View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
sa
SELLING:
TEAM ORION ADVANTAGE CHARGER (NiMH/NiCd/LiPo) 2.5K ONLY
* Charge 1 to 8 cells (2 cells Li-Po)
* 50 to 5400 mAh NiMH and NiCd batteries at 1 to 10 Amps
* 11 to 15 volts D/C input
* Customizable Linear, Flex and Step charging
* NEW LiPo charge function
* 5 charging memories
* Battery cycling
* Discharge at 1 or 10 amps
* Input and output short circuit Protection
* Attachable battery charging tray
* Full motor run-in feature
* Powers commutator lathes
* Full manual lap counting functions and displays:
* time elapsed, average lap time and number of laps
* Indigo Blue backlight 2 x 16 characters display
* Customizable user name
* English, German, French and Japanese displays
* Easy to navigate, 4 push button settings
* Choice of 3 different alarm tones or silent function
* Silicone output wires
* Built in Clock
* High tech carbon fiber look case
KO PROPO EX-10 HELLIOS 6K ONLY
http://www.kopropo.com/america/index...d=34&Itemid=88
* 1pc KR-302F super micro 3ch reciver
* 1pc ko propo 40mhz FM module
* 1 pair 40.083 xtals
* 8cell battery holder
BNEW Venom VR3T 3CH FM Radio 27mhz 2k only
Specifications:
* 3-Channel Computerized FM Radio
* 3rd Channel Mixing
* 15 Model Memory
* Programmable Steering Dual Rate
* Throttle Hold
* Built-in Fail Safe
* Adjustable Throttle and Steering Curves
* 4 Ch micro Receiver
* End Point Adjustment (EPA)
BNEW RAPICON FUEL 20% surface 1.2k only
* BNEW (as in walang bawas)
LOOKING FOR:
2s 7.4v LiPo batt
Length: 2.81" (71.5mm)
Height: 1.00" (25.5mm)
Width: 0.68" (17.2mm)
800mah above, bnew or 2nd hand as long it meets the size i want
same size na pang transmiter pero 2s
:t ire:
RFS: additional funds pang hilamos ng auto (pra pogi)
-GET ALL?? ill give for free bnew 8pcs AA 1800mah nimh for tx
-all items are used but not abused and well kept (unless specified)
-accepting shipping but buyers handles the shipping cost
-pm me if you have any question, txt me if you're sure to buy it
-spec's are all stated and provide links for reviews
-09282155035 molly
* Battery cycling
* Built in Clock
Specifications:
* 15 Model Memory
* Throttle Hold
LOOKING FOR:
2s 7.4v LiPo batt
:t ire:
-09282155035 molly
Still Looking for 2.4ghz Tx w/ Rx.
-Budget is between 1.8k to 3k depending on Tx Rx type and brand.
-Gun type only.
-Analog type lang po and no need for an LCD equipped Tx.
-Seller willing to ship the item to batangas.
PM me for your offers. Thanks!
-Gun type only.
Sir Edward Angtuaco (dtn324) thanks dun sa BL system.. mabait ka deal si sir at madali kausap, pumayag kahit 2 gives.. thumbs up for you sir.
also looking for:
--> CYCLONE S main chassis (tub chassis).. text me at 09398852792
also looking for:
LF: Rally block tires and wheels/ Radial Set of four
kahit gamit na!
please text me at 09163210053 for offers... im not always online thanks!
kahit gamit na!
Sir Ian... ikaw ba yung owner nung dating hobby shop sa Caedo?
The track will be in Mangoville Subdivision Phase I, Manghinao Proper Bauan Batangas. Presently, my brother Ian (Katukayo mo) and his friends are making the track into shape. Medyo madamo pa eh.
Once my vacation is approved this July, full construction of an OFFROAD TRACK will commence.
RC Stuff
FOR SALE:
HongNor X2CR Pro Buggy - P15,500
-slightly used buggy
-w/ Novarossi 367 Engine
-w/ 1600mah intellect reciever Battery
-w/ 2 Sets Tires (1Bnew)
Sanwa M11 2.4ghz Radio - P9,500
-w/ RX Reciever
-w/ 2 Sanwa WX Digital Servos
-w/ Rechargeable Battery Pack
Novarossi Plus 4 Engine - P6,500
-tight compression
-gauranteed no hidden defects
Q-World Strater Box - P2,800
-in excellent condition
-w/ 2 packs 4200mah NiMH Intellect Batteries
-complete and unused accessories
-w/ free Intellect Igniter Starter w/ charger
PLS CALL OR TEXT AT 09178903168
-w/ RX Reciever
-tight compression
P 51 Mustang Sport 60 with retracts - All Balsa ARF
FOR SALE
Brand new P 51 Mustang Sport 60 with retracts - All Balsa
P 11,500.00
Text or Call 09189244328
P 11,500.00
for sale 1 week old Esky LAMA V4 2.4ghz edition with yellow xtreme blade upgrade. attached pic is the exact color (for reference only)
selling for 3.2k slightly negotiable
Reach me @ 09163734082 or pm me. Pickup or meet-up (ortigas or qc area)
RFS: need money - SOLD! thanks RCTech
Pls. visit our website
www.cyclonetoy.com
www.alphamodel.ucoz.com
for inquire Globe 09164306651
New Airplane By order free shipping
http://www.sdshobby.com/carbon-fiber...ne-p-1264.html
http://www.sdshobby.com/carbon-fiber...ne-p-1262.html
Carbon Fiber Version Sbach 342 30cc ARF Plane 16,000 php
Black red and white color avail.
NOW Available !!!!
Limited stock only
[color=red]High-Voltage Mega Torque HS-7950TH: Universal 3,800 pesos each free shipping In Stock
Key Features
Generation 2 Digital Circuit
Titanium Gear Train (MK first gear)
Ultra Performance Coreless Motor
Heatsink Case
(8) O-Rings for Water/Dust/Fuel protection
Dual Ball Bearing Supported Output Shaft
*** Programmable Features Include: ***
Dead Band Width
Direction of Rotation
Speed of Rotation (slower)
End Points
Neutral Points
Fail Safe On/Off
Fail Safe Point
Resolution* (default is high resolution)
Overload Protection* (default is off)
*These features are only programmable with the HFP-20 (#44430), HPP-20 or HPP-21 (#44440) programmers.
Overview
the "Ultra Torque" HS-7950TH is designed to operate on a two cell LiPo Pack. Featuring our high resolution "G2" second generation programmable digital circuit and our indestructible Titanium gears, The HS-7950TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7050TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
The HS-7950TH has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 403oz./in. of torque at 6.0 volts, while still maintaining a respectable 0.15 second transit time
Motor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed (6.0V/7.4V): 0.15 / 0.13
Torque oz./in. (6.0V/7.4V): 403 / 486
Torque kg./cm. (6.0V/7.4V): 29.0 / 35.0
Size in Inches: 1.57 x 0.79 x 1.50
Size in Millimeters: 39.88 x 20.07 x 38.10
Weight oz.: 2.40
Weight g.: 68.04
Hitec 7955TG in stock 3,500 Free shipping
Aluminum gasolone filter 750.00 each ship
Great plane easy sport 40 kit 3,500 reprice 2,800
SPECIFICATIONS
Stock Number: GPMA1036
Wingspan: 59.2 in (1505 mm)
Wing Area: 750 in² (48 dm²)
Weight: 5.5-6.5 lb (2500-2950 g)
Wing Loading: 18-21 oz/ft² (55-64 g/dm²)
Length: 50 in (1270 mm)
Engine Required: 2-stroke .40–.50 cu in or 4-stroke .52–.70 cu in
Radio Required: 4-channel with 4 servos
Yak55M 50cc Fire color scheme ARF Plane 21,500in stock
Wing Span----86.6in/2200mm;
Wing Area----94sq.dm;
Fuselage Length----85.5in/2172mm;
Flying Weight:7300----7700g;
Radio----6Channels 6Servos;
Engine----50CC
Monokota Covering
carbon fiber wing tube
Carbon fiber rear lading gear
canister channel
high quality hard ware
New DLE55 55CC Gasoline Engine 16,500 in stock
1.The Cylinder and Crank Case made by new Technology-Compression Molding!
2.Electromagnetic shielding Sensor;
New DLE30 30cc gasoline engine 13,500 [B[/B] instock
Imax b5 brandnew complete 2.300 php free shipping
Accesories
Volts Monitor TM (DC 3.7-20V LCD VOLTMETER 1,750.00.00
Opto Gas Engine Kill Switch 700.00
3 BLADE aluminum Spinner 3.5" 1,100.00
ALUMINUM SPINNER 3" 1,100.00 ship
Tower Pro Battery Watcher 4.8v to 6v 450.00 eac. Sold out
Gasoline fuel host 50.00/ft
nitro fuel host 70.00 /ft
Fueltank for nitro and gas 1000CC 190x95x77(mm) Sold out
fuel tank for nitro and gas 500cc 450.00
Max Power Lipo For Transmitter Spektrum/Futaba/JR radio sold out
http://www.cyclonetoy.com/list_1.asp?id=1216
Heavy duty servo cable 300mm 100.00 ea.
Heavy duty servo cable 600mm 150.00 ea.
5 amp Power supply for B6 and B5 sold out
Hinges 500.00 set (20pcs)
T plug connector 3 pcs set male and female 150.00
Program card 450.00
http://www.cyclonetoy.com/list_1.asp?id=122
Telemetry Combo Pack 2,800,000
Key Features
* Monitors temperature to maximize performance and eliminate costly rebuilds
* Battery voltage display prevents runaway crashes
* RPM display shows top-end speed
* Quality of signal monitors RF link strength
* Lap Counter/Timer helps analyze results of performance tweaks
Heat shrinkable tube for battery
size 4"x19" 140.00
2.5"x19" 110.00
prop adapter free shipping
size 5mm shaft 650.00
4mm shaft 530.00
3.17mm shaft 530.00
Pull-Pull system for giant scale 1 set 650.00 free shipping
Nitro spinner
size 2" 250.00 each
prop. nut spinner
3/8" 450.00
Need boat and elec to nitro helicopter All item are free shipping visit www.cyclonetoy.com
Nitro helicopter
Aeolus 50 3D GF Glass Fiber Nitro helicopter Kit new 11,350.00
Aeolus 50 3D CF Carbon Fiber Nitro Helicopter Kit new 15,800.00
Aeolus 50 3D SV Carbon Fiber Nitro Helicopter Kit new 18,000.00
Flasher 600N GF Glass Fiber Nitro Plane(Compatible with Trex) new 17,500.00
Gasoline Boat
Volvo Gasoline 26CC Boat-Blue 19,500.00
Volvo Gasoline 26CC Boat-Silver 19,500.00
Volvo Gasoline 26CC Boat-Multicolor 19,500.00
Challenger Gasoline 26CC Boat-Yellow 19,700.00
Challenger Gasoline 26CC Boat-White 19,700.00
New Challenger Gasoline 26CC Boat length:128cm 19,700.00
Yamaha Gasoline 26CC Boat-Yellow 19,700.00
Yamaha Gasoline 26CC Boat-Blue 19,500.00
Yamaha Gasoline 26CC Boat-Multicolor 19,500.00
Yamaha Gasoline 26CC Boat-White&Orange 19,500.00
Yamaha Gasoline 26CC Boat-White&Black 19,500.00
Gasoline Boat With 26CC-Red &Yellow 21,500.00
RC Gasoline Boat With 26CC-Red 21,500.00
RC Gasoline Boat With 26CC-Green 21,500.00
RC Gasoline Boat with 26cc-Blue 21,500.00
RC Gasoline Boat With 26CC-Orange 21,500.00
RC Gasoline Boat With 26CC-Red&White 21,500.00
Navigator 26cc gasoline boat-Blue 19,700.00
Navigator 26cc gasoline boat-Red 19,700.00
Navigator 26cc gasoline boat-White&Blue 19,700.00
Super race boat 26cc 20,200.00
New 26cc Spider Gasoline Boat 20,200.00
26cc Gasoline Boat Turbo Bat 20,200.00
Queen 26CC Gasoline Boat 23,500.00
Blade 26CC Gasoline Boat With Zenoah Engine 23,300.00
Osprey 26CC Gasoline Boat With Zenoah Engine-white 23,300.00
Osprey 26CC Gasoline Boat With Zenoah Engine-yellow 23,300.00
Shark 33CC Gasoline Engine RC Boat 26,000.00
Electric Helicopter
KING 450SV 6CH Helicopter RTF Aluminum box 13,500.00
KING 450SV 6CH Helicopter RTF --2.4GhzAluminum box 15,000.00
KDS450S ---with special flymentor --Plastic Version (2.4G RTF) 16,500.00
KDS450S ---with Gyro --Plastic Version (2.4G RTF) 14,500.00
KDS 450C ---with special flymentor --Glass Fiber Version (2.4G RTF) Aluminum box 22,350.00
KDS 450C with Gyro Glass Fiber Version ( 2.4G RTF) Aluminum box 18,300.00
KDS 450C ---with Motor & ESC only--Glass Fiber Version 12,300.00
KDS450SV ---with special flymentor --Carbon Fiber Version (2.4G RTF)Aluminum box 22,950.00
KDS450SV ---with Gyro --Carbon Fiber Version(2.4G RTF)Aluminum box 18,600.00
KDS450SV with Motor & ESC only Carbon Fiber Version Aluminum box 12,800.00
500 Gfcpe Helicopter kit 13,800.00
www.cyclonetoy.com
NOW Available !!!!
Limited stock only
Key Features
Heatsink Case
Dead Band Width
End Points
Neutral Points
Fail Safe On/Off
Fail Safe Point
Overview
Weight oz.: 2.40
Weight g.: 68.04
SPECIFICATIONS
Engine----50CC
Monokota Covering
canister channel
Accesories
Program card 450.00
Key Features
size 4"x19" 140.00
2.5"x19" 110.00
4mm shaft 530.00
3.17mm shaft 530.00
Nitro spinner
size 2" 250.00 each
prop. nut spinner
3/8" 450.00
Nitro helicopter
Gasoline Boat
Electric Helicopter
LOOKING FOR!!
LOOKING FOR :
1) Ezrun Bl combo - FOUND!!
2) Any 4WD offroad rolling kit 10th or 18th scale "tamiya,associated etc.." - 2-3k budget depending lang
3) 2s lipos 25c or higher 1k budget
PLs text me your offers 09235753444.
.will buy it agad kung maganda pa :-)
Thanks rctech!!!!
Thanks rctech!!!!
For Sale!!!
NEW CONDITION Tamiya TT-01 Drift/Touring Car!!!
8.500php only :-) FREE SHIPPING NA! NEGOTIABLE!!!
READY TO RUN NA PO !!!!
SHELF QUEEN KO LANG TO!!
Includes:
1 MONTH OLD tt-01 kit
BRAND NEW teu-104bk esc w/ lipo cut-off
brand new tamiya tsu01 servo
tru-02 receiver
traxxas tq radio
Freebies :
subaru 08 body w/ lightbucket OR Porsche carrera gt body
white rims and radial tires
just add 500 php for a 3300mah GP battery..(barely used always balance)
NOTE: rollbars and chrome rims not included ..
PICTURE BELOW!
Rfs: dami napo ng kits ko :-).
Text or pm me David Suico 09235753444
Includes:
tru-02 receiver
traxxas tq radio
Freebies :
PICTURE BELOW!
LOOKING FOR:
KO PROPO kr302F receiver 27mhz
with or without crystals
must be in good condition
pls.text @09215209614-vince-binan laguna area
pls include your name and rctech username
[size=10pt]New and restock items! All are made of EPO material![/size]
New!
Restock Items!
New!
Restock Items!
