Mini-96 World Challenge >
Like Tree3035Likes
Old 02-01-2025 | 06:33 AM
  #2836
Default January 2025 MX-5 (Miata) Unofficial Experimental Class
Class-90mm Narrow MX-5 Miata Unofficial Experimental Class
Date-1/8/2025
Location-Winston-Salem, NC
Race Time-262.7
Fastest Lap-3.35
Chassis-MR-03 FHSS
Body-Mazda MX-5
Wheelbase-90mm
Tires-PN KSK 40 LH fronts, PN KS Soft rears (20mm 0 offset flanged wheels all around)
Motor-Stock
Batteries-Gens Ace 750s
Front Springs-PN Super Soft Blue
T-Plate-Kyosho Soft Fiberglass RM
Motor Mount-Stock RM
Dampener (If applicable)-N/A
Gearing-7/44 Gear diff
Notes-This car is super light, but very stable and quick and is one of the funest to drive and watch going around the track! It runs great on both Narrow and Wide rears with no setup changes. No changes, but was able to get close to my Box Stock RM GT1 time of 250.9.
Phatz_60 likes this.
Traveler2 is offline
Old 02-01-2025 | 06:36 AM
  #2837
Default January 2025 Narrow Class
Class-90mm Narrow Stock
Date-1/12/2025
Race Time-255.1
Fastest Lap-3.23
Chassis-MR-03 ASF
Body-Toyota GRMN Yaris
Wheelbase-90mm
Motor-ATM 70T
Batteries-GensAce 750s
Front Springs-PN Green
T-Plate-PN #3 Spring Steel
Motor Mount-PN MR9094 90mm
Dampener (If applicable)-PN Integrated with dual spring center shock
Gearing-9/44 Gear diff
Notes-It is a very stable body and fun to watch rip around the track. No changes.
BoxxerBoyDrew and Phatz_60 like this.
Old 02-01-2025 | 06:42 AM
  #2838
Default January 2025 Porsche Cup
Class-Porsche Cup Class
Date-1/11/2025
Race Time-238.5
Fastest Lap-3.02
Chassis-MR-03 EVO
Body-911 GT3
Wheelbase-90mm
Tires-PN KS Soft on PN 19mm +0.5 fronts, Marka v1R10 on PN 19mm W0 rears (not pictured)
Motor-ATM 3500
Front Springs-Kyosho Stock
T-Plate-GT55 +0.6 FRP #4
Motor Mount-Nexx Round RM
Dampener (If applicable)-PN G10 DDS and Kyosho Inner Tube Shock MZW442
Dampener Fluid (If applicable)-1300 Silicone Oil
Gearing-PN 64p 13/53 Ball diff
Notes-This car is super quick and fun, but a challenge to drive consistently. I only got a couple of runs in, but this one was near perfect at 97.42% consistency, the highest for all classes this month.
Old 02-01-2025 | 06:46 AM
  #2839
Default January 2025 Sock Class
Class-Stock PNR 3500kv
Date-1/19/2025
Race Time-232.4
Fastest Lap-2.92
Chassis-PNR2.5W
Body-Jomurema with PN Lexan Roof (Not pictured)
Wheelbase-98mm
Tires-PN KS Firm fronts, Marka V1RR10 Radial rears
Motor-PN v4 3500vk
Front Springs-PN AA Yellow
T-Plate-Kyosho FRP 0.5 Medium
Motor Mount-PN 98mm v5
Gearing-PN 64p 14/53 Ball diff
Notes-No changes. Despite several tries, I could not beat the 228.9 I ran in Feb 2023...
Old 02-01-2025 | 06:52 AM
  #2840
Default January 2025 Open 2WD
Class-Open 2WD
Date-1/31/2025
Race Time-228.1
Fastest Lap-2.86
Chassis-RTRC RTA v2
Body-Jomurema GT01
Wheelbase-98mm
Tires-PN KS Med on RTRC 19mm +1 fronts, Marka V1RR10 Radial +2 rears
Motor-GL Sensored 2500kv
Batteries-PN 2S LiPo
Front Springs-RTRC Yellow
T-Plate-N/A
Motor Mount-Stock
Dampener (If applicable)-Stock
Dampener Fluid (If applicable)-K 5000 grease
Gearing-14/53
Notes-Only a couple of runs, and just barely beat my Stock time from Feb 2023.
Old 02-01-2025 | 07:02 AM
  #2841
Originally Posted by AM03GT
I think generally more front tire (larger diameter) gives more steering for these tight courses but I'm cheap so I like to "use up" my tires before swapping to a fresh set. What is everyone's threshold for what "used up" means? On my open 2wd my fronts are down to about 21.5mm inner... Is this too thin and time to throw out?
AM03GT FWIF I usually run my front tires down to paper thin. I find they are more consistent the more they wear down, but I'm also thrifty. Its the Marka rears that I can't run too far down without losing performance. I usually have to replace them when they get somewhere below 24mm.
Old 02-01-2025 | 08:27 AM
  #2842
AWESOME RUNS guys!!!
BoxxerBoyDrew is offline
Old 02-01-2025 | 11:26 AM
  #2843
Ran CCW with my ProStock 787B for the first time this morning, and it was pretty good with a few TR in the 180* off the straight, but all but 1 landed on it's wheels. I need to do some setup work, but when it's going to be 80* this week and freezing again the next, the setup is going to be tough to nail down. Anyway here's the starting time.
Hope to shave at least 45 seconds off this by the end of the month, but my brain likes CW!
Old 02-01-2025 | 11:45 AM
  #2844
AM03GT's Avatar
Thanks i think im on the same program but the front definitely lose steering and gain consistency and ease of driving the more they wear down... Rears i agree under 24mm they start to lose pace and about 23.5mm and smaller you lose another tenth or two minimum...
AM03GT is offline
Old 02-01-2025 | 06:12 PM
  #2845
Hey Drew, how did you edit the name of the race?
iDChuck is offline
Old 02-01-2025 | 08:57 PM
  #2846
when you are in the page setting up the race, you will see the date and time at the top of the screen under Race Name. you can click in front of it and edit there. You just have to remember that it's for that race only. if you click repeat practice, it will just have the date and time.
iDChuck and Phatz_60 like this.
Old 02-02-2025 | 04:11 AM
  #2847
Hey guy’s sorry I’ve not been around much, I’m having some eye problems and will be getting shots every month for 3 months ( directly in my eyes ) so I’ll be out for a little while but will try to stay active here.
Welcome to the new folks and as Drew says Drive Fast
oh yeah my open chassis is ready for when I am. Later Walt
Phatz_60 is offline
Old 02-02-2025 | 09:37 AM
  #2848
Hey Walt, SORRY to hear of your eye trouble!!! My best friend of 30 years has severe eye trouble in one of his eyes, and it's a bitch! Hope you will get well soon!
Old 02-03-2025 | 05:11 PM
  #2849
Class- Narrow Class
Date- 2/3/25
Location- Monterey, CA
Race Time- 5:49.856
Fastest Lap- 4.319
Chassis-MR03-N
Body- Datsun 240ZG
Wheelbase-90mm
Tires-F 30 shore Kyosho / R 20 shore Kyosho
Wheels-F- N 0mm 20mm Kyosho / R- N 0mm 20mm Kyosho
Motor- stock silver can
Batteries- Energizer 800 mah
Front Springs- stock
T-Plate- stock
Motor Mount- stock
Dampener (If applicable)- stock
Gearing- 7T pinion
Notes- Takes time getting use to CCW direction. It still baffles me how fast you guys are
iDChuck is offline
Old 02-03-2025 | 08:54 PM
  #2850
January results:
We had 10 drivers posting 38 entries including some new drivers. Very close racing in several classes. Lots of fast times on this tight technical layout. Thanks to everyone for posting times and for participating in the challenge.
Fast lap was a 2.67 second lap with my stock 3500kv car.
Please let me know if you find any mistakes in tabulations.
Box Stock Sportsman
1st – AM03GT – 268.11/3.40
2nd –
BoxxerBoyDrew – 272.0/3.29
3rd –
danjoy25/Dan Dylen Garcia – 295.5/3.63
4th – Maaku0220 – 298.49/3.52
5th – CrazyRonny/Ronald Bouduc – 299.0/3.62
6th – feu98/Pierre Thisdel – 355.0/3.91
Box Stock Expert
1st - PoorBoy/David Krinard – 243.1/3.04
2nd -Traveler2/Marwan Zabaneh – 246.4/3.10
3rd – Chjosi – 255.5/3.16
Narrow Class
1st - Traveler2/Marwan Zabaneh – 255.1/3.23
2nd–
PoorBoy/David Krinard -255.4/3.16
3rd –Gerr Burr – 284.27/3.43
4th -iDChuck– 311.42/3.69
Unofficial Open MX-5 Class
1st - PoorBoy/David Krinard -255.4/3.16
2nd -Traveler2/Marwan Zabaneh – 262.7/3.35
3rd –
Chjosi – 270.3/3.16
4th - BoxxerBoyDrew – 282.5/3.23
Porsche Cup Class
1st - Traveler2/Marwan Zabaneh – 238.5/3.02
2nd - PoorBoy/David Krinard – 242.0/2.93
3rd – BoxxerBoyDrew – 274.7/3.18
Stock 86 Class
1st - PoorBoy/David Krinard –257.86/3.14
Stock Class
1st - PoorBoy/David Krinard – 228.7/2.72
2nd -Traveler2/Marwan Zabaneh – 232.4/2.92
3rd – BoxxerBoyDrew – 249.0/3.09
4th - danjoy25/Dan Dylen Garcia – 253.7/3.15
5th – CrazyRonny/Ronald Bouduc – 373.0/3.29
6th – feu/Pierre Thisdel – 343.0/3.91
Pro Stock
1st - PoorBoy/David Krinard – 226.9/2.67
2nd - BoxxerBoyDrew – 244.8/2.93
Open 2WD
1st - PoorBoy/David Krinard – 227.1/2.73
2nd -Traveler2/Marwan Zabaneh – 228.1/2.86
3rd – AM03GT– 253.96/3.25
4th - danjoy25/Dan Dylen Garcia – 262.1/3.17
5th – BoxxerBoyDrew – 277.3/3.06
Open AWD
1st - PoorBoy/David Krinard – 235.8/2.68
MA-020
1st - PoorBoy/David Krinard – 280.98/3.38
2nd - CrazyRonny/Ronald Bouduc – 306/3.68
3rd – feu/Pierre Thisdel – 345/3.92
AM03GT, iDChuck, chjosi and 2 others like this.
Poor_Boy is offline
