Like Tree759Likes
Mugen MTC1
    Hide Wikipost
Old 03-13-2018, 09:34 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MTC1
Last edit by: liljohn1064
Mugen MTC1 Wiki:
MTC1 Manual on the Mugen Web Site.
Correction for the manual
The max/min tooth count of the spur and pinion combined.
64p = 127 to 164 total teeth
48p = 95 to 120 total teeth
People who have spare spur gears left over from other cars which they wish to use but can only utilize 2 of the 4 mounting holes, here's neat trick from MKAH to drill 2 more holes precisely in the spur gear:
1.Dismantle the Spur Holder and mount XRAY Spur with two screws.
2.If you have take a 3mm Top Setting Screw
3.Get the Top Screw in the first free thread to the Spur Holder from the other side until it touches the Spur a litle bit.
Make the same with the second free Thread.
4.Dismantle Top set Srew an the two screws witch holds the Spur on the Holder.
Now you see two marks absolutely central.
5. Take an 3mm Driller an Drill the holes at the marked places
6.Mount the Spur with the two old and two new holes on the Spur.
Spur Gears known to fit the gear holder with the correct hole pattern
1. Axon
2. Panaracer
Upper front arm hinge pin set screw tip (or any of the kit set screws):
When installing the set screw run the set screw in until you can see it come into the hinge pin gap. Back the screw out and make sure there is no flashing in the way and then the screw. Now slide the pin in and you should hit the pin and come to a dead stop. It will be a solid feel and not sloppy like it will not tighten which is caused by any loose plastic.
Hara's Setup
Robert Pietsch's Latest Carpet Setup
Print Wikipost
Old 09-09-2017, 01:30 AM
  #631
Roelof's Avatar
Originally Posted by XCELL
And this is why if you have been in this hobby for a few years you learn never to buy the first run of a new kit! Wait a year and all the potential flaws will be found out before you waist your money!. Love the looks of this car though.
Patrick
Well... That Pietsch as a non-experenced electric driver could get 6th place on an ENS which is basically a small world championship with many large names does not count?, I do find it very impressive for a 1st impression.
Roelof is online now
Old 09-09-2017, 02:45 AM
  #632
Bar
Originally Posted by disaster999
It was my understanding that it didnt matter much as well, but was told differently by others racers at the track. When they saw the MTC1 and looked at the size on the pulley their instant reaction was "oh this car must not have much torque"
Belts not needing to bend that extreme sorta make sense, but not sure how significant the effect would be. I guess the results from the yokomo speaks for itself :shrugs:
I think Yokomo changed to bring the COG back up as they were not getting enough traction, more roll more traction, I guess it is finding the balance between the two. They also had some reliability issues I believe.
Bar is offline
Old 09-09-2017, 02:50 AM
  #633
Bar
Patrick
Associated TC3 what a terrbile car that was
gigaplex likes this.
Bar is offline
Old 09-09-2017, 03:02 AM
  #634
Bar
Originally Posted by liljohn1064
All, I asked on the Facebook page, but maybe can get an answer in here.
With the spur you have installed, Tell me the smallest pinion that makes contact with the spur and the largest pinion you can fit until the motor runs out of movement space. I need the max and min tooth count as this will tell me what range of pinions and spurs actually fit. The gear chart is nice, but doesn't set any limits on size at the top of bottom of the chart. I'm pretty sure a 116/50 combo will not fit on any TC on the market and a 99/20 might have a 5mm gap.
Posted on Facebook by someone, you have probably seen it already:-
Mugen MTC1 48DP gear chart.
FDR 1.7
Max 120 teeth (64dp 160 teeth)
Min 95 teeth (64dp 127 teeth)
These are just calculated but am confident within 1 tooth on max and min. (My get out of jail card in case)
liljohn1064 likes this.
Bar is offline
Old 09-09-2017, 04:48 AM
  #635
What internal does this car have guys ?
Ggrant is offline
Old 09-09-2017, 05:28 AM
  #636
BardSmith's Avatar
Trader Rating: 64 (98%+)
Ready to rumble!
snuvet75 likes this.
BardSmith is offline
Old 09-09-2017, 07:33 AM
  #637
Bar
Look above your original post
GrandeGixxer likes this.
Bar is offline
Old 09-09-2017, 07:39 AM
  #638
BardSmith's Avatar
Pulleys are 34/20. 1.7 internal.
Old 09-09-2017, 09:26 AM
  #639
Originally Posted by BardSmith
Ready to rumble!
Looks great good job
Ggrant is offline
Old 09-09-2017, 09:53 AM
  #640
Ready to rumble!
I see that we can run battery leads under the top deck. Awesome!
Ggrant likes this.
DavidNERODease is offline
Old 09-09-2017, 10:12 AM
  #641
GrandeGixxer's Avatar
Trader Rating: 21 (100%+)
Anyone put it on scales yet to see just how heavy the front end is? ;P
snuvet75 and Ggrant like this.
GrandeGixxer is offline
Old 09-09-2017, 11:38 AM
  #642
Roelof's Avatar
Like most cars some pulleys, carbon, 2 belts, some plastics and some screws are found internally.
Old 09-09-2017, 11:49 AM
  #643
snuvet75's Avatar
Trader Rating: 16 (94%+)
I didn't know you make jokes Roelof.
snuvet75 is offline
Old 09-09-2017, 11:50 AM
  #644
snuvet75's Avatar
For that matter, what's the kit weight? Or weight with all installed w/o body?
snuvet75 is offline
Old 09-09-2017, 12:00 PM
  #645
daleburr's Avatar
I think t2shop compared it to a T4 and it was 25g heavier, with identical electrics. I've never seen a T4 without a tonne of ballast so you'll be fine.
daleburr is offline
