Mini-96 World Challenge
#2761
No worries I have my stock window still i'll swap it in.
#2762
If I want to resubmit, can I repost or should I edit my older post?
Class- Narrow Class
Date- 1/11/25
Location- Monterey, CA
Race Time- 5:24.668
Fastest Lap- 3.860
Chassis-MR03-N
Body- Datsun 240ZG
Wheelbase-90mm
Tires-F 20 shore Kyosho / R 30 shore Kyosho
Wheels-F- N 0mm 20mm Kyosho / R- W -1mm 20mm Kyosho
Motor- stock silver can
Batteries- EBL 1100mah
Front Springs- stock
T-Plate- stock
Motor Mount- stock
Dampener (If applicable)- stock
Gearing-stock 6T
Notes- finally got a timing system. It’s a lot more fun and serious now
Class- Narrow Class
Date- 1/11/25
Race Time- 5:24.668
Fastest Lap- 3.860
Chassis-MR03-N
Body- Datsun 240ZG
Wheelbase-90mm
T-Plate- stock
Motor Mount- stock
Gearing-stock 6T
#2763
iDChuck, the way Jim wanted it done was to update your original post with your fastest time on top. That way the thread isn't filled with hard to search posts. That's what I plan on doing unless Poor Boy wants it otherwise since he is running it now.
#2764
lass- Box Stock
Date- 01/28/2025
Location- Irvine, CA
Race Time- 4:28.110 / 268.110
Fastest Lap- 3.396
Chassis- AE SR27
Body- Lexus SC430
Wheelbase- 98mm
Tires- FR (PN KS1138) / RR (Gekko RS2 GK-005)
Wheels- PN 10-Spoke 20mm F2 / PN 10-Spoke 20mm R2
Motor- Stock Silver Can
Batteries- PN Racing 900 mAh
Front Springs- Stock
T-Plate- Stock Plastic
Motor Mount- Stock Plastic
Dampener (If applicable)- Stock Center Shock
Gearing- 7T Pinion / Stock Differential (44T)
Notes- Stock AE Transmitter
Date- 01/28/2025
Fastest Lap- 3.396
Chassis- AE SR27
Body- Lexus SC430
Wheelbase- 98mm
#2765
Class- Narrow Class
Date- 1/11/25
Race Time- 5:24.668
Fastest Lap- 3.860
Chassis-MR03-N
Body- Datsun 240ZG
Wheelbase-90mm
T-Plate- stock
Motor Mount- stock
Gearing-stock 6T
Class- Narrow Class
Date- 1/11/25
Race Time- 5:24.668
Fastest Lap- 3.860
Chassis-MR03-N
Body- Datsun 240ZG
Wheelbase-90mm
T-Plate- stock
Motor Mount- stock
Gearing-stock 6T
#2766
Got the stock LM 3500 car working well on this layout. Here is what will probably be my stock run this month. Shaved a little over a second off of the winning 2023 time at 227.69 Total run time and a best lap of 2.72
https://www.youtube.com/watch?fbclid...ature=youtu.be
#2768
Tens of thousands of laps of practice. Took me many months pushing as hard as I could to get onto the pace and it is still a challenge every month.
Hopefully the video will help you with finding a fast line around the track. Turning my cars down until I could chose the line and repeat it lap after lap was probably the most helpful thing when I first started. If your track is brand new it will need a good amount of laps and some cleaning (damp wash cloth) before it starts making really good traction.
If you need help with setup or anything else reach out (here or PM)
#2769
Was bored last night, so I mounted up a Golem Bee Lexan body on my MR04 Open chassis. I still need a to trim a bit, then paint. It's different to drive with the body being soo light, but the car FLIES! It's not too bad on the walls, but a hit at high speed will have the car flipped around the wrong way! The Bee isn't a very race designed body, so I'm curious to see how a racing Lexan body will handle!
#2770
iDChuck, there are a few VERY FAST guys here! I have been trying to get somewhere close to PoorBoy and Traveler2 for the last few years, and while I can now get within a few tenths of a second for their fast lap times, their consistency has their overall times SUPER LOW! PoorBoy is correct that it takes TONS of laps to get to speed! I try to run at least a set of batteries a day, which depending on what motor/chassis I'm running is 200-300 laps at the speed I usually run at now. Most days I run closer to 1,000 laps, and almost 3 years after starting Mini-Zs, I'm just now getting the feeling I can keep my car wherever I want on the track at speed. The last few months everything is just really clicking.
So just get a couple of sets of batteries and tires, and drive as much as possible. It can be very frustrating trying to get fast, but once it clicks, it's a BLAST!!! So HAVE FUN and holler with anything!!!
Stay Warm Guys!
Stay Warm Guys!
#2771
same advice as already given...
laps laps and laps... I'm also just starting this format of time trial racing but i've raced for many years. Consistency is huge here as we are running super low times every mistake needs 3-5 really good laps to make up for in time and even then your average lap time will increase every time you make a mistake. My best run so far still has 7-10 bad laps as 75 laps is really a test of focus and consistency...
#2772
Class- Narrow Class
Date- 1/14/25
Race Time- 5:11.423
Fastest Lap- 3.686
Chassis-MR03-N
Body- Datsun 240ZL
Wheelbase-90mm
Tires-F 30 shore Kyosho / R 20 shore Kyosho
Batteries- EBL 1100 mah
T-Plate- stock
Motor Mount- stock
Gearing- 7T
Notes- Not using full power is faster for me. My left tire is wearing out faster because of more right turns. I also changed out to a 7T, I wasn’t aware that it was mandatory.
Date- 1/14/25
Race Time- 5:11.423
Fastest Lap- 3.686
Chassis-MR03-N
Body- Datsun 240ZL
Wheelbase-90mm
T-Plate- stock
Motor Mount- stock
Gearing- 7T
3036Likes
. What am i missing?
