View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
Nanda 1/8 buggy 6k rtr
Nanda Buggy NRB-3 RTR - sold
Meet up Robinsons Cainta
09152491794
09152491794
FS
updated
LF: Slipper Clutch
Looking for:
Slipper Clutch for Axial SCX10.Pls.
PM me or contact me at 09175360697. Thanks.
HobbY King 50A-65A Heli ESC - SWAP with 50Amp Plane ESC
Wrong choice eh, tested only.. disregard the date, mali pagka-set
Spec.
Weight: 40g
Cells: 4-10Ni MH ~ 2-4S Li Po
Max Current: 50A
Burst: 65A
BEC: 3A
Timing: 1/7/15/30 programmable
PWM: 8/16K
Features.
Constant current 50A Max 65A <10S
Li-Poly 2-4 cells Ni-MH 4-10 cells
Low Resistant 0.0014 Ohms;
Dynamic Braking
BEC: 3A
Auto shut down when lose signal
Slow down at 2.8V per cell Lipo, Cut-off at 0.8V/cell NiMh
User Programming options:
Battery setting
Throttle Range
Brake setting 4 options:
Direction and Cutoff Type
Timing Mode Setting: 1 / 7 / 15 / 30
PWM setting: 8K/16K
Governor mode
Soft start
Spec.
Weight: 40g
Max Current: 50A
Burst: 65A
BEC: 3A
PWM: 8/16K
Features.
Dynamic Braking
BEC: 3A
Battery setting
Throttle Range
PWM setting: 8K/16K
Governor mode
Soft start
Repriced UPGRADED HOT BODIES CYCLONE S RTR FOR SALE
Upgraded: speed passion motor 13.5T, speed passion esc cirtix club race, spektrum dx3c transmitter, savox servo, 2 sets of rims with tires, imax balancer charger, tiger lipoly battery 5400mah, c-hub upgraded to aluminum, upgraded one way differential, 2 body shells, light buckets, gt power led lights, intercooler, brembo brakes accessories.. 20k free shipping...
Contact: 09052235054
RFS: Quit RC. no time na kasi..
http://imageshack.us/photo/my-images...sc00977bk.jpg/
http://imageshack.us/photo/my-images...sc00986rj.jpg/
http://imageshack.us/photo/my-images/9/dsc00971eu.jpg/
http://imageshack.us/photo/my-images/40/dsc00982yg.jpg/
http://imageshack.us/photo/my-images/138/dsc00965w.jpg/
http://imageshack.us/photo/my-images...sc00983vr.jpg/
http://imageshack.us/photo/my-images...sc00966la.jpg/
Futaba R2104GF -- P1,400 SOLD
For sale TEH R31 ARTR
OPEN FOR Part OUT
UPDATED : PRICELIST for Part out
Some Item are NEGOTIABLE (But please NO LOW BALLER po)
TEH-R31 Eagle Racing CF convertion - 8000php
SAVOX SC-1257 TG -RESERVEDp
IMAX B6 Charger w/ Power Supply -RESERVED
TOOLBOX -RESERVED
Kit:
R31 Eagle Racing CF Convertion
R31 Eagle Racing Front One Way
R31 Eagle Racing Multi Diff Solid Spool axle
R31 Eagle Racing Aluminum Steering
R31 Eagle Racing Wide Angle Unis. F/R
R31 Eagle Racing Aluminum 10deg. C-hub
R31 Eagle Racing Aluminum Motor mount (Gold)
R31 Eagle Racing Aluminum Spur Gear Holder
Aluminum Dampers (not sure Eagle Racing)
R31 Eagle Racing Aluminum Servo Post
55% CS/Overdrive
F- 40 / 14 (Aluminum)
C- 18 / 18 both Aluminum Pulleys
R- 21 (Aluminum) / 36
Spring
F= Tamiya RED shoft Spring (but binalatan ko na dahil nababakbak para mas malinis tignan)
R= Super SOFT (from inertia)
FREEBIES for KIT
-almost B.new Tamiya 112T Spur
-Eagle Racing Front One Way tube for TA05 w/ 39T Pulley
-Eagle Racing 21T Front Center Aluminum Pulley
-TEH-R31 TUB CHASSIS
-TEH-R31 Front and Rear Shock Tower
-TAMIYA Adjustable offset rims with USED Threaded Tire (70%)
-BASHING SHELL YOKOMO S14 w/ Light Buckets ang Wing
-USED Painted Yokomo Rims (OFFSET maybe 6 or 7mm)
-1set China Rims and Stretch Tire 80%
NOTE : body post cut (advice to replace for other type or brand of shell)
Shock Piston need to replace for better performance but still in good working condition (may 2 piston modified 4 holes)
No Rear Diffuser
Electronics
Servo -RESERVED
SAVOX SC-1257 TG
NOTE: SERVO Wire is Cut almost 2inches nalang yun wire nya but malinis ang pag kakagawa
http://i1002.photobucket.com/albums/...ps4eff3e42.jpg
CHARGER -RESERVED
IMAX B6 w Power Supply
http://i1002.photobucket.com/albums/...pse7e70dd2.jpg
TOOLBOX -RESERVED
almost b.new bought last Dec. 2012 may price tag pa
(yung part na Orange is made of metal kasya ang kit w/ shell and some spare parts)
http://i1002.photobucket.com/albums/...psd9eedcc1.jpg
MORE PICS. pa CHECK nalang po yung mga Pictures dito
http://s1002.beta.photobucket.com/user/carb0n/library/
RFS : Planning to get 1:1, and nagiging too much busy nadin sa work....
For Inquiries
Send me SMS or CALL 09065812324
Open for PART OUT
Open For Meet Ups Depende sa Magiging usapan
No Lowballer Please ! only for Serious buyers
OPEN FOR Part OUT
TOOLBOX -RESERVED
Kit:
55% CS/Overdrive
Spring
FREEBIES for KIT
No Rear Diffuser
Electronics
Servo -RESERVED
SAVOX SC-1257 TG
CHARGER -RESERVED
TOOLBOX -RESERVED
For Inquiries
Open for PART OUT
Up ! lang po ulit !
KIT : TEH R31 still available ! Negotiable pa po !
thanks !
FOR SALE items:
Futaba 3PKS-8,500
• Spektrum 2.4 tx/rx
• Futaba bag with manual
• Alumm steering wheel
Novak GTB bl combo-5,000
• Sensored
• 6.5turns
TRF dampers-SOLD
• Soft&supersoft springs
Extreme x-605 lipo charger-2,000
Hpi toyota weld-800
•Bash shell
4cell lipo cut off-500
Rfs:quit..busy na sa work
For faster transaction call/txt 09159485521
Pm me for pic.send ko nlng via mail
Futaba 3PKS-8,500
• Sensored
• 6.5turns
TRF dampers-SOLD
Hpi toyota weld-800
•Bash shell
looking for!
looking for:
1.rear stabilizer bar for Kyosho Vonerrr
-1.3mm and 1.8mm
2. Blue 3mm nut (10pcs)
09155190006
thanks!
-1.3mm and 1.8mm
09155190006
thanks!
Additional pics.
[QUOTE=ashby00331100;12030985]Nanda Buggy NRB-3 RTR
