RC BOAT
#3076
@Dongskie - To give you an idea, the SV27 runs on 1.8Kv and 45amp esc, the UL-1 uses 2084Kv? and 60amp esc. Both are within the same size as your boat. I tried a 2.6Kv and all the boat wanted to do was spin like a crocodile when it tries to feed on something. The 2.3Kv was an improvement, but the cheap motor I tried had a short lifespan.
Also, bigger boats need torque (translate = low Kv) to propel it forward. Look, if you don't spin that 3.0Kv motor in it's comfort zone, you will overheat (do I see smoke?) everything!
We know this because we have burned quite a few motors and esc's.
Don't be tempted to go high Kv motors . . . most of the time it won't work with your appliction.
Stick within the 1.8 to 2.3Kv motors for your boat. You can always buy a water jacket and ESC cooling plate online (if not included) or . . . have a local machine shop make you one. Our motor jackets came from "ricamara".
Try mo muna ang 40A blesc mo. Of course, a 60A (or higher) marine esc is best . . . if you've got the bucks to spare . . go for it!
You want a cheap boat esc? Look for the "Mystery" brand. Kanya lang kailangan mo yata i-program everytime you plug the battery in.
@bentoy - This advice goes for you too. Bongsky is right, a car esc (BL or brushed) is not designed to handle the continous amp demands of Fast Electric boats. It's okay for your current setup, but not if you want to go fast. I'm surprised you don't experience thermal shutdown in your 101BK. Remember, it's trying to push water away continously . . and that my friend is a heavy load to push!
Guys remember . . . you will need good lipo's with 40+ C ratings if you want your batteries to last . . . . longer. And, good props!
#3077
parang hindi pwede yang esc mo madali mag overheat yan dapat yung me water cooling system. Try mo turnigy marine esc at brushless motor.
http://www.hobbyking.com/hobbyking/s...ter_Cooled_ESC
http://www.hobbyking.com/hobbyking/s...r_(WaterCooled)
O kya kung me airplane or heli esc pwede din yun lagyan mo lang ng water cooling system. na try ko na din kc esc pang car madali sya mag overheat.
kung me brushless motor ka naman na 540 size pwede mo din gamitin yun madali lang i watercooled yun.
E2 yung homemade fiberglass brushless rc boat ko na binenta ko na kay eight. 3800kv brushless outrunner, 30amp heli esc, cheap plastic prop and hardwares & cooling system is made from aluminum scrap and heli parts.
+ YouTube Video | |
I might go with your sugesstion so can i start with these items below ?
Esc:
http://www.hobbyking.com/hobbyking/s...ies_60-70A_ESC
and motor
http://www.hobbyking.com/hobbyking/s...otor_%28FIN%29
OR
http://www.hobbyking.com/hobbyking/s...250kv_Inrunner
BTW sir i think i can make my own cooling plate i just need a simple brushless upgrade..hehe..
If needed i can run it on a 4s set up..I have some turnigy 4000mah 2s 40c lipos here..
#3078
@bentoy - you are looking for a "smooth" can motor so you can install a water jacket . . preferrably the 36x 60 size . . . like this:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6526&Product_Name=Turnig y_B36-56-06_1800kv_Inrunner
For the esc I would reccomend these:
http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?catname=Brushless +ESC&idCategory=256&ParentCat=254
But yes, you can use plane esc's (60+ amps), just install a water cooling plate.
#3079
@David: pasilip naman ng video ng temporary run mo...
@Carakter: all noted sir, thanks for the extensive info.. I'm still waiting the arrival of my BL motor, for the meantime I will try out my temporary brushed 11.1v set-up this weekend at the QC pond, bahala na si
#3081
Saturday ako mag test run
#3082
[QUOTE=Dongskie;8028692]@David: pasilip naman ng video ng temporary run mo...
Sure sir if only i could. I just lost my drive nut(yung nut holder for the prop?the inner 1 yung may ngipin) kanina nungtinest ko with 3s lipo. triny ko yung isang drive shaft pero parang iba yung thread rotation nya.Hopefully i can find another one here.Meron ba sir?
Sorry for the newbie questions.Please bare with me im a noob in boat parts..lol..thanks!!
#3083
#3084
Gawin mong twin motor!! btw napatakbo mo na? slow rpm / high torque ang motors na kasama niyan..
#3085
Hala, nakalimot mo mag lagay ng thread-lock? hanapin mo ulit nandyan lang yun... drive dog ang tawag dun sa item na yun, otherwise gawa ka na lang, hanap ka ng nut na same size, i-file mo hanggang sa magaya mo yung shape niya.. sisiw di ba?
Im planning to turn that into this:
http://www.youtube.com/watch?v=wFUfc4eGNTs
hehe..anyways ill do the tracer first muna sir..hehe..
#3087
Rigger
shaft ng stabilizer ng t-rex 600 size heli 4mm yun at treaded na both ends yun ang ginamit ko nun sa home made boat ko eh mga P100-150 lang yun.
san mo nakuha at magkano rigger mo? San ka nag papatakbo?
hehe..anyways ill do the tracer first muna sir..hehe..[/QUOTE]
#3088
#3090
H
H
