View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
ADDED ITEMS:
PROTOFORM BODY STRATUS ALL-PURPOSE P520
-RACE WORTHY
-2PCS AVAILABLE
PROTOFORM BODY MAZDA 6 P520
-RACE WORTHY
RIDE BODY ACCORD P520
-RACE WORTHY
HPI RACING SUSPENSION SHAFT 3X45mm P380
-BNEW IN PLASTIC
-TITANIUM NITRIDE COATING
-CYCLONE, HELLFIRE/SS
3RACING MOTOR/ESC FAN P150
-USE ONCE
TAMIYA ALUMINUM SERVO MOUNT TA-05 P180
-USE ONCE
MABUCHI SILVER CAN MOTOR P450
-BNEW
TEAM LOSI JRX-S SWAY BAR PLASTIC ONLY P150
-BNEW IN PLASTIC
-PART #LOSA4253
SOREX 24mm MOLDED TIRE INSERTS 2 SETS P250
-BNEW IN PLASTIC
-TYPE C MEDIUM
FOR SALE:
LRP BRUSHLESS MOTOR X12 VECTOR 4.0 P2,950
-SINTERED MAGNET 12.5mm
-PRECISENSOR SYSTEM
-BOX AND MANUAL
NOVAK BRUSHLESS MOTOR SINTERED 10.5 P2,150
-USE ONCE
LRP TC SPEC BRUSHED/BRUSHLESS ESC P7,000
-PRISTINE CONDITION
-ORIGINAL WIRES
-BOX AND MANUAL
HPI RACING CYCLONE/TC FOAM MINI BUMPER P150
-BNEW
-2PCS AVAILABLE
HPI RACING BRUSHED MOTOR 23T P550
-USE ONCE
-TYPE SLF
HPI RACING SET REAR AND FRONT ARMS P450
-BNEW
-FOR CYCLONE/TC
-2PCS REAR AND 1PC FRONT
HPI RACING DIFF SCREW 2PCS P220
-BNEW IN PLASTIC
-CYCLONE TC, CYCLONE D4
-M2x25mm
ALUMINUM MOTOR HEATSINK P180
-USE ONCE
-AVAILABLE COLORS SILVER, PURPLE AND BLACK
TEAM ASSOCIATED TC5 CASTER BLOCK P180
-BNEW IN PLASTIC
-4 DEG
-PART # 31212
TEAM ASSOCIATED TC5 ONEWAY W/ BEARING P650
-BNEW IN PLASTIC
-PART #31177
EXPRESS BRUSHED MOTOR 27T P450
-RACE WORTHY
TAMIYA ALUMINUM HEATSINK P650
-PRISTINE CONDITION
-COLOR BLUE
SANWA FM RF MODULE P550
-BNEW
-FM 40 MHZ (73)
-FOR M8 AND M11
SANWA Ni-Cd WALL CHARGER P450
-BNEW
-INPUT 230v AC
TEAM LOSI KEVLAR SPUR GEAR JRX-S P150
-BNEW
-128T/64P
-2 PCS AVAILABLE
TEAM LOSI ASSORTED STABILIZER BAR JRX-S P250
-BNEW
-5PCS
ORIGINAL NECK STRAP SANWA P500
-USE ONCE
-AVAILABLE COLORS GREEN AND BLUE
ORIGINAL NECK STRAP KO PROPO P650
-USE ONCE
-COLOR BLUE
TRINITY BRUSH BUTCHER P1,800
-USE ONCE
-WITH SLAVE MOTOR 23T
NOVAK FLATLINE DISCHARGER P350
-DEAD SHORT STORAGE TRAY
-INDIVIDUAL CELL DISCHARGE CIRCUITRY
-NON-POLARIZED CIRCUITRY
-Ni-MH & Ni-Cd
BATTERY COOLING STAND P350
-DUAL FAN
-HEAVY DUTY
PICK UP: 112 D.TUAZON ST., Q.C. NEAR BANAWE AREA
CALL/TEXT 0917-5295252, 0922-8312255 or 353-0800
-RACE WORTHY
-2PCS AVAILABLE
-RACE WORTHY
-RACE WORTHY
-BNEW IN PLASTIC
-USE ONCE
-USE ONCE
-BNEW
-BNEW IN PLASTIC
-PART #LOSA4253
-BNEW IN PLASTIC
-TYPE C MEDIUM
FOR SALE:
-PRECISENSOR SYSTEM
-BOX AND MANUAL
-USE ONCE
-PRISTINE CONDITION
-ORIGINAL WIRES
-BOX AND MANUAL
-BNEW
-2PCS AVAILABLE
-USE ONCE
-TYPE SLF
-BNEW
-FOR CYCLONE/TC
-BNEW IN PLASTIC
-M2x25mm
-USE ONCE
-BNEW IN PLASTIC
-4 DEG
-PART # 31212
-BNEW IN PLASTIC
-PART #31177
-RACE WORTHY
-PRISTINE CONDITION
-COLOR BLUE
-BNEW
-FM 40 MHZ (73)
-FOR M8 AND M11
-BNEW
-INPUT 230v AC
-BNEW
-128T/64P
-2 PCS AVAILABLE
-BNEW
-5PCS
-USE ONCE
-USE ONCE
-COLOR BLUE
-USE ONCE
-Ni-MH & Ni-Cd
-DUAL FAN
-HEAVY DUTY
gud pm po... baka may E Maxx or E savage kayo jan ..
txt n lng p[o 09214088245
HongNor Pro X2CR Buggy
Slightly used Hongnor Pro X2CR Buggy
with Novarossi 367 Engine
with Novarossi 8573 pipe
with Sanwa M11 2.4ghz Radio
with Sanwa ERG-WX Servos
with Sanwa Reciever
with 1600nimh reciever battery
with New set of tires
with extra spare parts
with New body shell
All for 24k only!
0917-8903168
Used 6 times only
with Sanwa Reciever
with New body shell
All for 24k only!
0917-8903168
Used 6 times only
FOR SALE:
Stock SC10 ESC with Tamiya 23t RZ motor
*Used but in very good condition.
*Motor was never cut or opened yet.
*ESC and motor was used for only 4 races.
Php 1000
Losi 8ight 1.0/2.0 Parts Lot
*used parts (these are used but I assure you they are in very very good condition. I installed them but took them out after just one race because I sold my 8ight-T to get the 2.0. Never got to install them on my 8ight-T 2.0 then after) Take note of the item with red notes though.
-Aluminum Front Spindles http://www.losi.com/Products/Feature...rodId=LOSA1708
-Aluminum Front Spindle Carriers http://www.losi.com/Products/Feature...rodId=LOSA1711
-Adjustable Front Hinge Pin Braces w/ Inserts http://www.losi.com/Products/Feature...rodId=LOSA1754
-Adjustable Rear Hinge Pin Braces w/ Inserts http://www.losi.com/Products/Feature...rodId=LOSA1755
-Aluminum Front Chassis Brace http://www.losi.com/Products/Feature...rodId=LOSA4416
-Aluminum Rear Chassis Brace(one of the holes that attaches to the chassis has a seared bolt stuck inside)http://www.losi.com/Products/Feature...rodId=LOSA4417
-Aluminum Front Top Brace http://www.losi.com/Products/Feature...rodId=LOSA4440
-Quick Change Engine Mount Set http://www.losi.com/Products/Feature...rodId=LOSA9155
-3x Losi Heavy Duty Differential Cases http://www.losi.com/Products/Feature...rodId=LOSB3528
-Losi 15T HD Clutch Bell
*BNEW in plastic parts
-Losi HD Clutch Bell 14T LOSA9117
-Losi Clutch Springs, Silver LOSA9115
-Losi Clutch Shoes, Lightened Aluminum (2) LOSA9108
-Losi Clutch Shoes, Composite LOSA9107 (2) LOSA9107
-Losi Rear Diff Ring Gear 43T, 8T/2.0 LOSA3512
-Losi Diff Pinion gear 10T, 8T/2.0 LOSA3507
-Losi Diff gear and Shaft Set LOSA3502
-All these parts will fit in the 2.0 kits.
-Will NOT sell individually
RFS: Changing kits.
Php 5000 for everything (a bargain considering all of these cost ~$350 already)
Bnew Maxx Sized Tires
*Bnew never used
*I don't know what brand they are
*NO inserts included
RFS: no kit to use it for
Php 500
Hyper ST pro body braces
*New in plastic
Php 100
Losi Excellorin USB Programmer
*New in plastic
*RFS: I thought it would work with the 1/36th scale BL ESC. Turned out it doesn't.
Php 300
Call/Txt: 09178113399/09228076343
Kevin Cua
Php 1000
RFS: Changing kits.
*Bnew never used
Php 500
*New in plastic
Php 100
*New in plastic
Php 300
Kevin Cua
Lookig For
Buying a 1/16 drift car, Tamiya, Silverlit, any brand, yung mura lng po, pm me nlng po,
Locaion: METRO MANILA or BATANGAS
[QUOTE=kennethM.;7351380]FOR SALE LOSI STRIKE SHORT COURSE TRUCK, A
BNEW ARMS FOR MUGEN MBX5T.. 1K SET
Pls. visit our website
www.cyclonetoy.com
www.alphamodel.ucoz.com
for inquire Globe 09164306651
New Airplane By order free shipping
http://www.sdshobby.com/carbon-fiber...ne-p-1264.html
http://www.sdshobby.com/carbon-fiber...ne-p-1262.html
Carbon Fiber Version Sbach 342 30cc ARF Plane 16,000 php
Black red and white color avail.
NOW Available !!!!
Limited stock only
[color=red]High-Voltage Mega Torque HS-7950TH: Universal 3,800 pesos each free shipping In Stock
Key Features
Generation 2 Digital Circuit
Titanium Gear Train (MK first gear)
Ultra Performance Coreless Motor
Heatsink Case
(8) O-Rings for Water/Dust/Fuel protection
Dual Ball Bearing Supported Output Shaft
*** Programmable Features Include: ***
Dead Band Width
Direction of Rotation
Speed of Rotation (slower)
End Points
Neutral Points
Fail Safe On/Off
Fail Safe Point
Resolution* (default is high resolution)
Overload Protection* (default is off)
*These features are only programmable with the HFP-20 (#44430), HPP-20 or HPP-21 (#44440) programmers.
Overview
the "Ultra Torque" HS-7950TH is designed to operate on a two cell LiPo Pack. Featuring our high resolution "G2" second generation programmable digital circuit and our indestructible Titanium gears, The HS-7950TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7050TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
The HS-7950TH has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 403oz./in. of torque at 6.0 volts, while still maintaining a respectable 0.15 second transit time
Motor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed (6.0V/7.4V): 0.15 / 0.13
Torque oz./in. (6.0V/7.4V): 403 / 486
Torque kg./cm. (6.0V/7.4V): 29.0 / 35.0
Size in Inches: 1.57 x 0.79 x 1.50
Size in Millimeters: 39.88 x 20.07 x 38.10
Weight oz.: 2.40
Weight g.: 68.04
Hitec 7955TG in stock 3,500 Free shipping
Aluminum gasolone filter 750.00 each ship
Great plane easy sport 40 kit 3,500 reprice 2,800
SPECIFICATIONS
Stock Number: GPMA1036
Wingspan: 59.2 in (1505 mm)
Wing Area: 750 in² (48 dm²)
Weight: 5.5-6.5 lb (2500-2950 g)
Wing Loading: 18-21 oz/ft² (55-64 g/dm²)
Length: 50 in (1270 mm)
Engine Required: 2-stroke .40–.50 cu in or 4-stroke .52–.70 cu in
Radio Required: 4-channel with 4 servos
Yak55M 50cc Fire color scheme ARF Plane 21,500in stock
Wing Span----86.6in/2200mm;
Wing Area----94sq.dm;
Fuselage Length----85.5in/2172mm;
Flying Weight:7300----7700g;
Radio----6Channels 6Servos;
Engine----50CC
Monokota Covering
carbon fiber wing tube
Carbon fiber rear lading gear
canister channel
high quality hard ware
New DLE55 55CC Gasoline Engine 16,500 in stock
1.The Cylinder and Crank Case made by new Technology-Compression Molding!
2.Electromagnetic shielding Sensor;
New DLE30 30cc gasoline engine 13,500 [B[/B] instock
Imax b5 brandnew complete 2.300 php free shipping
Accesories
Volts Monitor TM (DC 3.7-20V LCD VOLTMETER 1,750.00.00
Opto Gas Engine Kill Switch 700.00
3 BLADE aluminum Spinner 3.5" 1,100.00
ALUMINUM SPINNER 3" 1,100.00 ship
Tower Pro Battery Watcher 4.8v to 6v 450.00 eac. Sold out
Gasoline fuel host 50.00/ft
nitro fuel host 70.00 /ft
Fueltank for nitro and gas 1000CC 190x95x77(mm) Sold out
fuel tank for nitro and gas 500cc 450.00
Max Power Lipo For Transmitter Spektrum/Futaba/JR radio sold out
http://www.cyclonetoy.com/list_1.asp?id=1216
Heavy duty servo cable 300mm 100.00 ea.
Heavy duty servo cable 600mm 150.00 ea.
5 amp Power supply for B6 and B5 sold out
Hinges 500.00 set (20pcs)
T plug connector 3 pcs set male and female 150.00
Program card 450.00
http://www.cyclonetoy.com/list_1.asp?id=122
Telemetry Combo Pack 2,800,000
Key Features
* Monitors temperature to maximize performance and eliminate costly rebuilds
* Battery voltage display prevents runaway crashes
* RPM display shows top-end speed
* Quality of signal monitors RF link strength
* Lap Counter/Timer helps analyze results of performance tweaks
Heat shrinkable tube for battery
size 4"x19" 140.00
2.5"x19" 110.00
prop adapter free shipping
size 5mm shaft 650.00
4mm shaft 530.00
3.17mm shaft 530.00
Pull-Pull system for giant scale 1 set 650.00 free shipping
Nitro spinner
size 2" 250.00 each
prop. nut spinner
3/8" 450.00
Need boat and elec to nitro helicopter All item are free shipping visit www.cyclonetoy.com
Nitro helicopter
Aeolus 50 3D GF Glass Fiber Nitro helicopter Kit new 11,350.00
Aeolus 50 3D CF Carbon Fiber Nitro Helicopter Kit new 15,800.00
Aeolus 50 3D SV Carbon Fiber Nitro Helicopter Kit new 18,000.00
Flasher 600N GF Glass Fiber Nitro Plane(Compatible with Trex) new 17,500.00
Gasoline Boat
Volvo Gasoline 26CC Boat-Blue 19,500.00
Volvo Gasoline 26CC Boat-Silver 19,500.00
Volvo Gasoline 26CC Boat-Multicolor 19,500.00
Challenger Gasoline 26CC Boat-Yellow 19,700.00
Challenger Gasoline 26CC Boat-White 19,700.00
New Challenger Gasoline 26CC Boat length:128cm 19,700.00
Yamaha Gasoline 26CC Boat-Yellow 19,700.00
Yamaha Gasoline 26CC Boat-Blue 19,500.00
Yamaha Gasoline 26CC Boat-Multicolor 19,500.00
Yamaha Gasoline 26CC Boat-White&Orange 19,500.00
Yamaha Gasoline 26CC Boat-White&Black 19,500.00
Gasoline Boat With 26CC-Red &Yellow 21,500.00
RC Gasoline Boat With 26CC-Red 21,500.00
RC Gasoline Boat With 26CC-Green 21,500.00
RC Gasoline Boat with 26cc-Blue 21,500.00
RC Gasoline Boat With 26CC-Orange 21,500.00
RC Gasoline Boat With 26CC-Red&White 21,500.00
Navigator 26cc gasoline boat-Blue 19,700.00
Navigator 26cc gasoline boat-Red 19,700.00
Navigator 26cc gasoline boat-White&Blue 19,700.00
Super race boat 26cc 20,200.00
New 26cc Spider Gasoline Boat 20,200.00
26cc Gasoline Boat Turbo Bat 20,200.00
Queen 26CC Gasoline Boat 23,500.00
Blade 26CC Gasoline Boat With Zenoah Engine 23,300.00
Osprey 26CC Gasoline Boat With Zenoah Engine-white 23,300.00
Osprey 26CC Gasoline Boat With Zenoah Engine-yellow 23,300.00
Shark 33CC Gasoline Engine RC Boat 26,000.00
Electric Helicopter
KING 450SV 6CH Helicopter RTF Aluminum box 13,500.00
KING 450SV 6CH Helicopter RTF --2.4GhzAluminum box 15,000.00
KDS450S ---with special flymentor --Plastic Version (2.4G RTF) 16,500.00
KDS450S ---with Gyro --Plastic Version (2.4G RTF) 14,500.00
KDS 450C ---with special flymentor --Glass Fiber Version (2.4G RTF) Aluminum box 22,350.00
KDS 450C with Gyro Glass Fiber Version ( 2.4G RTF) Aluminum box 18,300.00
KDS 450C ---with Motor & ESC only--Glass Fiber Version 12,300.00
KDS450SV ---with special flymentor --Carbon Fiber Version (2.4G RTF)Aluminum box 22,950.00
KDS450SV ---with Gyro --Carbon Fiber Version(2.4G RTF)Aluminum box 18,600.00
KDS450SV with Motor & ESC only Carbon Fiber Version Aluminum box 12,800.00
500 Gfcpe Helicopter kit 13,800.00
www.cyclonetoy.com
NOW Available !!!!
Limited stock only
Key Features
Heatsink Case
Dead Band Width
End Points
Neutral Points
Fail Safe On/Off
Fail Safe Point
Overview
Weight oz.: 2.40
Weight g.: 68.04
SPECIFICATIONS
Engine----50CC
Monokota Covering
canister channel
Accesories
Program card 450.00
Key Features
size 4"x19" 140.00
2.5"x19" 110.00
4mm shaft 530.00
3.17mm shaft 530.00
Nitro spinner
size 2" 250.00 each
prop. nut spinner
3/8" 450.00
Nitro helicopter
Gasoline Boat
Electric Helicopter
item for sale is on hold...
[QUOTE=Armstrong;7390204]FOR SALE:
Php 1000
sir, pwede ba pa reserve till sunday? tnx
Php 1000
hex set
looking for hex tool set.
2ndhand or brandnew, yung mura lang sana.
pa pm nalang. thanks!
-------------------THANK YOU---------------------
