Xray T4'17
#752
The 0 degree hubs are made for the rear end when running the ARS options. 4 degree blocks are definitely going to give you some more steering. You should post your setup so we can get you moving on the right track.
#753
What did you notice going from the Flex aluminum chassis to the solid one? I am weighing picking up the solid chassis for 17.5 class running.
#755
Looks like Ill be adding that at the 11th hour 🙂
#756
Yes, but the '17 chassis has the RF suspension mounts moved slightly outwards, reducing toe in. You'll have to run a block that is 0.5 further inward than what you'd run on your '15 in order to achieve roughly the same rear toe angle.
#757
The solid chassis numbs out the car a little bit compared to the carbon or flex and makes it much easier to drive. That's why a lot of guys are starting to run it on high grip black carpet. It just takes the edge out of the car.
#758
The issue with adjusting the L/R balance with weights not far from the centerline is that it takes a LOT of extra weight to get to 50/50 L/R (as you load the already heavy side too...)... you want to add it as far away from the centerline as possible so you can get to 50/50 with as little weight as possible. unless you're under the limit of course
With the t4, most standard electronics (read: non lightweight lipos) will get you there "by design"
#759
ok guys,
got kind of a newbish question. my car needs more off power steering and better rotation.
I've changed rear diff from 10k to 3k and that helped but it still needs more.
I order the FF brass to add more weight in front, right now I have 10 g weights on each side in the front .
Any obvious things I'm overlooking here?? Right now my back up car is better than this but I want to run this car.
Thanks.
~clueless in Orlando~
Thanks.
#760
ok guys,
Thanks.
Thanks.
#761
-2 camber all around
2.5 springs in front 2.6 springs rear
shock position 2 front and rear
400 oil (from kit)
droop 6 front, droop 4.8 rear
camber washers in front 2 inside 2 outside
camber washers in rear 4 outside 0 inside
running flex chassis
brand new black crc carpet, track is very tight and technical.
400 oil (from kit)
#762
400 oil (from kit)
400 oil (from kit)
If running '17, run center graphite brace.
128Likes
