View Poll Results: JPRaceway : On-road or Off-road?
On-Road
60
69.77%
Off-Road
26
30.23%
Voters: 86. You may not vote on this poll
The Big Locked Thread
PWEDE PA PONG HUMABOL PARA MAG ORDER UP TO 5 PM
cheap price good quality giant rc airplane,boat,nitro engine,gasoline engine
All of our products comply with international quality standards[/COLOR]
Check our accesories and engine parts for DL50
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=54
http://www.cyclonetoy.com/class_1.as...&anid=3&nid=67
We have a new airplane,1/10 car RTR and new low price adjustment !!
You can visit our website
www.cyclonetoy.com www.cheapricequalityrc.zoomshare.com
Imax B6 charger P 3,900.00 cheaprice order now!!!
Imax b5 charger P 3,200.00 cheaprice order now!!!
Imax B8 charger P 6,300.00 cheaprice order now!!!
LIPO Battery www.cyclonetoy.com
for inquire text the item num,
i will send you the price
cell num 09158884491
11.1v 2200mah 12c saddle type 1,660.00
11.1V 2000mah 12C Transmitter Battery 1,690.00
7.4v 2200mah 12c 1,450.00
7.4v 2200mah 25c 1,750.00
11.1v 3,500mah 20c 2.550.00
11.1v 1,600mah 8c gun-type transmitter lipo battery 1.400.00
11.1v 2200mah 12c 1,660.00
11.1v 2200mah 20c 1,750.00
11.1v 2200mah 25c 2,100.00
22.2v 2200mah 25c 3,100.00
22.2v 4400mah 25c 5,100.00
[/b]
30% YAK 54 50 CC 85" WING SPAN P 22,500 / combo DL 50cc = P35,500 in stock RESERVE UP TO FRIDAY
Carbon fiber tube made in USA plastic film
fiber glass cowl
with 22x 10 wood prop
30% EDGE 540 50 CC 85" WING SPAN P 20,500 / combo DL50cc = P=32,500 in stock carbon fiber boom
fiber glass cowl
with 22 x 10 propeller and aluminum
spinner 3.5 inches
DL50 cc engine new edition P=15,200 out of stock
U-BEC = P 600.00 in stock
> Input voltage: 11.1V/18V
> Output: 5.0V/6.0V
> Current capability: 3A
> Size(mm): 20X30X7
Rx-Regulator - P 600.00 in stock
> Use only2-cell(7.4V)
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
Tower Pro MG945 digital Servo all metal gear P950.00 in stock
spark plug dl 50 = 460 each 4 pcs in stock
Hawk wood prop 14x8 = 700 3 pcs in stock
hawk wood prop 22x10 = 750 2 pcs in stock
spinner 3.5 inches aluminum P= 850.00 sold out
Futaba gy 501 gyro w/manual P= 4,500
Call or text.cell no. 09158884491 / 045 8660458 look for alvin
Email: [email protected][
"Home made CONYNE DELTA KITE P = 400.00 each
70 inches wing span
Light Weight Fabric Materials
Bamboo Frame
Include Lines,Tails,Case
Other Designs and Colors Available
Text or call 09196014133 look for Eric Basit[/SIZE]
[/b]
fiber glass cowl
fiber glass cowl
spinner 3.5 inches
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
> Output: 5.0V/6.0V
> Size(mm): 20X30X7
70 inches wing span
Bamboo Frame
For Sale!!!
pls.. delete nagbago na isip ko...
UPDATE LANG PO
FOR SALE
1/8 Buggy Mugen Seiki MBX5 RTR with some freebies
14K only (negotiable)
- OS .30VG Big Block Engine (non-pullstart, good compression, never raced with box and manual)
- aluminum front and rear shock tower
- carbon fiber servo tray
- 2 standard servo (throttle & steering)
- "Dynamite" tuned pipe
- B/N Air Filter (converted to the airfilter used by motorcycle)
- KO Propo Ex-11 Presto fm radio & novak receiver(with tx&rx crystals)
- 2 bashed body cover
- 4 pcs. tire & dish type rim (tire needs to be replaced kasi medyo kalbo na, pero pwede pa pang bashing)
- rx battery
- starter box with free 6V lead acid battery (di ko lang sure kung ok pang ung lead acid kaya i'm giving it for free)
THE FREEBIES:
- 1pc. OS .21VG Vspec Engine (good for bashing only, glow plug needs replacement)
- 1 pc. vintage AIRTRONICS fm transmitter with module (without antenna)
- 1 pc. tire wrench
For faster transaction pls. text/call at 09174912255(Richard) or 8529412 (9pm onwards)
Meeting place @ sonic boom or we can meet halfway (during weekends)
FOR SALE
- rx battery
THE FREEBIES:
- 1 pc. tire wrench
FOR SALE:
A. PROMAX Activator Sport Digital Peak Charger: P2.2k
AC/DC input (110V or 12V)
Charges 4 to 8 cells of nicd or nimh batteries (any size)
User adjustable .1 to 4.0 amp charge current
Digital meter shows battery pack volts, amps, no. & type of cells, peak volts and elapsed charge time
Has internal cooling fan.
Just tested and kept as this is my spare charger.
B. Prather 265 boat propeller: P1.0k
Cast Stainless Steel, 2 blade - brand new item.
All items in very good condition.
PM na lang for inquiries.
for sale
TAMIYA TT-01 chassis Drift spec.
-TAMIYA ball bearings (all bearings)
-TAMIYA RZ motor 23turns.
-FUTABA ESC mc230(electronic speed control).
-TAMIYA carbon upper deck.
-TAMIYA stabilizer front/rear.
-TAMIYA foam tires 8pcs 90% tires(4 white/ 4 orange).
-TAMIYA drift tires 4pcs.
-TAMIYA 3300MAH ni-mh.
-TAMIYA lexan bodies (evo 7 green/ silvia blue).
-TAMIYA sport tune motor (included)
-FUTABA megatech 2PL-FM controller.
-FUTABA steering servo 9 series.
-13k (neg)
-09152550307
-click link to see photos.
http://www.motorcyclephilippines.com...e=Image040.jpg
http://www.motorcyclephilippines.com...e=Image033.jpg
http://www.motorcyclephilippines.com...e=Image038.jpg
http://www.motorcyclephilippines.com...e=Image039.jpg
-13k (neg)
-09152550307
FOR sale
SA MGA MAHILIG SA TOTOONG KOTSE
AVT dvd player & 7inch monitor single DIN
-slightly use lang po
-w/ box & manual & controller
-malinaw parang pioneer
-bnew price 32,000
-23,000 (neg)
-09152550307
PIONEER 6850 W/ STEERING CONTROLLER
-quality output sound
-ipod ready
-w/ ipod wire
-slightly use po
-may battery meter po yan
-3d graphics
-bnew price 12,000
-steering controller bnew price 2,000
-galing po ky mickey's autosound
-8,000 (neg)
-09152550307
-bnew price 32,000
-23,000 (neg)
-09152550307
-ipod ready
-w/ ipod wire
-slightly use po
-3d graphics
-bnew price 12,000
-8,000 (neg)
-09152550307
BUYING
BUYING:2nd hand only
ROLLING CHASIS
TTO1
TA05
SELLING:2nd hand items
FUTABA MC330rc P1900(neg)
stick type remote controll 1000 crystal included w/o receiver P1200(neg)
INTELLEC BATTERIES 3600MAP(side x side) P1000
txt me 09052447310
look for justine
ROLLING CHASIS
TTO1
TA05
txt me 09052447310
look for justine
5th Cebu Invitational Race! (This will actually be our 6th Annual Invitational Race but last year was the "2007 Philippine On-Road Nationals" sanctioned by RCMP )
Date: April 11,12 & 13 2008 (Friday to Sunday)
Venue: Hillside Hobbies & Raceway (On-Road/Off-Road Track)
Tentative Classes to be run. We might not run a particular class if there are not enough confirmed racers (Preferably a minimum of 10 racers/class).
Registration:
Kindly list your FULL NAME, LOCATION & FREQUENCY to the class you intend to join. This will help us monitor the number of racers joining the event and frequency conflicts. Thanks!
GP Touring: (Tentative: Friday)
1. Jon Jarantilla CEBU 75.710
2. Raul Baron CEBU Spectrum
3. Robby Fuentes CEBU 27.225 MHZ
4. Junnifer Tumanda CEBU 2.4Ghz
5. Ralph Lorenzo MANILA sanwa 2.4Ghz
6. Clemen Pancho MANILA sanwa 2.4Ghz
7. Louei Carballo MANILA futaba 2.4Ghz
8. Mike Ong MANILA Futaba Spectrum
9. Eric Tan MANILA Futaba
10. Lark Pacubas CEBU Futaba 40.850
11. Albert Arrambulo MANILA 2.4 Ghz
12. Rhoby "K" Orata MANILA 2.4 Ghz
13. Fritz Diorico CEBU 26.895Mhz
EP Modified: (Tentative: Sunday)
1. Stephen Dy Butuan/Cebu Spektrum
2.
3.
EP Stock: (Tentative: Sunday)
1. Ted Flores MANILA Spektrum
2. Robby Orata MANILA 2.4 Ghz
3. Stephen Dy Butuan/Cebu Spektrum
Tamiya Mini: (Tentative: Sunday)
2.
3.
GP Monster Truck: (Tentative: Saturday)
1. Junnifer Tumanda CEBU 2.4Ghz
2. Albert Arrambulo MANILA
3.
GP Truggy: (Tentative: Saturday)
4. Christopher Ramos CEBU
8. Jericho Borja MANILA KO PROPO 41.08
10. Atty. Noel Jose MANILA Futaba
11. Mike Ong MANILA Futaba Spectrum
12. Donjie Pascual MANILA Futaba Spectrum
13. Rodjard Soriba CEBU 40.730
14. Lark Pacubas CEBU Futaba 40.85
15. Apo DAVAO 2.4Ghz
16. Robby Orata MANILA 2.4 Ghz
17. Albert Arrambulo MANILA 2.4Ghz
18. Atty. Jon Albano MANILA FASST
19. Louie De Guzman BATAAN FASST
20. Ronald Serrano BATAAN FASST
GP Buggy: (Tentative: Saturday)
1. Ralph Lorenzo MANILA 2.4Ghz
2. Eric Tan MANILA
3. Mike Ong MANILA Spectrum
4. Clemen Pancho MANILA 2.4Ghz
5. Louie Carballo MANILA 2.4Ghz
6. Atty. Noel Jose MANILA
7. Donjie Pascual MANILA Spectrum
8. Robby Orata MANILA 2.4 Ghz
9. Jericho Borja MANILA
Thanks for registering!!!
Registration:
2.
3.
2.
3.
3.
2. Eric Tan MANILA
F.S. savage x .28 4.6 (f46) engine with rotostarter back plate. no problems good comp. got the savage x RTR last dec.1. 5,000 neg. engine only. 09279974570/09228124600
Academy Sea Dragon boat
-around 3 feet in lenght
-electric and gas convertable
-driver and co driver figure
2k
Racenut - i'll take the boat!
2k
for sale GS STORM SUT
current parts
-sh .28 engine (verygood condition, perfect for bashing)
-fioroni option team clutch 6 point
-fioroni option team dual chamber pipe
-fioroni option team chassis (black)
-carbon fiber radio tray
-titanium shock tower
-crime fighter mounted on ofna dish wheel
-new engine mount
extras
-1 dogbone
-kyosho brake pads, (still new, nasa plastic pa)
-extra fioroni option team chassis (blue) and the original chassis
-engine mount
-new lower arm
-also the original plastic parts
this kit is converted to pro kit...perfect for racing...already won at qc track...
selling for 11k fixed...
items are in baguio city...
you can call or txt for your inquiries...09163737814 globe / 09294399525 smart
current parts
-new engine mount
extras
-1 dogbone
-engine mount
-new lower arm
For Sale
New Hyper ST blue RTR body - 1.5K only
Team Losi XTT mounted truggy tires - 2.5K only
4 pcs Sanyo Nicd 2400 batts w/ deans conn. - 3K for all
LRP Pulsar Comp. 3 Charger very slightly used, box & manual - 7K
RFS- I have 4 chargers
pics. upon request
09178903878
pics. upon request
09178903878
sale!
b/n matrix pro lathe motor 55t single (integy tech inc) motor good for crawler -1,2k
b/n mugen mbx5t body shell never been cut w/d sticker- 1.5k
b/n ofna hyper 7 side guard gray w/d fuel proof plate-450 nlang
b/n ofna engine mount w/d chassis mount(hyper 7)-700 nlng
3pcs upper and 1 pc lower suspension arm tamiya TNX 5.2-250 each
all item in tanauan city,batangas
call,txt or pm 09185306462 (jason)
make an offer! tnx!
make an offer! tnx!
