Mini-96 World Challenge
#3211
Class- BOXSTOCK
Date- 07/31/2025
Location- Central Texas
Race Time- 360.036 / 6:00.036
Fastest Lap- 4.286
Chassis- MR04
Body- Ferrari Enzo
Wheelbase-98mm
Tires- F-PN KSM Medium LH / R- Marka V1R10
Wheels- F- N +1mm 20mm Kyo Blk Enzo wheels / R- W +3mm 20mm Kyo Blk Enzo wheels
Motor- Kyo Stock
Batteries- SpeedHouse 800HV
Front Springs- PN Red
T-Plate-Kyo #5 Soft Fiberglass
Motor Mount-Kyo Stock MM
Dampener (If applicable)- Kyo Spring shock (Yellow Spring)
Dampener Fluid (If applicable)- Atomic 25k grease
Gearing-7/44 Kyo Gear Diff- Ruby Lube packed
Notes- MR-04 Ready Set with Reflex 0* Aluminum Knuckles, and I removed the thermal switch from the motor, as it was a PIA to get the top cover back on after cleaning the motor!
Humidity down to 50% tonight at 72.4* and the tires were chattering at every turn! NEEDS TIRE WORK for sure! My body isn't happy and my times tonight weren't all that good.
Date- 07/31/2025
Fastest Lap- 4.286
Chassis- MR04
Body- Ferrari Enzo
Wheelbase-98mm
Motor- Kyo Stock
#3212
Class- STOCK
Date- 07/31/2025
Location-Central Texas
Race Time-
Fastest Lap-
Chassis- PN 2.5W/MR03EVO board/ 04 arms
Body-Jomurema
Wheelbase-98mm
Tires-F-PN KS Soft / R- Marka V1RR10 Soft Radials almost worn to slicks
Wheels- F-PN N+1.5mm 19mm Flanged White 6 hole / R- PN W+2mm 20mm Flanged White 6 Hole
Motor-PN 3500Kv
Batteries- Eneloop 850HV
Front Springs-PN Purple
T-Plate-PN #3 Silver Carbon Fiber
Motor Mount-PN V3 94/98mm
Dampener (If applicable)- PN DDS ( Green top/ PN lt. purple X-Strenght bottom spring) PN Dual Spring Top Shock (Green Front/Purple Rear)
Gearing-12/53 PN Ball Diff
Notes- Stock chassis was pretty good, me a little shakey! Tires are a bit worn, so new shoes will probably help!
Date- 07/31/2025
Race Time-
Fastest Lap-
Body-Jomurema
Wheelbase-98mm
Motor-PN 3500Kv
#3213
Class- PROSTOCK
Date- 07/31/2025
Race Time- 342.880 / 5:42.880
Fastest Lap- 4.038
Chassis- PN 2.5W/MR04EVO board/ 04 arms
Body- Jomurema
Wheelbase- 98mm
Tires-F-Reflex N 40* LH (RX604-40) / R- Reflex W 30* Radials (RX602-30)
Wheels- F- 3D Disk Wheels +1mm 20mm Blue / R- 3D Disk wheels +2mm 20mm Blue (no disk)
Motor-PN 5500Kv Anima Sensored
Front Springs- Kyo Green
T-Plate-PN #4 Black Fiber Glass
Motor Mount-PN Multi Mount
Dampener (If applicable)- PN DDS ( Green top/ Green bottom spring) PN Dual Spring Top Shock (Silver Stock Springs)
Gearing-10/52 PN Ball Diff
Notes- Car wasn't driving all that well! I really need to go back down to a 9T pinion, as it just didn't have enough drive to get off the corners like I like! Stock and Open were my best drivers tonight!
Date- 07/31/2025
Fastest Lap- 4.038
Body- Jomurema
Wheelbase- 98mm
#3214
Class- OPEN 2WD
Date- 07/31/2025
Race Time- 311.082 / 5:11.082
Fastest Lap- 3.859
Chassis- GL GLR
Body- Jomurema
Wheelbase- 98mm
Tires-F- PN KS Medium LH (KS1138)/ R- Marka MZR-V1R05
Wheels- F- N+1mm 20mm 3D Disk wheels Blue / R- W+2mm 20mm 3D Disk wheels Black (no disk)
Motor- NHX 2500Kv
Batteries- GNB 350mAh 2S LiPO
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
Dampener (If applicable)- Short Center Shock (Blue Spring) / Yellow side springs
Dampener Fluid (If applicable)- 25K Atomic grease- Center / 15K Atomic grease- Sides
Gearing-10/53 PN Gear Diff
Notes- Last car I drove tonight, and as always it's THE BEST!!! VERY EASY to drive, even after being awake for 50+ hours! I might have been able to get under the 5 minute mark with more time!
Date- 07/31/2025
Fastest Lap- 3.859
Chassis- GL GLR
Body- Jomurema
Wheelbase- 98mm
Motor- NHX 2500Kv
Front Springs-Blue
T-Plate-N/A
Motor Mount-GL 98mm
#3216
Class-Open 2wd
Date-7/31/25
Location-Central Wisconsin
Race Time-7:44.260
Fastest Lap-5.057
Chassis-Atomic MRZ-SF
Body-Jomura
Wheelbase-98mm
Tires-F-PN Mediums, R-Gekko Mediums
Motor-2500KV
Batteries-350mah 7.4
Front Springs-Atomic Green
T-Plate-
Motor Mount-Stock Atomic
Dampener (If applicable)-Atomic
Dampener Fluid (If applicable)-2500
Gearing-10/53
Notes-Did not give the box stock a try this month since I was enjoying the Atomic on this track. Cut my time down considerably this month as I started around 8 minutes. Wish I had more time to put more laps down, but summer time.
Date-7/31/25
Race Time-7:44.260
Fastest Lap-5.057
Body-Jomura
Wheelbase-98mm
Motor-2500KV
T-Plate-
Gearing-10/53
#3217
Hard to believe it's been six months since I last participated in the Challenge, but with starting a new job in February after being retired for 2 years and the brief illness and passing of my dad, I've had too many other priorities. I didn't have as much time this month to get runs in as I used to when I was retired, but I was able to significantly beat my times from April 2020 when we ran a very similar layout. After Eric beat my best Box Stock time of 329.5 mid month, I tried about 10 more times to improve but couldn't, so I will have to settle for other than first. I only got a couple of runs in with some of my other cars early in the month, but will post those times too to see how I did. Results incoming...
#3218
Class-Box Stock
Date-7/13/2025
Location-Winston-Salem, NC
Race Time-329.6
Fastest Lap-4.18
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Tires-PN KS Firm fronts, Marka V1R15 rears
Motor-Stock
Batteries-Amazon Basics 800s
Front Springs-Kyosho Stock
T-Plate-Kyosho FRP 0.6H
Motor Mount-Stock MM
Dampener (If applicable)-None
Notes-I had a lot of difficulty with thermal shutdown on this layout. I sprayed out and relubed motor twice, but it would still happen if I didn't let the motor cool down between runs. I also noticed I was faster and more consistent with the less punch AAAs. Consistency this run of 96.06% wasn't the best I had, but this was the quickest time.
Date-7/13/2025
Race Time-329.6
Fastest Lap-4.18
Chassis-MR-03 FHSS
Body-2012 NSX
Wheelbase-98mm
Motor-Stock
#3219
Class-90mm Narrow MX-5 Miata Unofficial Experimental Class
Date-7/6/2025
Race Time-352.4
Fastest Lap-4.43
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Tires-PN KSK 40 LH fronts, PN KS Soft rears (20mm 0 offset flanged wheels all around)
Motor-Stock
Batteries-Gens Ace 750s
Front Springs-PN Super Soft Blue
T-Plate-Kyosho Soft Fiberglass RM
Motor Mount-Stock RM
Dampener (If applicable)-N/A
Gearing-7/44 Gear diff
Notes-This car is super light, but very stable and quick and is one of the funnest to drive and watch going around the track! It runs great on both Narrow and Wide rears with no setup changes. Only 1 try this month.
Date-7/6/2025
Race Time-352.4
Fastest Lap-4.43
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Motor-Stock
#3220
Class-90mm Narrow Stock
Date-7/6/2025
Race Time-353.2
Fastest Lap-4.39
Chassis-MR-03 ASF
Body-Toyota GRMN Yaris
Wheelbase-90mm
Motor-ATM 70T
Batteries-GensAce 750s
Front Springs-PN Green
T-Plate-PN #3 Spring Steel
Motor Mount-PN MR9094 90mm
Dampener (If applicable)-PN Integrated with dual spring center shock
Gearing-9/44 Gear diff
Notes-It is a very stable body and fun to watch rip around the track. No changes. Only 1 run this month.
Date-7/6/2025
Race Time-353.2
Fastest Lap-4.39
Chassis-MR-03 ASF
Wheelbase-90mm
Motor-ATM 70T
#3221
Class-Porsche Cup Class
Date-7/5/25
Race Time-342.3
Fastest Lap-4.36
Chassis-MR-03 ASF
Body-911GT1
Wheelbase-90mm
Tires-PN KS Med fronts glued, Marka V1R10 rears
Motor-Stock
Batteries-SpeedHouse 800s
Front Springs-ATM Deep Blue (Soft)
T-Plate-Kyosho Carbon Soft
Notes-One of the more fun cars to drive, and better after gluing sidewall, but still flips easily if I clip an inside turn because its so light with no ballast added. I only got two runs in this month.
Date-7/5/25
Race Time-342.3
Fastest Lap-4.36
Chassis-MR-03 ASF
Body-911GT1
Wheelbase-90mm
Motor-Stock
#3222
Class-Stock PNR 3500kv
Date-7/11/2025
Race Time-309.0
Fastest Lap-3.92
Chassis-PNR2.5W
Body-Jomurema with PN Lexan Roof (Not pictured)
Wheelbase-98mm
Tires-PN KS Firm fronts, Marka V1RR15 Radial rears
Motor-PN v4 3500vk
Front Springs-PN AA Yellow
T-Plate-Kyosho FRP 0.5 Medium
Motor Mount-PN 98mm v5
Gearing-PN 64p 14/53 Ball diff
Notes-No changes. Only 2 runs this month. This one was 97.14% consistency.
Date-7/11/2025
Race Time-309.0
Fastest Lap-3.92
Chassis-PNR2.5W
Wheelbase-98mm
Motor-PN v4 3500vk
#3223
box stock
Date August 2025
Location- Sydney
Race Time-7:04.45
Fastest Lap-5.21
Chassis-Kyosho
Body- Jomurema
Wheelbase-98mm
Rear Marka
Front Marka
Motor-Stock
Batteries- Jaycar AAA
T plate #4 carbon
Front springs : stock
Date August 2025
Location- Sydney
Race Time-7:04.45
Fastest Lap-5.21
Chassis-Kyosho
Body- Jomurema
Wheelbase-98mm
Rear Marka
Front Marka
Motor-Stock
T plate #4 carbon
#3224
stock
Date Aug 2025
Location- Sydney
Race Time-6:38.32
Fastest Lap-4.80
Chassis-Kyosho
Body- Jomurema
Wheelbase-98mm
Rear Marka
Front Marka
Motor-Stock
T plate #4 carbon
Date Aug 2025
Location- Sydney
Race Time-6:38.32
Fastest Lap-4.80
Chassis-Kyosho
Body- Jomurema
Wheelbase-98mm
Rear Marka
Front Marka
Motor-Stock
T plate #4 carbon
#3225
Class - Box Stock
Date - 7/31/2025
Location - Iowa
Race Time - 374.970
Fastest Lap - 4.327
Chassis - MR-04 MM
Body - McLaren 12C
Wheelbase - 98mmTires - PN KS Medium on 20mm F1 flanged wheels, no tape / Marka 15° Radials R2 wheels
Motor - Stock
Batteries - Orion 750 SHO
Front Springs - Stock
T-Plate - Kyosho Carbon Firm
Motor Mount - Stock
Dampener (If applicable) -
Dampener Fluid (If applicable) -
Gearing - 7T, stock diff
Notes: Can't get myself excited to put laps on this layout.
Date - 7/31/2025
Location - Iowa
Race Time - 374.970
Fastest Lap - 4.327
Chassis - MR-04 MM
Body - McLaren 12C
Motor - Stock
Motor Mount - Stock
3035Likes
