View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
HPI SAVAGE Xss 16K only
Hotbodies Cyclone S kit-7k
new but assembled
with new parts ( Front one way, center 1way, Spool)
no body
Tamiya Mitsubishi Pajero Body Brand New Unpainted 3.5k
sms 09166622222
new but assembled
no body
sms 09166622222
Tamiya TRF 501X 4wd Buggy
With:
Box, Manual, Spare parts.
Losi Ifmar Pins Front Tires, Proline Step Pins Rear Tires
New in packaging front one way diff.
P10,000.00 Only
*electronics in picture not included, kit only.
LOOKING TO SWAP WITH EP TOURING CAR (415 MRE, 416, CYCLONE TC/Moorespeed. etc.)
09209623803
Pic:
http://www.rctech.net/forum/attachme...2272008037.jpg
With:
P10,000.00 Only
09209623803
Pic:
FOR SALE:
3PKS WITH FUTABA 2.4ghz MODULE AND RECEIVER
SOLD!!!!!!
THANK YOU!!!
TWISTER25
SOLD!!!!!!
THANK YOU!!!
TWISTER25
mamba25
for sale! castle creations mamba 25 esc (aka sidewider) plus 4400kv trinity brushless motor and a bnew castle creations usb programming kit and software!
actual pics:
3200php for all only!!
text or call 0909-6335678 for sure buyer.
always include your location when texting so we can set our meeting place halfway in manila or quezon city area...
thanks!
mmm
looking for: rc18mt/vendetta st rolling kit only.
sure buyer here, text your offers 0909-6335678... thanks!
fs
FOR SALE : B NEW SPUR GEAR FOR SAVAGE 47T -200 PESOS, USED 1TIME VERY FRESH ACME RADIO TX AND RECIEVER AM27MHZ W/PAIRS OF CRYSTALS -700PESOS, HOBAO TRUGGY TIRES W/ RIMS 80%THREAD-300PESOS. RFS.D NAGAGAMIT
SALE
1. Futaba Fail Safe Unit = Php 300
2. Wheels for 1/8 Scale Buggy = Php 500
3. Hyper 7 1/8 Scale - Yannick Version Pro Kit = Php 5,000
4. AM Crystal - 27.145 = Php 200
0917-8032326 / 0922-8553249
Cheers!!!!
Cheers!!!!
CHECK THESE OUT !
FOR SALE.
CASH ONLY.
ALL NEW & UNUSED STUFF.
1.0) B/N IN BOX BY ENERGY E.C. 7.4V 2S LIPO 5000MAH 15C BATTERY. 12AWG WIRE, DEANS
CONNECTOR. GREAT VALUE TO RUN INSTEAD OF THE HEAVIER & LARGER 4200 NIMH STICK PACKS.---------------------P2,350.
2.0) B/N JR RACING RS310 40 MHZ SYNTHESIZED FM MINI-RECEIVER. CRYSTALS NOT REQUIRED.-----------------------P3,550.
CHECK THIS LINK FOR MORE INORMATION-
http://www.horizonhobby.com/Products...dID=JRPRS31075
3.0) B/N SPEKTRUM SR3000 2.4GHZ DSM 3-CHANNEL SURFACE RECEIVER.---------------------------------------------P3,450.
CHECK THIS LINK FOR MORE INFORMATION.-
http://www.horizonhobby.com/Products...ProdID=SPM1200
4.0) B/N IN BOX DURATRAX FLASHPOINT TEMPERATURE GAUGE.------------------------------------------------------P1,450.
http://www3.towerhobbies.com/cgi-bin...&I=LXEMG5&P=ML
PICK UP ONLY 10 A.M.-4 P.M. WORK WEEKDAYS, EDSA-GREENHILLS AREA. NO PRIVATE MESSAGES
PLEASE. KINDLY INCLUDE YOUR FULL NAME OR RCTECH USERNAME WHEN CONTACTING DON AT
MOBILE # +63915-4524488.THANKS TO RCTECH.NET, MODERATORS & TO ALL FOR BROWSING.
CASH ONLY.
looking for
sirs,
still looking for xxx4-G front diff cover and..
17mm hex hub adapter for erevo.
salamat po!!
09157975459
4700276
salamat po!!
09157975459
4700276
www.cyclonetoy.com
www.cheapricequalityrc.zoomshare.com
DLE-222 222CC 4 Cylinder Gas Engine will release out soon!
Watch the video::
http://www.cyclonetoy.com/listzt.asp?id=1284
1/5 HPI Baja 5B Gasoline 23cc Buggy RTR Clone 32,500 php
http://www.cyclonetoy.com/list_1.asp?id=1350
Text or call 09158884491
A123 Battery 2300mah arrving soon
SM Digital 57g/12KG Servo(Double Bearing)
arrving soon
http://www.cyclonetoy.com/list_1.asp?id=1547
Limited items only all brand new
Shipping charge php120.00
Heavy duty servo cable 300mm 130.00 ea.
http://www.cyclonetoy.com/list_1.asp?id=1216
Heavy duty servo cable 600mm 180.00 ea.
http://www.cyclonetoy.com/list_1.asp?id=1218
Energy EC Power lipo Brand
11.1v 1,500mah 15c lipo 1,450.00
http://www.cyclonetoy.com/list_1.asp?id=944
11.1V 1600mah 8C Gun-Type Transmitter 1,450.00
http://www.cyclonetoy.com/list_1.asp?id=943
11.1v 2200mah 20c lipo 1,550.00
http://i248.photobucket.com/albums/g...34016480-1.jpg
7.4V 2200mah 12C 1,300.00
http://www.cyclonetoy.com/list_1.asp?id=949
lipo 7.4 3500mah 25c for 1/10 car /crawler truck 2,350
11.1V/2200mAH/ 12C for Airsoft
Three battery
http://www.cyclonetoy.com/list_1.asp?id=941
Regulator/Lipo Cutoff
UBEC-5A-HV (High Voltage) 1,450.00
http://www.cyclonetoy.com/list_1.asp?id=1209
(Lipo cutoff)LiPo Battery Protector for Car 950.00
stock 7 pcs in stock free shipping
Manual
http://www.hobbywing.com/english/Art...?ArticleID=402
Charger and Connectors
T plug connector 3 pcs set male and female 200.00
http://www.cyclonetoy.com/list_1.asp?id=131
Imax B6 Charger 3,150.00
http://s248.photobucket.com/albums/g...current=b6.jpg
Imax b8 Charger with connectors and aluminum case 3,750.00
http://www.cyclonetoy.com/list_1.asp?id=1174
5A adaptor for Imax charger and other brand charger 750.00
http://www.cyclonetoy.com/list_1.asp?id=1213
Program card 650.00
http://www.cyclonetoy.com/list_1.asp?id=122
Tower pro MG995 750.00
http://www.cyclonetoy.com/list_1.asp?id=163
Servo
Tower pro 9G micro servo 350.00
http://www.cyclonetoy.com/list_1.asp?id=160
Hitec HS-7955TG Servo 3,350.00
Motor Type: Coreless Bearing Type: Dual Ball Bearing
Speed: 0.19 / 0.15 sec @ 60 deg.
English Metric Torque: 250 / 333 oz.in (4.8v/6v) 18 / 24 kg.cm
Size: 1.57" x 0.78" x 1.45" 40.00 x 20.00 x 37.00mm
Weight: 2.29oz 65.00g
Hitec hs65MG 1,300 each 2 pcs in stock
Required Pulse: 3-5 Volt Peak to Peak Square Wave
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.14sec/60° at no load
Operating Speed (6.0V): 0.11sec/60° at no load
Stall Torque (4.8V): 25 oz/in. (1.8kg.cm)
Stall Torque (6.0V): 31 oz/in. (2.2kg.cm)
SPE 43CC Gas Engine with pitt muppler 10,500 in stock
http://www.cyclonetoy.com/list_1.asp?id=162
Hawk propeller brand (Wood)
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=21
23 x 8 c 880.00
22 x 8 850.00
20 x 8 c 850.00
20 x 10 c 840.00
19 x 8 c 750.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
10 x 4.7 electric prop. 150.00
8 x 4 E. propeller 150.00
http://www.cyclonetoy.com/list_1.asp?id=568
Igniter with battery and meter 800.00 1 unit avail.
http://www.cyclonetoy.com/list_1.asp?id=1157
Tower pro voltage monitor 450.00
http://www.cyclonetoy.com/list_1.asp?id=886
Futaba R149 DP Dual conversion 9 channels PCM receiver no crystal, 3,500.00 neg.
Selling for a friend
Brandnew Super chipmunk 30 made in japan for 7,500
spec.
Watch the video::
arrving soon
Three battery
Manual
Program card 650.00
Servo
23 x 8 c 880.00
22 x 8 850.00
20 x 8 c 850.00
20 x 10 c 840.00
19 x 8 c 750.00
18 x 8 c 550.00
16 x 8 c 480.00
14 x 8 c 450.00
14 x 6 c 450.00
spec.
For Sale
Titanium shafts and lightweight parts for Savage Transmission - 2500
- 40% lighter than stock
- Less rotating Mass
- Includes Integy Spur Gear Hub
- Complete set for the Savage Transmission
Carlos N. Davis
09178570781
Carlos N. Davis
09178570781
FOR SALE:
Panther Komodo dragon 1/8th buggy wheels and tires(99% thread)-1.3k fixed
Futaba s3003 servos 2pcs.available-500 each
hobao center torsen differential- 1.5k
Looking for:
mugen mbx5t/mbx5r fuel tank with post
pls text me@ 09215209614-vince
Looking for:
badly needed by my friend...any 1/8 truggy or MT. preferably RTR. yung medyo mura na maayos pa sana. thanks.
text me your offers....09228224217
For sale
Hongnor X1CRT PRO kit 19kneg
1/8 nitro truggy
very fresh
minor scratches only
box and manual
0916-620-1901
wowie
1/8 nitro truggy
very fresh
box and manual
0916-620-1901
wowie
