Asian Mugen Cup Details
#136
Originally posted by mavicRR
pay duty stem 1st..
just a Q: all car inspection or top 3 cars only?
pay duty stem 1st..
Cheers,
#137
Originally posted by HPC II
This will be race management decision on race day.
Cheers,
Cheers,
Sorry, guys after calling some kaki at the track I think this is the actual layout.
#138
#139
Re: Cooling and Refueling Holes
Originally posted by InitialD
Just trying to help out in the confusion here and give suggestions on how these holes the are cut on different car brands...
MTX-3
Team Magic G4
Serpent 710
HPI R40
FW05R
V1-RRR
NTC3
Not sure if all cars were covered... It sure does look like either the refueling hole or the main cooling hole can cross the window / roof line. Most opted for 2 holes but some opted for one main cooling hole come refueling hole like the MTX-3.
At the end of the day, it's up to the discretion of HPC to interpret the rules regarding the cooling holes.
MTX-3
Team Magic G4
Serpent 710
HPI R40
FW05R
V1-RRR
NTC3
Cheers,
#140
R&R
Make sure that the following are given attention to during the race...
a.) Cooling hole (within windscreen area) - 60mm dia.
b.) Refueling hole (can be on roof or crossing roofline but not overlapping cooling holes if any) - 50mm dia.
c.) 4 door EFRA, ROAR, FEMCA approved body
d.) front 2 side windows can be removed for cooling
e.) rear window can be remove entirely (within window line)
f.) Wing overhang - 10mm meansured from bootlid
g.) Rear bumper cutout - 45mm from base**
h.) Max height (roof height) - minimum 120mm from base**
i.) Wing height must not be higher than roof
j.) Wing width - 50mm
k.) Wing length - 200mm
k.) Wing side plate - 50mmx35mm equal size on both sides
l.) Weight - 1725grams including transponder
m.) Fuel Capacilty - 75cc with fuel line + filter
n.) car width with tires - 200mm or less
** from base means that the measurement will be done with a 10mm spacer/plate placed beneath the chassis.
Do take note that cars will tend to be slightly lighter after finals (tire size reduction). Hence, pls take care.
Cheers,
Cheers,
#141
Re: R&R
l.) Weight - 1725grams excluding transponder
#142
Re: Re: R&R
Shouldn't that be 1725 grams including transponder (with wheels, with bodyshell and without fuel measured after the race) as per IFMAR?
Better would be to say car width 200 mm or less.
#143
Re: R&R
#144
Re: Re: R&R
Originally posted by crashed_1
This could be a tricky one...It's gonna make the car look like a rally car if we tried to make the 120mm mark...Max i got to was 115mm...and that was with a 10mm Hudy Block. How ah?...
When you do this, watch out for the rear bumper cutout. It must not be higher than 45 mm when put on the 10 mm block.
#145
Uncle Crash,
You still have time to get a new Rally body. Peugeot 206?
#146
As for the jig,we just received it today.Had 2 minor adjustments to be made.So I dont think it will be available just yet.
Basically,I think it is not much of a problem for u to check yourself.So on Saturday morning,do come early if u wish to double check.
Cheers!
#147
UPDATE:
1/10 -
1) David Voo 40.750 - S710 (Sabah)
2)Richard Voon 40.610 - Mugen (Sabah)
3)Poniman - 40.630 - Mugen (Sabah)
4)Nadzree - 27.025 - Mugen (Sabah)
5)SD Lung - 40.370 - Mugen (Sabah)
6)Brandon Lo - 75.550 - Kyosho V1RRR (Sabah)
7)KK Lee - 40.650 - Mugen (sabah)
8)Adnan - 40.945 - Mugen (Sabah)
9)Iskandar - 40.670 - Kyosho FW05 (Sabah)
10)Gary Soh - 40.710 - S710 (Sabah)
11.)Leong Keng Hoe 27.045 - Mugen
12.)Big Kent - 40.435 - Mugen (KL)
13.)Gerald Lim - 41.140/40.835 - S710 (KL)
14.)Hafiz Shah - 40.270 - V1RRR (KL)
15.)Ong Kee Huat - 41.060 V1RRR (Penang)
16.)Eric Ma - 40.875 V1RRR (Penang)
17.)ANDY DASS - 40.130 Serpent 710 (KL)
18.) LIM TOW JIA - 75.830 V1RRR (KL)
19.) RAMESH - 75.790 Ho Bao (KL)
20.) LOOI GA SING - 75.630 Ho Bao (KL)
21)Juan Masrin - 75.810 - Mugen (Sabah)
22)Mansur Yusop - 40.850 - S710 (Sabah)
23)Ong Kok Thye - 40.435 - G4 (KL)
24)Behringer - Mugen (KL)
25)Anthony Tan - 40.170 - Mugen (KL)
26)Jason John - 27.495 - Mugen (KL)
27)Kew Sau Gie - 40.750 - Kyosho Evo(KL)
28) STEVEN TYE - 75.590 - SERPENT 710(KL)
29) SUAH - 40.590 -SERPENT 710(KL)
30) MICHAEL OOI - 40.290 - SERPENT 710(KL)
31) BADRUL ALIAS - 40.290 - SERPENT 710(KL)
32) Sydney Soo - 40.650 - Kyosho FW05R
33) Ben Siew -27.285 - Kyosho FW05R
34) Desmond Lam - 26.995 - Kyosho FW05R
35) Anthony Wee - 40.000 - Kyosho FW05R
36) Yap Chew Kong - 27.345 - Kyosho FW05R
37) Lun - 40.375 - Kyosho FW05R
38)Kelvin Ngow - 27.175 - G4 (KL)
39)APU - 40.415 - G4(KL)
40)Leonard Ong - 40.310 - Mugen (KL)
41) Kelvin Wong - 29.860 - NTC3
42) Jordon - 29.TBA - NTC3
43)Baru - 41.060 - Mugen (KL)
44)Bulldog - 40.590 - Mugen
45)Moon - 40.510 - Mugen
46)Ikhwan- 40.355- Kyosho V1RRR (kl)
47)Mizan-75.690-Kyosho V1RR (kl)
48)Lias- 75.770- Mugen MTX-3 (kl)
49)Riad- 40.835- Serpent 710(KL)
50)Emeel-26.975-Serpent 710 BLACK MAMBA(KL).
51)Ikmal-26.865-Serpent 710(KL).
52)Wayne - 40.725 - HPI R40 (Kuantan)
53)Harry - 40.750 - Mugen (Kuantan)
54)M.Afiq - 40.830 - NTC3 (KL)
55)Wong KK - 27.025 - FW05RR (KL)
56)Hanafi - 40.850 - Mugen (Klang)
57)Madnor - 27.025 - Mugen (Klang)
58)Zairul- 40690-Mugen (KL)
59)Azmi Fiat - 75.550 - FW05RR (KL)
60)Baharudin - 40.675 - SERPENT 710(KL)
61)Timmy Tan - 41.120 - (Penang)
62)Lye Keat Seng - 75.490 - (Penang)
63)Jimmy Ngai - 40.775 - G4 (KL)
64)Daniel Kee - 29.865 - NTC3 (Klang)
65)Lee Kok Jeen - 40.150 - FW05 (Kelantan)
66)Doremon - 40.415 - Mugen (Ipoh)
67)Poyol - 27.095 - Mugen (Ipoh)
68)Din Satay - 40.965 - R40 (Ipoh)
69) Shahrom Majid - 75.790 - S710 (KL)
70)Alex Hau - 40.695 - Mugen (Melaka)
71)Chau - 40.895 - Mugen
72)Khairol - 40.690 - CD3
73)Jackson Goh - 41.775 - FW05 (KL)
74)Bahrain - 75.470 - Mugen (KL)
75)Haikal - 75.430 - G4 (KL)
76)Azhar - 75.610 - Mugen (KL)
77)Mahathir - 40.770 - S710 (KL)
78)Lai Boy - 40.070 - NTC3 (KL)
79)Zamanhuri - 75.710 - Mugen (KL)
80)Daniel Tan - 40.810 - Mugen (KL)
81)Simon Loo - 40.650
82)Azri Amri - 75.750 - Mugen (KL)
83)Yus - 29.825 - Mugen (KL)
84)Jeffery Chew - 40.710 - Mugen (KL)
85)Albert -
86)Akhiar - 40.610
87)Imad - 75.670 - Mugen (KL)
88)Simon G - 41.180 - Mugen (KL)
89)Chua Kim Swee - 41.040 - Mugen (Melaka)
90)Ezumi - 40.810 - NTC3
1/8 -
1) Michael Ho 40.955 - S950R (Sabah)
2) Gary Soh - 40.710 - XR8 (Sabah)
3) Chai Kok Chin - 27.225 - Mugen MRX4 (KL)
4) Wong Yoong Keong - Mugen MRX4 (KL)
5) Shahriman - 75.670 - S950 (KL)
6)Yee Kok Leong - 27.095 - Mugen MRX4(KL)
7)TPK - 41.040 - Mugen MRX3(KL)
8)Roger Wong - Mugen MRX3 (KL)
9)Niko Cheng - 26.885 - Serpent 950R (Johor)
10)Haji Jusri - 29.785 - Serpent (KL)
11)Mee - 75.790 (KL)
12)Amril - 75.510 (KL)
13) Boy - 40.710 (KL)
14)Joe - 40.690 (KL)
15)Azman - 26.875 - Serpent (KL)
16)Lai Kok Heng - 29.865 - XR8 - (KL)
17)Andak - 41.160 - MRX3
18)Gelong - 29.825 - MRX4
19)Goh Teo Ann - 41.895 - MRX3 (KL)
20)Zack - 40.790 - MRX3 (KL)
21)Zaharin - 75.670 - MRX3 (KL)
22)Leong Pak Sing -
23)M.Zain - 26.995
24)Ismail - 75.890
25)Mohd.Fauzi - 29.925
26)Lun -
1/10 -
85)Albert -
86)Akhiar - 40.610
1/8 -
22)Leong Pak Sing -
23)M.Zain - 26.995
24)Ismail - 75.890
26)Lun -
#148
Re: R&R
#149
UPDATE:
1/10 -
01)David Voo 40.750 - S710 (Sabah)
02)Richard Voon 40.610 - Mugen (Sabah)
03)Poniman - 40.630 - Mugen (Sabah)
04)Nadzree - 27.025 - Mugen (Sabah)
05)SD Lung - 40.370 - Mugen (Sabah)
06)Brandon Lo - 75.550 - Kyosho V1RRR (Sabah)
07)KK Lee - 40.650 - Mugen (sabah)
08)Adnan - 40.945 - Mugen (Sabah)
09)Iskandar - 40.670 - Kyosho FW05 (Sabah)
11)Leong Keng Hoe 27.045 - Mugen
12)Big Kent - 40.435 - Mugen (KL)
13)Gerald Lim - 41.140/40.835 - S710 (KL)
14)Hafiz Shah - 40.270 - V1RRR (KL)
15)Ong Kee Huat - 41.060 V1RRR (Penang)
16)Eric Ma - 40.875 V1RRR (Penang)
17)ANDY DASS - 40.130 Serpent 710 (KL)
18)LIM TOW JIA - 75.830 V1RRR (KL)
19)RAMESH - 75.790 Ho Bao (KL)
20)LOOI GA SING - 75.630 Ho Bao (KL)
28)STEVEN TYE - 75.590 - SERPENT 710(KL)
29)SUAH - 40.590 -SERPENT 710(KL)
30)MICHAEL OOI - 40.290 - SERPENT 710(KL)
31)BADRUL ALIAS - 40.290 - SERPENT 710(KL)
32)Sydney Soo - 40.650 - Kyosho FW05R
33)Ben Siew -27.285 - Kyosho FW05R
34)Desmond Lam - 26.995 - Kyosho FW05R
35)Anthony Wee - 40.000 - Kyosho FW05R
36)Yap Chew Kong - 27.345 - Kyosho FW05R
37)Lun - 40.375 - Kyosho FW05R
41)Kelvin Wong - 29.860 - NTC3
42)Jordon - 29.TBA - NTC3
78)Lye Boy - 40.070 - NTC3 (KL) <=- Please rename,Thanks
85)Albert -
86)Akhiar - 40.610
1/8 -
22)Leong Pak Sing -
23)M.Zain - 26.995
24)Ismail - 75.890
26)Lun -
UPDATE:
1/10 -
85)Albert -
86)Akhiar - 40.610
1/8 -
22)Leong Pak Sing -
23)M.Zain - 26.995
24)Ismail - 75.890
26)Lun -
#150
HPC, will the race STARTS at 9am as posted? Reason is, in all races I have been to, organiser only starts setting up at 9am and most if not all the time, race starts at 10.30 or so. With so many heats (at least 10 groups in 1/10th and 3 groups in 1/8th), I think it will be better if the qualifying session starts at 9am sharp, not to mention the kinda weather we have been having lately.
Rgds
Rgds
