RC BOAT
#4456
Both Robbe and Graupner have really great looking yatchs and their attention to detail is second to none! Kaso, mahal talaga! For the longest time gusto ko sana ng Robbe Najade, but very hard to come by nowadays.
For cheaper China stuff - HK Princess yatch maybe a good alternative.
#4457
#4460
Fuel tank
@BOATERS
HELLO, QUESTION LANG PO? I BOUGHT A USED NITRO BOAT AND I PLAN TO ADD ANOTHER FUEL TANK FROM MY RC KYOSHO CAR. CAN I CONNECT THE 2 TANKS IN THE INTAKE FUEL HOSE OF THE ENGINE USING A Y-SHAPED COPPER TUBING? WILL IT NOT DROWN THE ENGINE IN FULL REV?
#4461
1st run
pashare lang po, my 1st run....enjoyed it!!!!!
#4462
#4463
2t fully synthetic oil
guys baka may gusto sa inyo nito ha. pm nyo lang po ako kung sino may gusto. thanks! 500 per litre.
#4464
- flex shaft, copper tube, teflon tube, drive dog and prop nut
- strut or stinger
- rudder
- trim tabs
- turn fins
- prop
- plastic tank or IV bag
- water hose line
- fuel hose line
- fuel filter
- plastic tee
- motor mount
- throttle bellcrank
- coil relocator
- coupler
- pulley
- throttle linkage (clevis)
- rudder linkage (heavy duty clevis)
- rubber boots
- 1/8" pushrods
- on/off switch
Of the above, you already have a hull, motor, pipe/header, throttle and rudder servo, Tx/Rx, rx battery and radio box.
#4466
lf
modified/upgraded to brushless system RC NQD Tear Into jetboat. PM offers.
#4467
FS
26 inches fiberglass deep v
4 pole 2850 brushless motor w/ watercooling jacket
60amp turnigy marine esc
brass prop balanced and sharpen
1pc flex cable drive w/ stainless stub
watercooled motor mount
PM or call 09175197191-bong
+ YouTube Video | |
#4468
FS
Expandable foam sealant perfect floatation for rc boats! P500/can
Cured foam can be trimmed and sanded. Does not absorb water unlike toy tube flotation that absorbs slight water if dip or submerge into water.
MADE IN USA
http://www.amazon.com/Beckett-Corpor.../dp/B005G6TNC4
MADE IN USA
#4469
#4470
Sir RED kung pang deep v gas boat parts e2 na halos ng hardwares na kailangan mo..
Attachment 928764
Attachment 928766
Attachment 928764
Attachment 928766
