Platinum Lipo
#1066
Originally Posted by SlamMan
Does anyone have the Platinum batts in stock?
#1067
Rick, I know it's probably answered in another thread, but I figured instead of digging elsewhere, you would know better than anyone else. Does the new TC5 accept both Orion LiPo packs without any "dremel shoehorns?"
I'm a little bummed out by the new JRXS-R's seemingly fragile condition, even though the car is PERFECT with the 4800 Orion pack in it. I'm kind of starting to look elsewhere...
Thanks,
doug
Thanks,
doug
#1069
I just picked up a Platinum pack from the LHS today. The case seems to be spread or expanding on one corner. My concern is that the cell inside has swelled causing this. This or the case is just warped.
Anybody run into this? What do you think?
My secondary concern is this might make it difficult to fit in my 007. I'll just have to try and see though.
#1072
If the gap changes over time, then you could be experiencing swelling.
It is OK to put a small drop of CA glue on that corner if the separation is causing fitment problems. Just don't put a bead of glue around the entire edge.
#1074
Originally Posted by Scrad
What cheap charger can I use for my Platinum lipo? I've be bumming my buddies advantage, but would like something for myself. Nothing too expensive. I'm waiting for the lipo update on the CE gfx charger.
And I think the Avionix is around 75.00
#1075
orion avionics charger, max 5 amp charge rate, perfect for your platinum (4.8amps rate) - about $80
#1078
Originally Posted by birdy233
what is the meaning or difference in discharge ratings on lipo packs? 10c, 20c etc??
#1079
Originally Posted by kuzo
It's the amount of continuous discharge the pack can handle. A 20C lipo like the platinum can handle discharge up to 20 times the capacity. So the plat can run 96 amps continuous. I know burst rate is much higher but don't have time to look them up.
The Platinum is actually 15C but at such a high capacity it still performs strong.
The 3200 is 20C and this is why the 4800 and the 3200 seem to be so matched when it comes too durability.
The C ratings will continue to increase with capicites as sizes and cost go down this is another advantage of LiPo over NiMH. NiMH will continue to increase in size and price exponentially with power.
#1080
MrBlack - Gotcha on the plat C rating. BTW, the plats saved my butt the other day when my 24V lithium drill batteries died. 3 in series lasted quite a long time in a time of need. Voltage never dropped low even under load. Guess my warranty is shot on the packs though huh?
