Xray T4 18
#361
#362
You missed a promotion opportunity
Brass Bottom Case for HW XR10
https://teameamotorsports.com/collec...se-for-hw-xr10
#363
By centering the servo 90 degrees to the link I get near symetrical steering throw left and right at 70%, 80%, 90% and 100% Dual Rate.
#364
#366
I always centre the servo saver at 90 degrees to the turnbuckle link and not the chassis as this gives equal throw left and right. If I centre the servo at 90 degrees vertically I always have to add more EPA on one side which throws out Dual Rate adjustments.
#367
The steering plate moves horizontally, and with the saver dead vertical you get the same arc of movement in either direction.
If you mount at 90deg to the link the speed of steering will vary slightly in each direction (and at different points of steering lock) due to the fact that the link is moving in different arcs in each direction, i.e. when turning right the link move up relative to the saver as it rotates upwards first, when turning left the link moves down as the saver rotates downwards.
The issue being that the rack still moves horizontally only.
#368
Never understood why people think the saver should be at 90deg to the link.
With the above settings it's fine at 100% dual rate and will give equal angle left and right but at say 80% Dual rate I never get equal steering left and right without readjusting EPA.
It is a pain as the saver hits the steering mount on my TCXX before getting to full lock. If there is another way or something I can check I'd happily not set it 90 degrees to the link.
I've always thought it seems odd that all manuals say 90 degrees to the chassis and yet it creates un-even steering lock?
#369
I've always had slightly different EPA's, but never a very large difference, maybe 10 at most.
On the Xray I set max EPA to be just as the steering post touches the saver arms, then back it off.
If anyone ever uses the steering knuckles touching the C hubs then that adds a whole lot more into the equation, steering link lengths etc.
At 90deg to the chassis, the servo arm should be moving an equal amount to each side, no matter what car it's on.
#370
It shouldn't create uneven lock, so there's an issue somewhere.
Everything is fine until I adjust dual rate as it throws out the end points at varying percentages?
I'll check again on my T4 tonight. I've always thought it had something to do with pushing the steering one way and pulling it the other but surely the arcs are the same as it is a circular motion from the servo???
#371
....Everything is fine until I adjust dual rate as it throws out the end points at varying percentages?
You're correct on the second bit, the arc's taken by the servo horn will be identical no matter where it is positioned on the servo.
#372
The dual rate should reduce or increase things by the same amount each side as you adjust it, no idea why it should be different each side.
#373
For those that still can't grasp it;
Play the following Youtube vid at 0.25 speed and you can see the piston slowing as it reaches the end.
That's effectively what you are doing by starting the links attachment point on our 'wheel' (the servo horn) closer to it's end, when the link is angled.
https://www.youtube.com/watch?v=LwphVOXmL3Q
#374
If hes running a Sanwa radio, there is a option on the radio for the servos, that either lets you run it in centered or parallel, or something like that. Regardless one will only effect the servo at center off and the other will re-adjust the endpoints as the trim is adjusted.
