/2021
Race Time-324.076
Fastest Lap-4.064
Chassis-MR-03 ASF
Body-Ferrari F-430 GT
Wheelbase-94mm
Motor-PN 70T
Batteries-TRP 747s
T-Plate-PN CF #4
Motor Mount-PN 94-98mm v2
Gearing-PN 64p 10/54 Ball diff
Notes-No changes this month, but also 3 seconds slower in this class.
Date-8/25/2021
Race Time-324.076
Fastest Lap-4.064
Chassis-MR-03 ASF
Wheelbase-94mm
Motor-PN 70T
Batteries-TRP 747s
T-Plate-PN CF #4
#1271
August Class-box Stock
Date-08/18/2021
Location- Elkton MD
Race Time- 338.42
Fastest Lap - 4.29
Chassis-MR-03
Body- Audi R8
Tires- PN KS firm front (22.5 mm), Marka V1R10 rears
Motor- box stock
Front Springs- kyosho red
T-Plate- silver PN #4
Motor Mount- MM.
Dampener Box stock
Gearing- 7t
Notes: The only change for this month was the addition of a 1.7mm spacer between the T-plate and the motor pod to lower the chassis to a height of ~1.5-1.7 mm. This did seem to improve my lap times from July despite observing a stronger tendency towards traction roll in the CCW direction (hence the reason for lowering ride heights where possible).
pictures pending…
Date-08/18/2021
Location- Elkton MD
Race Time- 338.42
Fastest Lap - 4.29
Chassis-MR-03
Body- Audi R8
Motor- box stock
Motor Mount- MM.
Dampener Box stock
Gearing- 7t
pictures pending…
#1272
August Class-Stock
Date-08/08/2021
Location- Elkton MD
Race Time- 317.50s
Fastest Lap- 3.93
Wheelbase-98mm
Tires- PN KS firm trimmed to 22.5 mm front, Marka V1R10 rears
Motor- kyosho speed 4100kv BL
T-Plate- wolfram CF #5
Motor Mount- Kyosho MML
Dampener Kyosho CF disk damper.
Gearing- 44/7 PN stock kyosho gear diff.
Notes: changed from the MZ309/310 LM rear pod with side springs to the kyosho aluminum MML pod with CF disk damper. This allowed me to have a lower rear ride height of ~1.5 mm and enabled the use of the more grippy PN firm tires (seemed more grippy than my old MZW2-30’s). The car felt faster and more responsive but the time was nearly identical to last month…
picture pending…
Date-08/08/2021
Location- Elkton MD
Race Time- 317.50s
Fastest Lap- 3.93
Wheelbase-98mm
picture pending…
#1273
Class- August Porsche Cup
Date-08/15/2021
Location- Elkton MD
Race Time-349.26
Fastest Lap-4.33
Chassis-MR-03
Body- Porsche 911 GT3 RSR 2005 No136 Yokohama MZP126AD
Wheelbase-90mm, narrow front
Tires- MZW39-40 front (22.5mm), PN KS medium narrow +2 rears
Motor- PN70T BB
Front Springs- kyosho purple
T-Plate- PN CF #3
Motor Mount- PN reconfigurable mount.
Dampener PN disk damper
Fluid - N/A
Gearing- 8/44 - stock gear diff.
Notes: I didn’t get a chance to log many full runs with the Porsche but I spent a lot of time tweaking. Traction roll is the big enemy here - and this older ASC body is more narrow than the newest 911 GT3 RS ASC bodies. This is most evident in the rear - where trying to lower ride height results in wheel rub even with 0 offset tires. Going to narrow rears with +2 offset allowed me to lower it a little but traction roll was still a constant battle - but this also encourages smoother driving practice…
pictures pending…
Date-08/15/2021
Location- Elkton MD
Race Time-349.26
Fastest Lap-4.33
Chassis-MR-03
Motor- PN70T BB
T-Plate- PN CF #3
Fluid - N/A
pictures pending…
#1274
Class-Pro Stock
Date-08/04/2021
Location- Elkton MD
Race Time- 344.88
Fastest Lap- 4.02
Wheelbase-98mm
Motor Mount- MZW309
Dampener MZW310
Notes: no changes from last month. Moving forward I will be experimenting with 102mm wheelbase. Still a work in progress…
pictures pending…
Date-08/04/2021
Location- Elkton MD
Race Time- 344.88
Fastest Lap- 4.02
Wheelbase-98mm
Motor Mount- MZW309
Dampener MZW310
pictures pending…
#1275
Hello All,
We only had four racers this month.
Box Stock
1st - ChemNut - 338.4/4.29s
2nd - Traveler - 350.5/4.51s
3rd - FastJew - 368.2/4.49s
Porsche Cup
1st - ChemNut - 349.3/4.33s
Stock Class
1st - ChemNut - 317.5/3.93s
2nd - Traveler - 324.1/4.06s
3rd - LuckyLou - 328.2/4.19s
Pro Stock Class
1st - ChemNut - 344.9/4.02s
Only ChemNut improved his counter clockwise time in Box Stock and Porsche over his clockwise time in prior month and FTM goes to ChemNut and his Stock car with a smoking 3.93 fast lap.
Drive fast!
Cheers,
Traveler2
Hello All,
Box Stock
Porsche Cup
Stock Class
Pro Stock Class
Drive fast!
Cheers,
Traveler2
3036Likes
