QCRCCC OFF-ROAD RACING
Sir and dami reasons.
1. low cost, made from low quality materials
2. Over discharge
3. low quality charger
4. too many cycles in a day.
Dynabolt,
Suko na ako kagabi, sobra pagud na rc. Grabe 12MN! kayo sa CV.
octo,
Ikaw may kasalanan, pinagod mo ako. hehehe enjoy naman.
Tagal mo na hindi na pasyalan condo mo sa cv ayos yan sir.
2. Over discharge
Dynabolt,
octo,
thanks @emer. servo ko pala yun may tama kagabi. may damage na naman sa wallet ko yun =))
wapak, dynabolt, viralvariance, vin, greendot, WSL ,Sir boyet, garet, etc kung mern akong hindi na banggit.
Thanks for running at cv! sarap ng takbo natin.
Greendot,
Sir bitin naman ako sa takbo natin, sira servo.
WSL,
Medyo na kilala ko na si Nvision.
Vin,
And tulin mo!
Dyanbolt,
Improve na sir, sumasabay ka na. welcome to dirt off-road.
viralvariance,
Ganda motor mo sir!
wapak,
Sir, kaylagan talaga silicon oil difs mo and CA mga diff bushings.
Balikrc,
Sir andito na epektos natin!!!!
So far okay naman starter box motor mo, I think replacing the Tamiya plug will resolve any issues.
Greendot,
WSL,
Vin,
And tulin mo!
Dyanbolt,
viralvariance,
Ganda motor mo sir!
wapak,
Balikrc,
Yes Sir emer, thanks din for the tips. sayang nga hindi ako makastay ng matagal. will get those diff oil before dec 2. kinalas kna dn ung mga gears...btw wats CA?
RC 101
CA is acronym for "Cyano-Acrylate" composition ng superglue. the common brand found anywhere is MightBond or Bulldog. may klase din yan, famous sa Hobby natin RC ay "Thick" type difference is that mas matagal lang matuyo ang thick kaya mas recommended gamitin para ma-align ang mga dapat na nakatapat bago madikit. not like thin mabilis matuyo mas delikado gamitin sa RC. we have Medium type din in between ng Thin at Thick, ito gamit ko.
Emer, help
Power system - Novak GTB + ???kv motor (sana magamit ko ESC ko)
Pinion Gear???
2S Lipo Batteries??? ilan packs kailangan for a race day
10kg .10s torque servo ok na ba?!
tires/wheels combo for CV?!
Punta ako SG sa Tuesday, balik sa Thur
Pinion Gear???
To all SCTE new owners, green dot, joey, wapak, creepycore, lewd, etc, its a must to CA all diff bushing, to prevent silicon oil to leakout.
Lewd,
Youll need minimum of 2 oack 2s, 70c or higher, 6000mah or higher.
For GTB 7.5 turns will be safe from overheat, but might not have enough top end speed, and torque to clear the jumps. pinion gear my 16 to 17t.
For the servo, 8kg is enough hindi ka ma bitin.
Tires stock tires eclipse or the once you got will do.
Lewd,
@ emer, you had mine glued already hehe thanks!, next kinakalikot ko yung monster truck i wanna switch it to silicon oil din, read i need 30k to 50k oil daw, nabaklas ko na front end ko linis inabot ako buong araw! lol, harap palang kapagod, binalik ko na nakabit ko naman hahaha, havent touched the diff yet, bibili palang ako ng silicone oil for it, takot ako buksan baka pwede ko ulit itakbo sayo hahaha. by the way do i need to change my shock oil na? both in my losi and savage?
Wow! Daming kinakati na kamay ah... puro SC 4x4 set-up ang usapan ng mga LOSI Boyz...
For sure mainit yung laban come December 2 sa CV! Hoy mga AE Boyz... Gising Na!!!
Yung mga may Traxxas at Durango dyan... Mahiya naman kayo! Get off your lazy asses! Race Na!
creepycore,
Your kit scte is still new, no need to change shock oil, maybe after 6 months. Sure txt me if I'm available i can help you with the diff. yes silicon oil sa MT 10K up.
STEALTH,
Busy ka kasi sa f1.... hehehe sayang si F.A. well thats part of racing.
Ready na E.buggy mo?
lewd,
2 packs pa lan, 6000mah or higher capacity.
STEALTH,
lewd,
Lewd,
Lewd,
Yung diff pwede ba silicon sealant lang or talagang i-CA na sa diff case? Also ok ba 5K-10K-3K set-up?
Balak ko mga 5.5/6.5 na motor?! Yes I'll get 6000mAh 70c packs if maassure ko pwede i-check in sa plane yung batts.
Pwede check in sa plane yung Lipo bawal lang talaga hand carry nyan.
CA is a better option for the scte diffs. silicon sealant does not perform well when applied thinly. besides, CA restricts the bushings from minute movements.
lewd,
Silicon will still leak-out from diff bushing. CA is the only way.
I'm running 7k front, 10k center, 5k rear, some guys run 5,5,2 or 7,7,3.
Get the 5.5turns, you need torque to pull the dump truck.
Thanks MON, Octopus Prime!
Ok Emer. Hope to race with you guys (again) soon
PITSHOP and CV SPEEDWAY PRESENTS...
THE 2012 OFF-ROAD ELECTRIC CHRISTMAS RACE!!!
DECEMBER 2 SUNDAY 2012
REGISTRATION 9:30
QUALIFYING STARTS AT 10:00
CLASSES:
1/8 E-BUGGY
1/10 4WD OPEN SHORTCOURSE
1/10 2WD OPEN EP/GP SHORTCOURSE
SPECIAL CHRISTMAS TROPHIES WILL BE AWARDED
CHRISTMAS RAFFLE!!
CHRISTMAS BUFFET LUNCH!!
CHRISTMAS MODEL
AND LOTS MORE!!!
SEE YOU GUYS THIS SUNDAY!!!
REGISTRATION 9:30
CLASSES:
1/8 E-BUGGY
CHRISTMAS RAFFLE!!
CHRISTMAS MODEL
AND LOTS MORE!!!
