View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
slasherch@ oki sir salamat mag back read ako , eto gusto ko sa rctech lahat matulungin..salamat ulit
kaya balak ko nimh battery na lng buy ko khit 4hrs charging tiis lng
60A 5.5T- 4.5k (BRAND NEW SEALED)
35A 13T - 3.5k (BRAND NEW SEALED)
All HW item are sealed and brand new
IMAX B6Ac - 2.7k (BRAND NEW)
Tiger 5400mAh 60C hard case 7.2v 2S - 2k (BRAND NEW) out of stock
Tiger 5400mAh 60C hard case 7.2v 2S - 1.5k (USED brand new comdition)
dimension: 140x48x27mm
09224790923
meet up in any LRT/MRT Station
09224790923
Sana nga my points maski papano... nagkaproblem ako sa last 2 heats final hehehe nagthermal ako no time sa 2nd heat at 3rd heat 3 laps lang ata tapos ayaw na. Kunin nalang sana points ko sa quaili hahaha
~wala si dennis, sean at jovie - naka-Red tide alert hahaha sabi ni papz nhelson nasubsub daw hahaha -- goggles kasi kayo para protektodo
:fOR sALE!!!
...NEW PARTS FOR TAMIYA TA05!
54083 -short reversible suspension set - P2,500
53848 -aluminum racing steering set - P1,200
53883 -carbon steering link - P1,000
53904 -carbon center plate - P500
53916 -aluminum stabilizer holder - P600
51216 -drive shaft, 2pairs - P500
84048 -lightweight urethane bumper, 3pcs - P150each
3RACING ta05 aluminum bulkhead - P1,200
3RACING ta05 aluminum center one-way - P800
3RACING ta05-ifs heavy duty universal shaft, 2pairs - P800/pair
YEAH RACING ta05 steel universal shaft set, 4pcs - P1,500
tamiya ta-05ms belt set, 2pcs - P500
...NEW PARTS FOR TAMIYA M-CHASSIS!
3RACING m05 extension wheelbase kit (257mm) - P1,500
3RACING m-chassis spring set - P300
3RACING m05 aluminum front shock tower - P500
...NEW ASSORTED PARTS FOR TAMIYA!
53683 -urethane bumper blue - P150
53807 -aluminum rear upright 0deg. - P1,500
53502 -aluminum universal shaft 42mm - P750
53670 -tt01 aluminum racing steering set - P1,400
51132 -6mm aluminum stabilizer end,2pairs - P250
53806 -tt01 ball diff cup joint for universal shaft - P150
49228 -pinion gear holder (blue) - P750
53526 -3x23mm titanim turbuckle shafts (2pcs)- P550
53527 -3x32mm titanim turbuckle shafts (2pcs) - P550
50992 -TB evolution III diff joint - P450
53505 -39mm swing shafts (2pcs) - P800
53626 -TB evolution III 1way ring gear carbon plate - P300
53590 -cup joint for TB-01 reinforced front 1way unit - P250
53451 -TA04 front 1way joint set - P300
...USED ASSORTED PARTS FOR TAMIYA!
ta-05 ver.2 stock motor mount (slightly used) - P500
ta-05 stock motor mount (slightly used) - P500
ta-05 low friction belt set (slightly used) - P400
ta-05 wheel axles, 2pcs (slightly used) - P200
ta-05 dogbones, 2pcs (slightly used) - P200
extra stiff spring set, white (like new) - P300
...NEW PARTS FOR HPI/HB CYCLONE!
61395 -aluminum pivot block set, 6pcs. (black) - P2,000
70706 -aluminum block FR (black) 2pcs - P600each
61396 -aluminum drive shaft ver.2 44mm (black) 4pcs - P400each
67740 -aluminum shock set (purple) - P3,500
70729 -upper chassis woven graphite - P900
66492 -aluminum center pulley 18T - P600
67704 -frp middle block deck 2.0mm - P300
75143 -aluminum servo saver set - P300
...USED PARTS FOR HPI/HB CYCLONE!
aluminum C-HUB 4deg (BLACK) - P600
aluminum SPURGEAR HOLDER (BLACK) - P500
aluminum pivot blocks, 2pcs:FR, 1pc:RF (silver) - P300each
cyclone-s upperdeck and middle chassis - P300
cyclone-s motormount and middle mount - P300
stabilizer set, front and rear (ver. 1) - P500
stabilizer set, front and rear (ver. 2) - P500
aluminum diff outdrives for cyclone (silver) 2pairs - P500pair
aluminum rear hub for cyclone (silver) 2pairs - P600pair
aluminum steering parts for cyclone (silver) - P600
aluminum upper shock cap for cyclone, 4pcs. (silver) - P500
aluminum shock adjust nut for cyclone, 4pcs. (silver) - P500
ball differential for cyclone tcx and tc-fd - P1,000
delrin diff outdrives (opened only) - P500
heavy duty ball caps (opened only) - P200
ball diff pulley 39t (ver.2) 2pcs - P150each
aluminum shock ball end 4pcs (blue) - P150
rear suspension arms ver.1 (opened only) 3pairs - P300pair
rear suspension arms ver.2 (opened ony) 3pairs - P300pair
c-hubs (opened only) 0 deg - P300pair
rear hubs (opened only) - P300pair
cyclone-s spur gear holder (opened only) 3pcs - P100each
shock ball end set (opened only) - P200
universal wing mount set - P150
-sms me at 09157445578
-no reservations pls, tapos di naman pala sure.
-meet-ups, Q.C., every sunday lang sana.
-pictures per request.
-thank you RCTECH!
-thank you RCTECH!
For Sale:
very slightly used 3Racing FGX f1 car
with Pit shimizu racing tires front and rear
extra pit shimizu front (medium comp)
stabilizer bar
Bnew BMS 706MG low profile hi-speed servo
extra speed tuned gears
silvercan stock motor
some spares, box and manual
09178903878
6K neg.
stabilizer bar
09178903878
6K neg.
Bawas gamit Sale!!!
HPI RS4 Rally Slipper clutch w/ manual - 1000 (free new 84 teeth 48p spur gear)
Proline SC10 2wd beadlock rims front & rear - 1000
Bnew F103 Carbon reinforced arms set - 500
Bnew F103 Type A front rubber tires mounted - 800
Bnew GPM alloy rear damper mount for CC01(silver) - 800
Bnew 3racing alumn. belt pulley for HB cyclone- 500
LRP Vector X11 4.5T BL motor - 2K
SC10 2wd gear diff rebuild kit - 500
09178903878
sa jp lang ang meet up!
09178903878
For sale
Gt power flashing light kit...500
Ae sc10 ft cf lipo stay
Differential assembly
Tranny case
Idler gear
Topshaft
Front and rear arms,hubs,shock tower,bumpers,knuckles
Call/text.....9153786069 for prices
Tnx rc tech
Tranny case
Idler gear
Topshaft
Tnx rc tech
