View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
up
For sale RC8be rolling kit for 12.7k good as new
MAMBA MONSTER BL MOTOR 2200kv brandnew in box for 5.3k -RESERVED TO A NON RCTECH MEMBER
EREVO VXL 1/16 scale for 18.7k ---97% new this is a sacrifice sale all aluminum hop ups and RPM's and hitec metal servo worth 12k+ with 2 free lipo and parallel connector no tx rx
TURNIGY NANO TECH 5000mah 2s 50c 2pcs. for 2500 each good as new-RESERVED TO SIR LANCE ALLAN
thanks rc tech 09157677094
pics.on page 1958
pics.on page 1958
LOOKING FOR:
LOOKING FOR M05 SHELL MED WB.......
09216013419
09216013419
buggies, hulls, bike & car
unloading some boat hulls, buggies, bike and nitro on-road. please link below for pics and specs. thanks!
sulit.com.ph/index.php/view+classifieds/id/3919430/RC+Buggy+Bike+and+Boat
LF
looking for spektrum DX6i 2nd hand, with or w/o rx. reasonable price and good condition. 09178333590 pls include location and handle when texting...
looking for 2nd hand tx/rx
a newbie looking for 2nd hand tx/rx for 1/10 rc drift and battery, all in good working condition..pm me for offers, thanks
FS/FT
FS/FT: 4-STROKE NITRO OS FS SERIES ENGINE
FOR 5K NEGOTIABLE AND OPEN FOR SWAP/TRADE
- MODEL FS-40 SURPASS
- WITH FUEL TANK
- WITH TORNADO PLANE PROP
OR SWAP TO 100-200AMP MARINE/WATERPROOF ESC
OR SWAP TO 3655 OR HIGHER MARINE BL MOTOR
OR SWAP TO BL COMBO WITH REVERSE FOR 1:10 CAR
0922-860-5019 NAP
*****Pictures on page 1969*****
- WITH FUEL TANK
0922-860-5019 NAP
LOOKING FOR
Mga Sir,
I'm looking for DEANS PLUG for Y harness.
Please txt or PM me your offers.
09174299993
Salamat RCTECH.
09174299993
Salamat RCTECH.
still available
selling this item. for ep conversion po sana. kaso lang medyo kinapos ang budget for this one. just upgraded my pc kasi. di ko po alam specific model nito
selling for P4,500.00.. buyer handles the shipping fee.
Item is in Iloilo City.
Also open for swap with the following:
1. A BL combo that can be used to a 1/8 onroad car.
2. A Paired 2.4 RXTX and High Torque Servo - that can be used on my ACME Crawler
body is already old and bashed included in the package.
with motor mount already. motor in the picture not included in this sale. all you need are your electronics and you are good to go.
pm or text me at 0908 4703723 smart or 0932 3356326 sun
thanks rctech!
thanks rctech!
rc boat parts and lipo batteries
PM or Call 09175197191- Bong
For Sale Brand new Servos
Turnigy MG958 Composite Digital Metal Gear Servo 15kg / 65g / 0.2sec
SOLD OUT
TGY-MG958 spec.
Control system: +pulse width control 1520usec neutral
Required pulse: 3-5V peak to peak square wave
Operating voltage: 4.8V
Operating temperature range: -20~+60C
Operating speed: 0.2sec / 60 degree at no load
Stall torque @ 4.8V: 166 oz/in. (12.0kg.cm)
Stall torque @ 6.0V: 200 oz/in. (15.0kg.cm)
Operating angle: 45 deg. one side pulse travelling 400usec
Direction: Counter clockwise/pulse travelling 1520-1900usec
Motor type: Coreless motor
Potentiometer drive: Indirect drive
Bearing type: Dual ball bearing
Gear type: All metal gears
Connector wire length: 12in
Dimensions: 40.2 x 20.1 x 36.8mm
Weight: 2.24oz. (65g)
P1500.00 each
SOLD OUT
The Mad Max of servos.
Milled from a single block of 6061 alloy*, this servo screams "crazy tough"!
The milled alloy MG959 carries as much attitude as it does torque and robustness.
No amount of R/C truck bashing or plane crashes will distort this servos case.
It includes accessories and has dual ball bearings and metal gearing.
TGY-MG959 spec.
Weight: 2.64oz. (75g)
P2,000.00 each
Turnigy 12v Electric Fuel Pump P800.00 each (3 units only)
Suits Nitro and Gasoline
Specs.
Input: 12v
Size: 90mm x 49 x 37mm
P2,800 SOLD
An advanced and powerful charger, the Turnigy A6-10 is able to charge, balance and discharge Lion, LiPo, LiFe (A123), NiCd and NiMH batteries on a maximum output power of 200W. It can charge or discharge up to 18 cells of NiCd / NiMH and 6 series of lithium batteries with maximum current of 10A. It can accept three types of Lithium batteries (Lilo/Lipo/LiFe).
Features;
Microprocessor controlled
Delta-peak sensitivity
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 5 packs in memory)
Battery break in and cycling.
Spec.
Input Voltage: 10~18v
Circuit power: Max Charge: 200W / Max Discharge: 25W
Charge Current Range: .1~10.0A
Discharge current range: .1~5.0A
Ni-MH/NiCd cells: 1~18
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~24v
Weight: 540g
Dimensions: 143x124x37mm
SOLD OUT
Spec.
Capacity: 5300mAh
Voltage: 2S2P / 2S Cell / 7.4V
Discharge: 50C Constant / 100C Burst
Weight: 295g (including wire & case)
Dimensions: 138x47x25mm
Balance Plug: JST
Discharge Plug: 4mm Bullet-connector to your own custom plug
P2,700 each
SOLD OUT
Spec.
Minimum Capacity: 5000mAh
Configuration: 2S1P / 7.4v / 2Cell
Constant Discharge: 30C (high voltage hold)
Peak Discharge (20sec): 40C
Pack Weight: 306g
Pack Size: 137.5 x 46 x 25mm
Charge Plug: JST-XH
Discharge plug: 5.5mm Bullet-connector
P2,000 each
SOLD OUT
TGY-MG958 spec.
P1500.00 each
SOLD OUT
TGY-MG959 spec.
P2,000.00 each
Specs.
Input: 12v
P2,800 SOLD
Features;
Time limit function
Spec.
Weight: 540g
SOLD OUT
Spec.
Capacity: 5300mAh
Balance Plug: JST
P2,700 each
SOLD OUT
Spec.
Pack Weight: 306g
Charge Plug: JST-XH
P2,000 each
RC Parts for Sale (1/8th scale monster truck, truggy & buggy)
ITEM: Flysky Reciever
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
Compatible with all flysky 2 and 3 channel radios (GT2, GT3 & GT3B)
number of units: 15
Price: 750
NEW STOCK HAS ARRIVED!!!
Item: Multifunction wheel nut wrench
with 17mm and 23mm hex nut
and 4mm and 5mm hex key
number of units: 3
price: 570
Item: Hex driver set 4pcs
Set includes 1.5, 2.0, 2.5 & 3.0
Price: 650
Item: Scorpion Lipoly Lock Strap 3pcs per pack
length: 300mm
width: 25mm
can be used to hold the battery pack of 600-700 size heli or 1/8th scale electric buggy, truggy or monster truck
Ideal for strapping 4~6S lipo packs
price: 515 per pack
Item: Parallel Charging Board 2s~6s (up to 6 packs)
Balance Charge SIX (2~6S) lipo packs with same capacity & cell count simultaneously using standard lipo chargers.
also available with t-plug type (deans type) terminals
Price: 1670
***pictures at http://ceburc.blogspot.com/ ***
Brand new and used RC parts for sale. (ON HAND)
For inquiries, please text or call to 0922-9661909.
ITEM LOCATION: Cebu
ITEM # 3: Slightly used Hobao monster tires with chrome rims 14mm hex (some curb rash and flaking crome on the rims) tread left 90% - P2250
ITEM # 8: Used 40 series proline crimefighter tires with velocity rims 23mm hex. tread left 85% - P2525
ITEM # 9: Brand new Proline Velocity Rims 14mm hex (set of 2) - P1260
ITEM # 10: Brand new HPI Savage Reverse Module -P2730
ITEM # 11: New HPI Savage XL TVP (Taken from a brand new never used Savage XL) - P2400
ITEM # 12: New HPI Savage XL conversion kit plus front drive shaft and engine mount w/ brace (taken from a brand new never used Savage XL) - P4100
ITEM # 13: Brand new Team TCS 5mm thick Black Flux TVP - P2300
ITEM # 14: Brand new Team TCS 5mm thick Red Flux TVP - P2300
note regarding item 13 & 14:
- these tvp are a good upgrade to the stock tvp, they are so much stronger and looks better than the stock tvp, and they look so much better than the stock!
- http://www.tcscrawlers.com/TCS-5mm-C...d-p-17758.html
- http://www.youtube.com/watch?v=G5vILOPVX54
ITEM # 15: Brand new Racers Edge 1/8 silicone exhaust deflector - P450
ITEM # 16: Brand new HPI Roto Start 2 with shaft (xl length) - P2750
ITEM # 17: Brand new HPI Savage 2 speed transmission (taken from a brand new Savage X 4.6) - P2700
ITEM # 18: Brand new 23mm Hex set (colors available white) - P950
ITEM # 19: Brand new Flux shocks (1 pack contains 2 shocks) P1885
ITEM # 20: Brand new Savage X, XL Battery Box only P625
OR choice of having it with charging jack and switch (taken from a brand new savage xl) P1250
ITEM # 21: Brand new Savage XL Front/Rear Differential assembly with bulk head (taken from a brand new never used Savage XL) P2365
ITEM # 22: Team Losi XXL Shocks (taken from a brand new Losi XXL) set of 2 - P1520
ITEM # 23: HPI Savage X, XL turn buckles (Brand new) P650
ITEM # 24: Used Savage 21/25/X roll cage with mounting hardware (nothing broken, just paint scrapes) - P1350
ITEM # 27: Slightly used Sirio .27 engine 9 port (a small road rash on top of the cooling head) - SOLD (THANX DOC PHILIP)
ITEM # 28: Brand new Top 528XPS engine made by novarossi - SOLD (THANX DOC PHILIP)
ITEM # 29: Brand new ODonnell medium hot glow plugs standard purple long plugs for 25% - 30% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) P270/piece
ITEM # 30: Good as Brand New Hyperion EOS Battery Charger USB Adapter Cable (reference # HP-TI-PRGUSB) (only used 1 time to upgrade my Hyperion EOS0610i NET) - P1200
ITEM # 31: HPI Savage XL engine plate w/ brace (taken from a brand new savage xl) P978
ITEM # 32: HPI Savage XL center dogbones (taken from a brand new savage xl) - P1030
OR choice of having it with cups - P1320
ITEM # 33: CEN 23mm hex (taken from a brand new CEN GST 7.7) - P890
ITEM # 34: HPI Savage Flux complete Bulletproof differential assembly with bulk head, bearings & drive cups (brand new) P3125
ITEM # 35: Venom fuel tubing (OD=6mm ID=3mm) - P55/foot
ITEM # 36: OFNA throttle linkage kit blue (part # 10724) - P690
ITEM # 37: Dynamite Silicone Switch Cover (transparent blue/florescent yellow) 2pcs per pack - P265
ITEM # 39: Mugen MBX6T wing, wing mount & mounting hardware(taken from a brand new kit) P1520
ITEM # 41: Dubro Body Clip retainer w/ 8 body clips - P452
ITEM # 49: Brand New Proline wabash rims 40 series 23mm hex 2 pcs per pack P1155
ITEM # 54: Used standard MT size Proline bowtie tires on 14mm hex aluminum rims MT tires #1079 very good condition tread left 90% - P3560
ITEM # 59: New Team Losi XRT tires w/ Team Losi Dish rims 17mm hex buggy tires P2040
ITEM # 60: GRP TRC 1:8 buggy Cubic tires w/ rims buggy tires tread left 95% - P1635
ITEM # 65: HPI savage 17mm hex and lock nuts (set of 4) - P630
ITEM # 67: HPI savage 14mm hex and lock nuts (set of 4) - P350
ITEM # 68: HPI savage xl extended wheel axles (set of 4) P2115
ITEM # 69: HPI savage xl outer dogbones (set of 4) - P1195
ITEM # 70: Brand new ODonnell hot glow plugs standard red long plugs for 5% - 20% nitro content (for picco, novarossi, rb concept and more, check manual for compatibity) P300
ITEM # 71: HPI Savage xl front and rear skid plates w/ bumpers and Bulkhead Lower Plates - P685
ITEM # 73: RPM Center skidplate for savage x P1215
ITEM # 74: Losi 15mm shock boots for big bores P640
ITEM # 75: Dynamite Fuel filter P512
ITEM # 76: HPI Slipper Clutch Pad P537
ITEM # 77: Du-bro 2-56 safety lock kwik link (clevis) - P245
ITEM # 78: Ofna throttle linkage kit blue (part # 10724) - P255
ITEM # 80: HPI savage x engine protector - P365
ITEM # 81: HPI savage high body mount post & throttle horn - P365
ITEM # 83: HPI cap head screw 2.6x12mm 12pcs - P310
ITEM # 86: RB Concept TM728 standard combustion chamber
ITEM # 87: RB Concept one way bearing
ITEM # 89: Duratrax rotostart backplate - P995
ITEM # 90: RB Concept Headshims for .28 engine thickness available .10mm & .3mm. Can be used with other .28 size engines (sold per pack) - P285
ITEM # 91: RB Concept exhaust gasket P480/pack of 4
ITEM # 92: Dynamite Max-life aluminum clutch shoes P1570
ITEM # 93: Mugen clutch spring 1.0mm - P420
ITEM # 94: Dynamite clutch shim kit - P440
ITEM # 100: Factory Team Shock oil 35wt P240
ITEM # 101: Factory Team Shock oil 50wt P240
ITEM # 102: Factory Team Shock oil 70wt P240
ITEM # 103: CLUTCH BELL BEARINGS NEOPRENE SEAL 5x10x4 - P800/pack of 10
ITEM # 104: AXLE BEARING NEOPRENE SEAL 8x16x5 P700/pack of 10
ITEM # 105: HPI Rotostart Starting shaft- P700
ITEM # 106: Losi tire glue standard - P570
ITEM # 107: CEN Genesis/Nemesis/GST 7.7 Fuel Tank 220cc - P1095
ITEM # 108: HPI Savage Heavy duty servo saver spring - P248
ITEM # 109: RB Concept Aerosol Lubricant - P435
ITEM # 113: New Speedmind transmitter bag for 3pk - P1766
ITEM # 114: Fail safe P750
ITEM # 115: Exhaust gasket P500/pack of 5
ITEM # 116: Exhaust Spring long 240/ pack of 2
ITEM # 117: Antenna tube with silicone end cap (250mm) P85
ITEM # 119: Bones Speed Cream Bearing Lubricant - P465
ITEM # 120: : Integy Heavy Duty Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) - P2370
ITEM # 121: Integy Rear Hub Carrier for HPI Savage purple/silver (pre-X, X, XL, Flux) P1830
ITEM # 122: Castle Creations 6.5mm High Current Bullet Connector P540
ITEM # 123: Brand New Savage XL 3 Speed Transmission - P3875
ITEM # 124: Slightly Used Proline Big Joe Tires on 14mm hex P3160
ITEM # 125: 3Racing Aluminum fuel tank protector for Savage (silver/pruple) P1045
ITEM # 126: NIB JR Digital High Voltage Servo Z9100HVS - P8775
ITEM # 128: NIB Tekin Brushless Truggy Motor T8 TT2361 4038 - P8540
ITEM # 130: CorrosionX 16 oz Trigger Spray Bottles - P1685 - Protects your expensive electronics, will not trap heat within the components unlike Plasti Dip, much safer and easier to use than ballons. See this video ===> http://www.youtube.com/watch?v=6jpSW50cobs
ITEM # 131: NIB Futaba 3pm P9000
ITEM # 132: Used Team Losi XBT Buggy tires w/ Team Losi Dish rims 17mm hex. 2 tires 97% tread, 2 tires 90% tread P1480
ITEM # 133: Used Team Losi Eclipse Buggy tires w/ 17mm hex. 85% tread P1520
ITEM # 134: Brand NewPro-Grip Performance Devices buggy tires & rims 17mm hex - 1940
ITEM # 136: Brand New Proline Step-up buggy tires & dish rims P1790
ITEM # 140: Used Proline Hole shot (#9026) w/ losi rims 17mm hex tread left 95% - P1385
ITEM # 143: Used Losi XTT truggy tires w/ Losi dish rims 17mm hex. 75% tread P1260
ITEM # 144: Used Proline 40 series Crime Fighter Tires w/ proline dish rims 23mm hex. 80% tread P2315
ITEM # 145: Brand New Airtronics 94758z digital highspeed/high torque digital metal gear servo Torque 92 / 115 Oz In @ 4.8 / 6.0V Speed 0.07 / 0.06 sec @ 4.8 / 6.0 V P3485
ITEM # 146: Brand New HiTec 5996TG Digital Servo Torque: 89/111 oz @ 4.8/6.0V Speed: 0.13SEC/0.10 sec @ 4.8/6.0V P3185
ITEM # 147: HPI Machined Bulletproof Diff Gear Set P2350
ITEM # 148:Savage x/xl/flux upper and lower arms with pins (pair) P880
ITEM # 149:Savage x ss adjustable upper arms (set of 4) P725
ITEM # 150:Hobao D8/T wing & wing mount P1055
ITEM # 151:Savage 25/x/ss/flux center drive shaft P635
ITEM # 152:NEW HPI Savage X Roll Bar,Handle,Engine Protector P685
ITEM # 153:Savage X SS Clear Body with complete decals and antenna tube - P2125
ITEM # 154: HPI Savage Battery Level Indicator P1967
ITEM # 155: Panther Buggy Tires MT998SY Switch on yellow rims 17mm hex (set of 4) - P1885
ITEM # 156: Panther Buggy Tires MT945MSY Boa on yellow rims 17mm hex (set of 4) - P1885
ITEM # 157: Brand New XTM XT2E BUGGY 17mm Blade Wheels Rally Cross Tires P1920
ITEM # 158: HPI Exhaust Coupling 12x18x30mm (PN 87040) P389
ITEM # 159: HPI Slipper Clutch pad (PN 72131) P340
ITEM # 160: HPI Differential Case Washer 0.7mm (PN 86099) - P240
ITEM # 161: Exhaust manifold spring: 110/ pack of 3
Shipping details:
- Additional shipping charges apply
- Payment must be made through BDO prior to shipping
- Payment may also be made through PAYPAL (Customer add 3.6% of the total amount to cover the paypal fees)
- Once payment is verified, items will be Shipped through Air21 unless the buyer make other arrangements
- A tracking number will be provided for buyers reference
We accept orders for hard to find parts (please txt or call if you need more details)
THANX RCTECH !!!
Model: FS-GR3C
Channels: 3
Frequency: 2.4Ghz
number of units: 15
Price: 750
number of units: 3
price: 570
Price: 650
length: 300mm
width: 25mm
price: 515 per pack
Price: 1670
ITEM LOCATION: Cebu
Shipping details:
THANX RCTECH !!!
