RC BOAT
#3708
Sir CARakter, Oo, pero ang metal parts pinagawa ko sa silver artisan friend of mine. kasi yung kit parang plastic lang talaga. ito fiberglass ang loob and real fine wood ang labas. I do still have the plan somewhere.
sir dizzyxtian,Thank you, hard labor and passion lang, Malapit na bang mabuo ang cat mo?
eto pa ang ibang angle.
#3709
#3710
tagasagwan, thank you.
Carakter, definitely 'di silver, pero yyung metal parts cost me a fortune. Tama, naka display na lang mas maganda kasing i admire kaysa patakbuhin. isang beses ko lang nilubog sa tubig.
Oro27, Thank you
Dizzyxtian, Gusto ko rin nga sanang lagyan, pero wala akong talent sa paggawa ng figure. We'll wait for your pictures goodluck
Eto pa ang isa ko pang binubuo ngayon. 1/5 scale 40- 60cc KNK engine will run this thing. pero matatagalan pa bago siguro matapos.
Oro27, Thank you
#3711
esc required
mga sirs, patulong lang po. Ano po required na esc sa BL3656-1200KV Brushless Inrunner (WaterCooled) at sa HXT 36-56 2700kv Brushless Inrunner (WaterCooled) ? tatlong esc na po ang nasunog ko sa 2700kv, isang 100amp,120amp ang 150amp na po ang nasunog ko.
#3712
1. right polarity connection from esc to battery..
2. proper voltage programming of the esc...and right battery of the right voltage capacity..
3. waterproofing of the esc and water thight connections of the cooling tube.
4. sufficient cooling to desipate heat..make sure your water cooling works..
5. time your run...the longer you run your boat the more heat it produces and you risk your esc,battery and motor's life in the process.
6. lastly, water leaks!..water and electricity dont mix so keep your boat leak free!! that's all i know for the moment..hope it helps..
#3713
esc
kahit siguro 100amp lang esc mo kayang kaya yang 3656 motor mo. Kaso 43 inches boat mo masyado malaki at pag mabagal boat mo hindi sufficient yung water supply na pumapasok sa esc mo kaya nasunog at siguro malaki pa gamit mo propeller. Try mo gumamit ng 35-37mm 2 blade propeller baka bumilis pa ang takbo ng boat mo at hindi pa siguro mag init yung esc mo..
#3714
#3715
LAZER RESTORATION
THE LAZER, WITHOUT PROPELLER!!!!
#3716
Ganda naman ng Lazer mo sir archer
Cant wait on that FE boat project namin ni Tag - pero may feeling ako na malapit na sya ma-launch
#3717
FE and Lazer Projects
Sige po sir Macdon, baka magkasabay-sabay na.
#3718
1/6 Scale boat
Sir MACDON natapos nyo nba yung project nyo na 1/6 LSSC? Post mo naman mga picture ng boat nyo.. Takbo tayo molino pag ok na yang boat mo..
#3719
#3720
May mga binubuo ako mga boats dito ngayon - 20" na Graupner Carina, 24" na racing boat at yung 29" deep Vee mono na project namin ni Tag. Ipapaubaya ko yung project launching ng deep-V kay Tag dito sa forum pag matapos
Oo nga pala - dumating nung isang araw yung "small bolt" hydro kaso hull lang - magpapaturo sana ako sa iyo ng mga kailangan nun para patakbuhin - pagusapan natin one of these days sir
I will definitely take you up on that offer to try Molino - hindi pa kasi ako nakapunta dun eh.
